Everything posted by FlatFourFrenchy
Leak free in 2017 maybe.
I drive a 94 Loyale with a 92 engine in it. The seals seem to have been drying up on me lately causing lots of leaks. My main leak was just resolved this weekend resealing The Rocker Box to head connection is specifically the o-ring that was non-existent in the old passage to the camshaft. With that resolved I have always had a problem with my power steering pump and fluid leaking from it. Does anybody have any ideas were the best seal, gasket, or kit to resolve that problem is?
Painted an extra set of wheels and applied some Firestone Winterforce tires. Fresh plug wires and plugs. Still looking for the oil leak on pass side and hoping it isn't the rocker box to head gasket.
13 inch tire discussion
I am back to stock height and rims and have a set of Firestone Winterforce tires on the way. Bring on the snow.
Last Saturday I swapped in a good motor into my 94 Loyale out of a 91 Loyale. The check engine lamp was on since swap. Ran onboard code test and found code 55. Hmmmm? Exhaust temp sensor open or shorted. Got to pocking around and found that the 91 did not have a temp sensor where the 94 did. Easy. Swap engine wire harnes and drill and tap manifold and install sensor. Light fixed.
Finally dropped in donor motor without lifter noise and blown headgasket. It is just wonderful to lay underneath while its running and just smile. The two inch lift really helps with getting under it. Just the whrrr of the dry belts.
While old motor is still ticking away at 200k and oil light only comes on at idle I freshened up all of the front seals and timing belts on donor motor. It wasn't leaking but it is so much easier to do with motor on the stand. I went with genuine suby seals for oil pump and valve covers. The oil pump reseal went smooth. I found the pump oring seal split so I was happy to fix that now rather than waiting for the TOD again. I met the parts guy at Subaru and he was very new. His has been training on the new parts catalog so I had to work with him on the illustration on a car that when new he was still in diapers. All seals still availible at dealer and not stupid priced either. I am busy next couple of weekends and am looking forward to installing better engine and a tickless future very soon.
High Moisture Day
My 94 did the same thing. Cap had barely visible carbon tracks. Enough to make it hard to start when damp outside. Hasn't done it since replacing cap over a year ago.
EA82 SPFI ECU getting flakey?
If yours codes are all over the place I would start with checking all your grounds. I once had a 93 VW Eurovan. Started bucking on highway if I tried to keep it at any steady speed. After many attempts to isolate cause, I found that the chassis negative wire from battery was loose. My ecu was trying to find ground through the drive axles to the engine ground (-). It can make for a very simple and free fix if that is it. Good luck
SPFI EA82 Hesitation on Acceleration when Cold
My 94 does the same exact thing. Kinda just thought it was the nature of the beast. I know carburater cars have done this for years when the choke was a little off so that would lead me to guess that it ia a fuel delivery issue. Never really bothered me for the two minutes it lasts if I don't let my car warm up good.
Got my exta front hubs and rear drums drilled for six bolt wheels and got them all installed as well as some good used firestone destination a/t's in 225/70 15. Minimal rubbing with 2 inch lift. Will do some adjusting when we get back from pool. I'll post some pics then.
Noise in rear please help
Maybe it is the rubber bushings that you hear. I have tracked thousands of noises and you will have to isolate it more. Does it make the same noise jacked up with wheels off the ground? During braking or accelerating or just steady driving?
the compass is dead on when compared to my Garman GPS, I still need to mount the temp sensor, but will probably put it somewhere up front around the bumper area When you push button and end on direction hold it and numbers will appear. They are for setting zone. Look on a zone chart and pic the zone that you are in.
A/c & r-12
On a 70° day high side might be over 200 and low side below 100. I don' have a chart handy. The bubbles usually indicate that system needs a charge. As using gauges, red=highside, blue= lowside, and yellow is for source of charging freon or recovering freon. To check pressures just turn valves closed or the precious freon will dicharge out yellow hose.
Gave up searching...
Yes, the two lower lines at switches come from one and are t connected to make the two.
This is a picture of my 94. The two lower nipples (when mounted) are from vaccumm source. The nipple ontop and rear most goes to large vac. Pot on driver side of tranny. I can't see where other line goes but i would guess transfer case. Hope that helps.
lazy lifter?
Read up on the other post about tick of death and fix. Mine has been ticking for over 30k soI don't think the death part is very accurate. Still gets uppper twenties in mpg and will roll along at 85 mph all day long. It is annoying nonetheless.
Finished stripping donorwagon and it is ready for scrap collector. Once that was done I took my daily driver to the banks of the Missouri River and caught some dinner.
Playing with tire sizes.
Yesterday I found a free pair of 235/70 15's and decided to see just how much work they would be to roll with. By the way, I have the two inch lift as described in the offroad section. I have so far spent $4.00 on entire project and that was for the black paint. The wheels are the 2WD Colorado wheels. I am kinda liking it but I will really need to go after it with a sawzall and BFH before I can drive it so here are some pics.
lift and tire size combo pics...
Two inch lift with Chevrolet Colorado 2WD wheels and 235/70 15's. Still need to do the trim and BFH work.
Today I hauled the donorwagens engine to the steam bay and gave it a thorough cleaning gefore I give it a complete reseal. Took two convertors and got exhaust quiet again so now the TOD on engine is very pronounced. Looking forward to putting in a quiet engine with half the miles.
I found a N/A loyale dyno run video
My 94 probably doesn't have the hp it once had with the TOD all the time but like loyale said once you get it going, get out of the way. Eighty with no problem and still more but I usually try to be conservative so I only have to buy one tankfull every couple of weeks. Where it really shines is in snow up to the grill and driving where noone else would dare. Then I am very happy with whatever hp it still can muster up.
Steam cleaned engine bay and replaced rusty rear bumper that kept leaving piles of rust every time that I shut the rear hatch.
Stuck Brat cylinder 1979
Thank you very much.
Buddy at work is working on 79 Brat. Ignition cylinder stuck in run. Can't start it, can't turn it. Anyone have any ideas or know of part supplier for cylinder?
Hi everyone, I'm new
We use a tool at ourshop that "sniffs" for exhaust gases. It pulls fumes out of radiator and changes the color of liquid that fumes have to pass through if exhaust gases are detected. Maybe the gas they spoke of was not gasoline but rather exhaust gases.
