scrapdaddytatum
Everything posted by scrapdaddytatum
  1. well is the part i replaced that vsss part, its the elctro/mechanical piece, didnt change anything, does stabalize above 30????????
  2. 97 outback 2.5 4eat replaced the cluster, and replaced the speed sensor but the speedo jumps seems to only work while my foot is on the accelarater any ideas????
  3. jamie, just so you know i replaced the ring and sensor on driverside, myself i do ALL my own work and the fluid level was good, i did also replace all 4 rotors and pads and then bleed the whole thing untill it bleed clear at all 4 corners i also rebuilt the 2.5l , rebuilt the 4eat becouse the 4wd was chunked new header and cats, new o2's, new cluster, speed sensor stil has an issue with the speedo that is a different post though
  4. anybody no how to reset them, turns on instantly, does not reset with ecu fixed problem(sensor ring broke and destroyed sensor) all new now still lights on???? any help searching didnt lead to an answer
  5. will the 2.5 from a 03 baja fit in a 04 outback and can i use a 91 leg 2.2 in a 98 outback w/blown 2.5 whats diff between 96 2.2 and a 91 2.2??? let me hear your noise!!! word
  6. i used Goerlich Catalytic Converter they are suposed to be true odb2 compliant seems to work real good, acording to the o2 read outs
  7. do you think after market cats will affect any thing??? i have real nice name brand cat that is odb2 compliant works great, never throws a code and water spits o plenty i think it would pass any smog test but we dont have them here so i got no way to tell
  8. im sending a car out to cali for a customer 97 outback 2.5 with new motor and trans and new exhuast too new cats and all will it pass cali emisions or do i need to do something extra to it????
  9. yes yes manarius you snobby bastard i run the english market gt-b projectors and you can buy on ebay the UK lights and guess what, THEY ARE THE SAME PART NUMBERS AS JDM BOOGER OFF YOU PICKY BOOGER:Flame:
  10. the projection headlights are THE way to go i have installed and used several sets of the JDM lights and although a little wiring is involved they KICK AZZ and i mean KICK AZZ they are so worth the money there is another kind, the are called morrettes(spelling???) and they are OK, but the JDM projectors are the way to go i had a 97 legacy gt with JDM projectors and JDM fog/driving lights and they ROCKED insanely bright, and great for country roads
  11. if anyone is interested i make custom mandrel bent , seem welded, exhuast any way you want it examples of work availible via email
  12. if anyone is interested i make custom mandrel bent , seem welded, exhuast any way you want it examples of work availible via email
  13. i have used worse with no ill effect, as long as none are on the headgasket edge i would not worry about it i have run much worse on toyota's
  14. did you check all your plug wires?? and check all the connections?? besides stating the obvious,but sometimes we forget the little things
  15. hey i have an xt6 too, dont make fun of the flying pizza slice, it really can fly and dont forget gen 1 brats, they were pretty ugly and i like the new pretzel looks like a video game but thats cool i drive like a video game
  16. do a relearn unplug battery step in brake pedal hook battery back up and start car, dont touch anything wait for it to warm up and dont touch anything when it is warm, shut it off and restart, is it normal then this is the standard relearn prcedure if you touch something during that first restart it can effect the relearn cheers good luck
  17. check the listing in marketplace lost storage to day car MUST go i have no where to keep it clear title
  18. OK LET ME BE CLEAR THIS GAS SAVER THING IS A HOAX, NOT REAL BIG FREAKING SCAM I AM PART OF A WATCHDOG GROUP AND THIS PERTICULAR ITEM HAS BEEN ON OR NEAR THE TOP OF OUR LIST FOR OVER 10 YEARS THE IDEAS ARE 30+ YEARS OLD I WOULD SUGGEST TO ALL TO READ ABOUT DENNIS LEE, AND AVOID THIS PRODUCT IF YOU WANT BETTER GAS MILAGE KEEP YOUR CAR PROPERLY TUNED AND KEEP YOUR LEADFOOT OF THE GO PEDAL OR AT LEAST NOT PEDAL TO THE METAL I GET 28MPG FROM MY 67 BUICK 300V-8(2BBL) AND THATS CITY CHEERS J:mad:
  19. i think those websites need to be hacked thats all i got to say about that they are bad christians.........
  20. HLS needs no reason to tow, they just do it to keep their techs busy logging loads of useless hours so they can fatten their budget......LOL
