Everything posted by Unsp0kn
'89 RX: Project Rally
Fixed the leaky BOV today. Did the crush mod and now it stays shut tight at idle which means it idles better too. Still chasing the cold start issue, should have a new CTS soon and new wiring. Hopefully that fixes it. It runs strong from about 2500 all the way to redline now and feels a little smoother. Once I get it running properly I can get started on all the metal work inside and it'll be RallyX ready for next year!
picked up an RX, been sitting awhile, got it running, but no boost?
Cool to see another RX alive! Figure out anything with your boost issue?
Took some quick pics, now I think I can get back to focusing on the interior and getting the seats in. Gauges hopefully soon and build a new dash!
Well I fixed the vacuum issues I could find and it seems to have helped a bit. The turbo inlet wasn't all the way down so I loosened the clamp and pushed it down about a quarter inch. I still think the CTS needs replacing.
Cool, I was wondering if that sensor was the one. The plug on it is broken and I actually found it unplugged the other day. Going to take them both out and re-do the wiring, I read that can be the cause too. If it still does it, I'll replace the sensor. Yeah the dash isn't very pretty, I bought it this way. Got plans to make a more professional setup and do away with the stock gauge cluster, just need to get er running right before I dive into throwing money at all the work I have planned! The coolant is full and it doesn't have any white smoke out the exhaust.
Well I fixed all the leaks I could find, now it will start, idle perfect for 6-10 seconds, then drop down, backfire a time or too and chug to a halt. I can start it right back up and it does the same thing. Once warm, it idles fine.
No CEL, but who knows if it even works anymore. I'm going to go after the vacuum leaks firstly, that could be all it is since it ran fine when I picked it up. I'll check the plugs and wires next, they are all new.
Well I'm trying to track down issues with the RX, the cold starting is a problem and it frequently wants to fall on it's face while driving. It's got vacuum problems galore from the previous owner, the PCV system is all unhooked, BOV won't stay shut under vacuum and I found capped nipples on the intake that were cracked and probably leaking too. Anyone know what this little sensor on the intake manifold runner is? I'll try to get a pic up later, but it's on the runner closest to the firewall on the passenger side. It was unplugged, plugged it back in and the car still stumbles sometimes. I'll be driving, get on the throttle, hear the turbo spool up and it feels like it's dragging, then all of a sudden breaks loose and accelerates.
Funny you say that, the only place I could find the wheel adapter hub was in Oz! He said this car over there is an L-series if I remember right.
Haha, thanks guys. I've been stalling on this project majorly lately, bought a dirt bike and have been riding as much as possible. The RallyX season is almost over now, but I should get more work done on her this fall. I'm hoping I can get it moved to a friends shop about 100mi away this weekend and get some of the metal fab started!
Wheel is in! Pretty nice piece, I really like it. Now to tackle that dash and get the gauges ordered!
SAAS Octane wheel and BOSS adapter kit arrived today from down under! Excite!
86 GL10 Turbo -Shortysayhi
I think the wing is too rounded for that body style, but to each his own!
My 83 2dr GL
Wow, this is going to turn out so badass. Watching
My 89 RX
Love this car, pretty much the reason I bought mine even though I'm going a different direction with it.
Tick of death and Air bubbles in the oil
I can't say about the oil pump, but my '89 RX had a super loud tick last week I started it after it sat for almost a month. It was really loud and got louder as the RPMs went up. I checked my oil, still shiney gold so I drained about a qt. out and topped it back off with LucasOil Engine Oil Stabilizer. Fired it up and let it run a good 15 minutes and now it purrs like a kitty. I've used the same stabilizer in all of my cars, it quieted down the valvetrain in my GSR swapped Integra (VTEC are notorious for louder valve trains) and I use it in my WRX as well. Seems to be good stuff!
I'll see if I can get you a pic. Like I said, the passenger side will need new sliders, both seats are just aged. I probably won't have them both out for about a month at least, have to get it to a buddy's shop 100mi away to get the brackets made for the new ones.
They are thrashed bad, grease covered, drivers side is duct taped back together all down one side. They are pretty nasty. I ruined the sliders on the passenger seat too.
Picked them up off Ebay cheap, was $240 for the pair shipped. Put them together a few days ago, they are pretty good for the money. The rails are narrower than stock, so I have to come up with some brackets to mount them.
Ok, I found where to get steering wheel hub adapters finally! I found them at http://www.accessoriesonline.com.au, I e-mailed CS and Stuart told me exactly which kit I needed. I guess the RX is the "L-series" down under, so that's what I'm going to go with. Shipping is a bit much to the States, but I've been looking for 2 months for a solution and finally found them if anyone cares!
88 GL bounces when idling
The idle bounces or the car physically bounces?
'87 RX at Oregon Trail Rally this weekend
Obviously a Sparco wheel, is it also a Sparco hub adaptor? Does anyone know? I'm trying to find a way to put a race wheel in my RX project.
I haven't even started the real work on this thing yet! Still have lots to do before it is ready for any RallyX.
New seats arrived with sliders! Still need to assemble them and get the mounting brackets ready to go.
Seats will be in today! Can't wait to get working on the install. Also does anyone know of any steering hub adaptors for these cars? I really want to replace the stock wheel with a GT or Rally Style.
