Posts posted by Bantum
Yea - sorry the bidding war started at :
¥ 2,800
& is currently @
¥ 21,100
So you'll be lucky to get it at that ...
Add : fixed the link in my previous post ( I think )
Ciao, Bantum ...
Hmm NOS Bumper :
Found here : Edit : http://buyee.jp/item/yahoo/auction/b160300830
Something that might fit the FF-1 ?
Cheers, Bantum ...
You’ll need to get hold of one of these:
Then find the relevant section to follow procedure …
Cheers, Bantum …
Found a few others:
Found here : http://buyee.jp/item/yahoo/auction/n126957247
And this one :
Found here : http://buyee.jp/item/yahoo/auction/m123422074
Cheers, Bantum ...
Yep - don't use hard mediums like sand, unless you want them to look dull afterwards ...
Ha - I just found this thread when searching for more utes …
Here is my effort :
More details to be found here : http://www.ultimatesubaru.org/forum/topic/136886-subaru-xv-ute/
Cheers, Bantum …
Certainly Haight,
My background is in Architecture & Design ... So not a traditional industrial designer per say, but I still know how to draw ...
You can see more of my work in the photo bucket links below ...
Cheers, Bantum ...
Finally got round to finishing this drawing I had started ages ago :
Something for the Brumby boys to mull over ...
Cheers, Bantum ...
You should get a set of center caps to go with those Enkei's :
Note : I think the original caps are either f or m ...
More details here : http://www.hirano-tire.co.jp/enkei/enkei5.htm
Cheers, Bantum ...
Sorry to say there will be a bit of a hold up on this project due to my back surgery ...
So here is something else to tide you over until then :
More details on this beast can be found here : http://www.ausubaru.com/forum/showthread.php?t=23869
Cheers, Bantum ...
Wonder which GL you have there 19804wdPOS ... ?
This might help to tell us which model you have ie: Wagon etc :
http://ridehomehappy.com/index.php/blog/post/vintage-subaru-brochure-1980-model-lineup
2675-skishop69 - as far as I can tell, the internals of a 1980's 4wd 'part time' gear box are similar ( both in layout & gearing ) to the later 1983 'Dual - Low range' box I showed earlier, just the rear out put is different & its missing a few gears ( low range ) ...
( sorry I haven't been able to find an internal image of the correct gear box - will post when I've found it )
Add : I know it don't have no center diff also - never said it did either ...
Add : One way of confirming how much power is getting to the rear end, is to put the car on a dyno with a before & after test measuring just how much HP is getting back there & see if it's actually 100% ...
By the sounds of it, 19804wdPOS wants to do some 'burnouts' & waste a few tyres ...
So I'd say let him find out the hard way when something goes bang ...
Cheers, Bantum ...
Another thread worth reading : http://www.awdwiki.com/en/torque+split+ratio/
Might be a good idea to get hold of a manual, will help to follow up on the CV & other details on your car.
Here is another thread to read up on : http://www.ausubaru.com/forum/showthread.php?t=21886&highlight=rear+wheel+drive
So here is my understanding of the situation : Remove front drive shafts, engage 4WD, and Bob's your uncle - you've got rear drive only. ( only recommended for light duty / emergencies though )
If you're after something more permanent, you would have to look into upgrading gearboxes ...
Add : Found this diagram that sort of explains what I'm talking about :
Found here : http://www.subaruforester.org/vbulletin/f89/front-rear-diff-questions-445610/
From this you can see that it's unlikely 100% is going to be transferred via rear through that kinda center diff ...
( Item 1 & 6 are not directly connected ) - Granted your transmission is different, so I have no direct knowledge of it.
Hope I haven't confused you all too much - even if you have a similar gear box or not ...Cheers, Bantum ...
- 1
Hmm - I'm not sure about that, maybe only if you have a locked transfer diff ...
More details found here : http://www.ultimatesubaru.org/forum/topic/139096-4wd-loyale-rear-diff/
+ Something to show what were talking about :
Note : this is from a later model, but the layout & gears are similar ... ( the transfer diff is not shown )
There's no way to get full power using this type of gearbox to the rear with out serious mods ...
And how to get dual range 4WD here : http://www.ausubaru.com/forum/showthread.php?t=15316
Cheers, Bantum ...
As a temporary fix it would work - But you not sure you'd get all of available power to rear ...
Add : Yet to confirm actual figure ... ( Do note that the transfer gears in an EA GL slush box are split 60% front, rest to rear )
If you want to make it more permanent - you would need to re-build the box without the transfer gears / front Diff ...
Cheers, Bantum ... -
Like the concept, Great video ...
Cheers, Bantum ...
Found this beast :
Cheers, Bantum ...
If it has old style commutater brushes, they would be worn out by now ...
Nearly done with wheels ...
Last bit of casting :
And all apart :
And the aim is to make 'em look something like this :
Marked out Ready to cut :
Still more to do on front side ... :twisted:
Cheers, Bantum ...
- 1
Just received some more bits for this project ...
Some Stealth Mounts :
Some Racks :
& Test Fitting :
Got some more bits on the back burner too !
Cheers, Bantum ...
- 1
This is what I ended up with :
More on procedure here :
http://www.ausubaru.com/forum/showthread.php?t=23077
Cheers, Bantum ...
Ok - next bit to bring up to date ...
Last bit of casting dried :
Some fixings :
& holes Drilled :
More Securing :
Nearly done :
Cheers, Bantum ...
Some results from more casting :
Had to add a bit in the middle to level it out ...
More prep work :
Ready for casting :
And no - its not milk in the bottle ...
Done :
Awaiting drying ... hmmm will have to add some bolts later ...
Cheers, Bantum ...
Yep - I have them caps on my '76 Wagon ...
You'll need to get the ends of each drive shaft taped out to suit a M6 bolt from memory ...
Cheers, Bantum ...
1978 Subaru Brat. From death to life and everything in-between
in Historic Subaru Forum: 50's thru 70's
Posted
Narva do a complete range of plugs that you can directly swap over ( pins are similar size ) – You can either cut the old ones off & replace with new or more tedious - swap the pins over, which can be difficult to get the old ones out, as you may have to cut the old plug up … L
More here : http://www.narva.com.au/products/browse/quick-connect
Cheers, Bantum …
