my car EATS wheel bearings
GeneralDisorder replied to Uberoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave you checked any of the hubs for an out-of-round condition? As mentioned presses can deform the bearing pockets..... all things being equal the hub-tamer is a more delicate approach if you can get access to one. GD
'97 Legacy L - dies on right hand turns !?
Hhhhhmmm - yeah I'll have to pull the pump/sender and see if there is any foolishness going on in there. The car is 100% fine when going straight and when it dies it doesn't give any OBD-II codes so I'm thinking it's got to be something mechanical with the fuel delivery, etc. GD
Ej22 head bolts
GeneralDisorder replied to Markus56's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEyeball it. It's just not that critical. If it were it would say 90* and to use a special tool to insure accuracy. It says "80 to 90" specifically because it's an estimate, not a specific number that has to be measured accurately. These are NOT torque to yeild bolts - in fact there are alternate methods used by many seasoned Subaru mechanics that use real torque values rather than the degree method. The bolts do not stretch - they are threaded into an aluminium block and would rip the threads out of the block long before the steel bolts "yeilded" from torque. GD
Weird problem - EJ22 AWD Automatic, 147k. When accelerating around right hand turns (from a stop light or around an on-ramp, etc) it wants to die - like it's losing fuel. I've had the tank near empty and also over half full. No codes - just dies like it isn't getting any fuel then either picks up on it's own or will restart within a few seconds at most. I need to hookup a pressure tester and try to get a reading while it's doing this, but it's hard since you have to be driving for it to occur. Anyone seen this before? Do these have a saddle pump and is that somthing I should be checking for proper operation? GD
GeneralDisorder replied to Uberoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour new bearing wasn't new. It had 120k on it - I replaced a VERY bad bearing on a '96 with 115k on it not long ago...... It might have sat for years prior to you aquireing it and could have been exposed to moisture, etc in that time. Unless you have other reasons to suspect some other cause (severely uneven tire wear, etc) then you probably just got unlucky. Bearings are $35 and aren't that hard to install if you have a hub-tamer or similar tool. I have the one from Harbor Frieght - I think it was $79. Works fine but you need a puller to get the old outer cone off the hub which it doesn't come with. GD
If ya had an extra $500...
They do fine with 27's. My EA81's with 74 HP will turn 28's or 29's pretty easily. Plenty of people do just fine with the stock engines. I've had my wagon on 28's up to 90 MPH on the freeway. There's been plenty of people that have put the lower performing EA81 into the EA82 body to get better reliability. The biggest reason for the swap is RELIABILITY and easy maintenance. Power is a secondary benefit. If you can't do wireing then you shouldn't be doing an FI swap of any kind. If it's not done right you can end up with a frustrating mess at best or a fire hazzard at worst. GD
EGT Gauge on EJ22 Loyale Swap????
You don't need an EGT gauge. You need a tail-pipe. GD
EA81 Master Cylinder/Booster Upgrade?
Doh! Makes a nice road trip though! A1 coupling will have something. GD
2001 headgsket prices
GeneralDisorder replied to logic23's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would say that 10.2 hours is a good estimate, but ONLY for the actual head gaskets. If there are other things that are being done at the same time then more time needs to be added in. GD
Just mulling an idea over in my head here..
Wheel offset plays a part as well - the larger the offset toward the outside of the car the larger the sweep of the outside and inside edges of the tire when turning. And while the tire/wheel combo may fit, it may rub on turns. Larger tires are not always better. While they may look cool, they decrease your gearing and power, and when fit to a car with only barely enough lift to clear them they will limit suspension travel. It is much better to pick a "sensible" size of tire for the amount of lift you have rather than the largest size possible to fit. For example - a 29" or 30" tire is a much more sensible size for a 6" lift. And to practically fit a 33" tire you really need 10" to 12" of lift. GD
They make right-angle fittings for places where the bend is too tight. Baxter's should have them. GD
Knock sensor- is my mechanic trying to rip me off
GeneralDisorder replied to tjxtreme's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes - the cost of running a business is much cheaper outside of the city. It also pays to entice customers with a bit of helpful diagnostics or even a minor adjustment for free or very, very cheap. People remember that stuff and it creates an air of honesty and integrity. I do that quite a bit actually - keeps people comming back and softens the blow when I have to give them bad news in the future. We used to do that kind of thing all the time at the machinery shop I worked at - especially for customers that were frequent visitors - minor adjustments and even small repairs weren't charged if they came to the shop. GD
front wheel drive gl's?
Pretty common actually. Not desireable. GD
GeneralDisorder replied to tjxtreme's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLabor is about right since normally it doesn't really matter what they are doing they will not charge fractional hours - so they are charging the 1 hour minimum. The part cost is pretty typical - they are probably using an OEM knock sensor since they are prone to cracking and various years have been redesigned so figure they are doing a 100% markup on it (not unusual) for a real price of $62.50 - which is likely wholesale price of an OEM unit from the dealer. The computer reset..... well unfortunately not all cars are equal and while some are easily reset, other's are not. So this may be a charge the shop has adopted to cover some of the messy systems other manufacturer's use and/or to offset the cost of the expensive equipment often required to do this sort of work. Not something I have run across before but I can see how it could come about these days. All-in-all I don't think they were trying to rip you off at all - you are simply discovering the value of doing the work yourself. This stuff isn't cheap and it isn't cheap to run a shop. Even I am surprised at the size of the bill's I hand people for work I have performed - and I only charge $35 an hour and typically I don't markup parts unless I have to travel a bit to aquire them or have to pull them from a yard myself. GD
Realy Desperate now ! help !
Check for a short to the idle-cut solenoid (anti-deisel solenoid) on the front of the carb. The other symptoms sound like there could be issues with the secondary vacuum actuator or crap floating in and out of the main jets in the bowl. GD
Winch mounting
1/8" would probably bend and tear under much stress - let alone a 6000 lb line pull with a snatch block. No way I would run that anyway. It would likely hold for a half dozen recovery's and then be pretty much hosed after that much of a work-out. 1/8" is really thin stuff. I can bend and shape 1/8" flat-bar with a small hammer and an anvil - not something you want to be putting a hell of a lot of stress on. 1/4" would hold if it's gusseted properly and the thing was bolted down well. Hell it's own mounting plate is only like 3/16" by the look of it - if anything the spool would tear free of the mounting bracket before the 1/4" bolt-down plate failed . I agree that more winch than that little toy is better, but it's better than nothing at all and sometimes just a bit of pull along with the vehicles own power is all you need. You aren't likely going to yard it out of a sink-hole burried half-way up the doors but then your rig probably can't get itself that stuck in the first place unless you find a nice big pit of quick-sand to fall into . GD
ea82 ignition troubles, possible fuse prob.
What is your problem exactly? I can't understand from your post what is going on - are you having problems with it cranking or with it actually starting? If you can't crank it with the key then you have classic ignition switch problems most likely. If the problem is that it won't start then you need to find out what you are missing out of these five: Air, Fuel, Spark, Timing (ignition and valve), or Compression. GD
engine smoking
If you only replaced the PCV valve itself and didn't clean the hoses and connectors associated with the entire breather system that might still be your problem. Also replace the air filter if you haven't in a while. When they get up there in the mileage it's not uncommon to see valve stem seals start to leak a bit of oil in the cylinders so don't be terribly surprised if the PCV system clean-out doesn't completely fix it. Rings on these engines just don't wear out. You could probably do a valve stem seal replace on it with the heads still on the engine and fix the majority of it's problems. Properly maintained the EA82 can do well over 300k before some major mechanical problem claims it - usually rod bearing failure will claim them long before anything else goes. GD
Mick is running Toy suspension, etc. I doubt they would come anywhere close to fitting a Subaru suspension. GD
Any luck with Brat calipers on rockauto?
Yeah - sounds like they are fine. I'll lookup that headlight thing in a few. GD
Coil Resistance Values
Off the top of my head....... the primary winding should be around 0.75 to 1.25 Ohms or so and the secondary should probably be about 10,000 to 12,000 Ohms (somtimes more on certain engines). Those are generic numbers for most automotive coils. Usually in a bad coil you will see the secondary side partially shorted and it will read low. The correct numbers are in the partial '89 FSM sections linked at the bottom of my EA81 SPFI conversion page: http://home.comcast.net/~trilinear/EA81_SPFI.html GD
just got a 3D STD
Go for it - it's a lot of work though. And the EA82 engine is not highly regarded - most of us feel that would be a downgrade even though it's technically more HP. The timing belts, hydraulic lifters prone to ticking, etc really suck. The EA82 is a LOT wider. It is virtually impossible to service it without pulling it back out when it's installed into the EA81 body. The power steering won't work as the EA82 body is too wide to use it's cross-member. And a Loyale definitely does not have ABS. Only Legacy's and up got ABS. GD
97 Outback seeping oil
GeneralDisorder replied to johnny9k's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMuch like military equipment - as they say if you get on the bird and there isn't hydraulic fluid visibile leaking from something - get back off cause it doesn't have any left. Subaru's leak - that's pretty much their deal. If it's leaking on the exhaust it's probably something simple like valve covers, etc. Torn CV boots like to do that as well and it's worse because the CV grease is thick enough that it doesn't easily fall off or burn away quick. GD
EA81's do not have any sort of proportioning system unfortunately. GD
EA82 Carbed will it run without the computer?
The EA82 feedback computer directly controls the fuel pump relay - they do not have a seperate FPCU like the EA81 feedback system. You will have to rewire that either directly to power or through a fuel pump control unit like the non-feedback's or EA81's (EA81 feedback FPCU is the easy choice since it does not control choke power). GD
