Profiles
Everything posted by subarurx yo
I've found nothing, im wondering what dualport headers to buy for my ej swapped rx (ea82 body) right now im running my homade ones off the flanges that keep getting cracked from hanging so low and it kinda sounds ricey. I was looking at the ebay ones for under 150 bucks, if any work which ones do i buy for, legacy, impreza, forester?... what year?
well the reason i built the frankenmoter is to have more power, and its alot more than the ej22 in a little rx, i will be replacing the t-belt, as soon as i get the money, and i should have just bought new headgaskets, but i didn't i kinda thought that metal ones were reuseable, just not graphite ones, from now on i wont be reusing any or spaying stuff on them. mine haven't leaked any yet but im always checking and keeping a close eye on temp just in case. thanks for help though
well it appears i may not have to tear my 2.5 apart, after i took the engine out and down to the longblock i noticed the timimg belt very loose and the tensioner wasn't even touching the tensioner puley and when i pull the belt tight it makes that clunk that sounds just like it did while running, so i slowely re compressed the tensioner like i should and slid it all the way to the left, where it puts the most tension on the belt, tightened it and pulled the pin on it and the rod only came out about half way, not even tensioning the belt.
so after 4-500 miles on my ej25d/ej22e phase I franken motor it sounds like a metal to metal loud deep squeak with a tap and i still have a great ej22 shortblock, im on a very low budget and saw that they both have the same stroke so im wondering if all the bearing sizes are the same between the two motors so i could use 2.2 guts in the 2.5?
i figured it out i just popped the pin out with pliers and got the cable out
ok so i searched and cannot figure out how to remove my clutch cable, after half the day researching and crawling under the dash, the furthest i got is removing the 14mm nut i think holds the pedal on. Also how do you remove the pin that's on the spring attached to the pedal, if it needs to come out? It would be nice to have pics too.
is the turbo water or oil cooled?
subarurx yo replied to jeryst's topic in Old Gen.: 80's GL/DL/XT/Loyales...
well both run through the turbo but im not sure if the oil cools it much? -
engine swap in 87 gl 10 sedan help
subarurx yo replied to gl101987's topic in Old Gen.: 80's GL/DL/XT/Loyales...
A ej22 in my opinion is a great swap, its reliable, powerful (135hp ish) and gets good mpg but it does take some work and money, research it and you will see:D -
Where do I connect a boost gauge? (EA-82T)
subarurx yo replied to PlaneDriver's topic in Old Gen.: 80's GL/DL/XT/Loyales...
where i had mine is off the vacuum line running straight up off the intake manifold on the right side, i think if you follow the line from the vacuum canister thing for diff lock? behind right strut tower you should be able to find it and i just used a T and spliced in it. i swapped to n/a ej but still have the motor so i can maybe snap some pics tomorrow where to put it -
ya i thought it may be and i checked grounds, according to the ecu pinout charts you gave me, at ecu plugs and everything seemed grounded that should be, but i may be missing some, anyways today i swapped the #4 injector with a injector from a 1&2 fuel rail instead of another #4 injector and it seemed to solve the misfire issue and i drove it to the beach and back just fine, but im skeptical of the weird tweaking out of electronics
when my engine stalls for whatever reason, with the ignition still on i hear stuff that sounds like electrical buzzing, the tach jumps and the fuel pump either continues to run, or cycle, like the ecu is trying to make it run?? and a couple times it has sputtered after 2-3 minutes after shutting the car off?, I also have had misfire on #4 and swapping injector with a used hasn't helped, i put a new fuel filter on and ran injector cleaner through it, VERY often it will miss at low rpms with full throttle and or high rpms, and sometimes it feels kinda more sluggish and when to the floor at around 4500rpm feels like vtec and gets full power and at the same rpm every time/ any gear, #4 cylinder is now always missing since random when i started it and sometimes idles fine. ECU codes i pulled before today was i think 51 and the one for the o2 sensor(no sensor hooked up) the engine is Swapped in a rx, and never fails to run, but has weird issues
dang now that i think of it, the filter hasn't been changed since i got the car over 4k miles ago. I replaced 1and 3 injectors with used ones as they completly quit, but it took a while for the injectors to work too as there wasn't a difference right away and the engine jolted all arround on two cylinders, may try a tps today as its like 5 bucks, possibly 2,4 injectors and fuel filter
my car when accelerating, changes its tone like its missing between about 2000-4000rpm like its detonating, kinda clears and power feels like its surging but not joltiong arround,but it falls on its face after 5000rpm and ive replaced the knock sensor since old one was cracked allover and it went away completely then came back, i have ran injector cleaner through it and at first, before this issue i got 28mpg then to 20mph then 24 when filled with premium gas. I reasearched but no luck, its a swap from a 92 legacy. it doesn't always do this but usually disconnecting knock sensor while its running fixes for about 3 starts of so, before i replaced the knock sensor , when starting sometimes i had to hold it to the floor while cranking it and it ran on two cylinders until i drive or rev it up, then goes normal. Im just confused and trying to work out the bugs, so ideas will be appreciated .
silly question of the dayI have an 88 gl coupe.
subarurx yo replied to ellets's topic in Old Gen.: 80's GL/DL/XT/Loyales...
my rx has the jack normally under a wood peice thing under carpet behind the left fender well
