Everything posted by matt167
USDM EJ25 DOCH to JDM EJ20 swap
matt167 replied to Zoltan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat depends. The EJ20E motor will work with an EJ22E manifold and wiring harness. But EJ20E is almost non existant anymore.
oil filter fit and install issues
matt167 replied to dburton97128's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI used to do Subaru oil changes several times a week on those cars. We did call it the fire ring. There is no reason you can't get your hand up there, and I never even used a socket cap wrench to even pull them off, and the cars/ Exhaust were HOT when I did it.. Pliers or a 3 jaw wrench is what I used Now when I did laying on the ground oil changes to my girlfriends moms '10 legacy, I actually used a Honda V6 filter. Same specs but slightly longer to make it easier to grab
17 inch Forester Wheels on 01 Legacy
matt167 replied to steve56's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX205 50 17 is the 17" equivalent of the 205 55 16
GOOD TIRES FOR A 2011 SUBARU FORESTER
matt167 replied to bull6791's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGrand touring is a name that some use but basically meaningless. Touring tires/ grand touring tires are just basically highway tread.. We sell a lot of the Master craft version of the CS5, the LSR grand touring. There a good highway tire
OEM parts source recommendations
matt167 replied to Basket_case's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXImpex Japan is a pretty cool source too. I just used them to get a clutch for my JDM Suzuki Jimny. I got my parts in a few days. You buy the part, then buy the package/ shipping when it's ready
matt167 replied to bull6791's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBest advice would be to buy a tread depth gauge. Walmart even sells them now for a dollar or so, or any auto parts store. any more than 2/32" variance or so and I would want an alignment. Check in 3 places or otherwise just look for uneven wear That would be for second from left. If your tires are flat spotted ( left ) then you need shocks/ struts or you got your tires at discount automart and the balance is way out.
matt167 replied to bull6791's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif your tires are wearing evenly, I wouldn't bother. If you have an inner or outer shoulder worn more than the rest then get an allignment
matt167 replied to bull6791's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXtakes a while to set up an allignment rack and often you'll find something just a smidge out of spec to where, your that close it might as well be done and at that point take your money for an alignment.. I had a buddy who recently went out of business who did alignment checks for $20, and $60 for the alignment which is dirt cheap here as well as having a low labor rate. He closed his business because he wasn't making enough. But he had a large customer base.
matt167 replied to bull6791's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXalignment is one possibility for pulling left or right. But also, you can have a hung brake and not know it, and there is also the possibility that a tire has a broken belt or is under pressure, and causing a pull due to high rolling resistance.. BTW I used to do allignments, but hated doing them so I'm glad I don't do them where I'm at
matt167 replied to bull6791's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf tires are wearing good/ even treadwear, you don't need one. Some elect to get alignment checked with every set of tires.
matt167 replied to bull6791's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf your Subaru is in good allignment, I would expect 40k miles to be about the max you'll get and 25k miles the least.. Somewhere around double that for a FWD Corolla. Figure 40-50k miles per set on a FWD
matt167 replied to bull6791's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYup, pretty much the northeast, the all weather tires are perfect.
matt167 replied to bull6791's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAll weather tires have superior rain/ wet traction compared to a 'basic' all season. probably not as good as rain tires but, it's PA not Seattle They are still plenty soft for dry pavement traction. Actually a lot of racing classes will use snow tires because they are grippy in dry conditions
matt167 replied to bull6791's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAll weather is basically a snow tire ( 3pt snowflake rated ) that they reformulated them a bit to be able to give them year round performance and treadlife and back them with a treadwear warranty.. All season tire will not have half the winter performance, but you might get more miles out of them in some cases.
matt167 replied to bull6791's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey are " All weather tires " designed and majority built in Finland, the remainder is built in Russia. They are snowflake rated for severe winter duty, but also carry a 60k mile warranty for use in every season. Nokian has been making a WRG all weather for probably 10 years now and the WRG4 was introduced into 2017 alongside the WRG3 originally. Now the WRG3 is discontinued and Nokian will likely have a WRG5 out at some point. Reviews are out there https://www.google.com/shopping/product/778595420962974515/reviews?client=firefox-b-1-d&channel=cus&q=nokian+wrg4&ved=0ahUKEwid497BtuzhAhVihuAKHZEkCc4Q4jUIOA
matt167 replied to bull6791's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNokian WRG 4 as I stated earlier. It will last ~30k miles and they will honor the warranty for a pro rate.
matt167 replied to bull6791's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcan't comment on those Toyo's, other than they look like junk. The 3.5 out of 5 rating in dry conditions is pretty scary as well.. Yokohama Avids are generally ok. if you had to pick between those 2, the Yoko's would be my selection
matt167 replied to bull6791's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFrom top to bottom recommendations Nokian WRG3/ WRG4 ( severe discounts on WRG3 right now as they are on clearance ) Nokian Entyre Mastercraft Grand Touring LSR/ Cooper CS5 Uniroyal Tiger Paw Bridgstone Ecopia General Altimax RT43 Veredestine Quadrac 5- I am not a dealer for these, but they are probably as good as a WRG3. Wish we could get them, but Nokian and Veredestine dealers don't intermix We sell the Kelly Edge A/S as our bottom price in stock tire. This is a slightly better tire than the Douglas All Season you get from Walmart and about as low as I would go.
matt167 replied to bull6791's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSubaru has Symetrical AWD that powers all tires all the time, so even rotated they will wear faster than a 2wd vehicle either rear or front drive and for sure, your only getting that far if you rotate. No tire will survive that much past 40k miles unless you buy a highway tire with a very hard rubber compound ( high treadwear number ) and it will be rated for a crazy amount of miles, 75-90k miles. But then look at the rain traction on that tire and it will be non existent Bridgestone Dueler isn't a bad tire, anything that Khumo makes is garbage. severe Runout, just pure junk
matt167 replied to bull6791's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBridgestone Dueler or the Geolanders are optional on The Foresters. 50-60k will not happen on a Subaru with 'good' tires. If you get 40k out of a set on any Subaru your doing good. Thing to remember is tires with a high mile warranty are going to be made of a very hard rubber. They won't have the best traction but they will wear and wear. I will never recommend such a tire. One of the big reasons I advocate a Nokian is their rock solid warranty. The WRG4 has a 60k mile warranty in a size a Forester will accept. It will last 30-35k miles which is average for a Subaru. Nokian will cover the warranty and your next set will come in at 50% off more or less.. Keeping in mind that Nokian is not the most expensive tire. We install WRG 3 or WRG 4 tires on probably 90% of the Subaru's we service. Most of those are warranty exchanges with happy customers that love how the tires handle
matt167 replied to bull6791's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthey come stock on many SUV's, that's why. You'll get 30k miles out of them rotated. They are decent, not great tires. Just decent
matt167 replied to bull6791's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXadaquate tires. Yoko's are stock on a number of Subaru's. A Forester would have Geolanders. Toyo is good but they were bred from racing and that is where they are best at
matt167 replied to bull6791's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMichelin is overpriced junk IMO. The rubber stays soft for years, so if you don't drive often Ig that's a plus. But for the same cost or less, there are better options General/ Continental ls the same company. Continental is generally overpriced, and General is fairly priced. An Altimax RT43 is an ok tire My vote will always go to Nokian after running them personally, and seeing how they balance. They are not cheap but also not expensive.. Also if they do knot or have belt seperation, getting them to do something for you is pretty easy. pretty uncommon but, they stand behind the product If you want something a little less expensive, I would probably recommend the Mastercraft LSR Grand touring. It's their 3rd tier up product line. It's a pretty good all season, cheap and reliable
matt167 replied to bull6791's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNokian WR G4, all weather. Cooper are 'good enough' as well as Mastercraft.. But the Nokian is an all weather tire. Being in PA, that means don't worry about switching to snow tires. They are snowflake rated, and carry a 40k mile warranty plus Nokian is very good about honoring the warranty. That said, do not buy Nokians online and take them to just any tire dealer. The beads are made special ( 2 ridges ), and they run dead true and perfect but only if you take them up to ~60 PSI before letting them down to spec.. Buy a Nokian from a Nokian dealer. The Entyre 2.0 is a nice tire as well but it's a ho hum all season. It's better than something like a Mastercraft LSR, but an LSR will run straight enough and is just a good cheap tire. Some Cooper/ MC tires are scary how much they runout side to side they have. We sent back probably 5 sets of Courser MSR ( Discover M+S sister tire ) because they were just unusable this winter.. I work at a Mastercraft/ and Nokian tire dealer. We do sell about every other brand as well
1999 Outback with missing engine
matt167 replied to Ravenwoods's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes, the wheels themselves will fit right on. But you will not fit the 205/70/15 on a regular Legacy without a lift of some sort, either OEM outback stuff ( which is basically subframe spacers and struts ) or a Forester lift. A 1995 Legacy though, will have a dual port EJ22E, and it will fit right into a 1999 Outback and plug in and run.
