81standard-busted transaxle
I have been having good luck with the EMPI axles. There's a place up here that carries them. They can also be found online - but I don't typically like buying axles online for the obvious warantee related issues that may crop up. GD
legacy runs for 4 days and quits HELP....
Have you checked for spark? GD
just got a 3D STD
That would cost a lot more than $300 and a LOT more time to install. Trust me on that one. You would be lucky to get a reliable motor and tranny for that price at which point it would look very nice sitting on the ground next to the car. The Weber's can be had used - this board, craigslist, and ebay are good places to look. Figure on spending about $200 once it's all said and done for a used carb and to rebuild/install it. There are TONS of threads about Weber's on your engine and the EA81 (same basic install). Just do some searches and you'll find what you need. GD
Hatch questions
Yes - the window glass is different but the door itself is the same as the Brumby/Coupe. As I recall, those are really rare in NZ and Aus. Only a very few imported - maybe for early rally racing? Though that particular model might not have been being it's a 2WD. If you need any hatch specific parts they will probably have to come from the US. GD
just got a 3D STD
I started with carbs when I was a kid. Since then I've done FI swaps on several EA81's and an EJ22 swap into a Brat. But I still love working on the Weber 32/36's and the Quadrajet on my truck. Carbs are great - not the one on your car - those are junk - but replace it with a Weber and you'll love it. GD
just got a 3D STD
Heh - I suppose I'm used to people taking my word around here. Stick around and you'll learn a LOT about that little hatch of your's. I have an '83 GL Hatch myself. It and my '91 SS are my all-time favorite models (for different reasons of course ). GD
just got a 3D STD
They can cause runnng issues - poor idling and missing problems, and they have a high rate of failure. It gets old talking about this menial stuff all the time around here. Most of us know this stuff and quite frankly we figure that if you come here for advice you'll be glad to take our combined decades of experience with these engines. If you want to experiment and find this stuff out on your own you ought to be able to do that well enough without our help. We are telling you that MANY people have solved a multitude of problems by removing brand new plugs of various brands (notably high end Bosch and other "platinum" plugs as well as low-end brands such as Champ's and Autolite's) and replacing them with a cheap set of NGK's. I run plain v-power NGK's on my 75 HP EA81's and my 200+ HP EJ22 Turbo. They never dissapoint at $2 each. I also run an NGK brand wide-band O2 system and NGK narrow-band O2 sensors - all with excelent results. GD
just got a 3D STD
Regular plugs rarely require replacement. Clean and regap is all they need on an EA pushrod engine. If it has NGK's in it now I wouldn't swap them out for Champions - pull the old plugs, file the electrodes with a point file and then properly gap them. Plugs are cheap - about $1-$2 each. Toss the Champions - they can cause issues that may not be immediately apparent. GD
So really... how much?
While he did pay for someone to strip the harness (before he enlisted my help), he did the majority of the labor himself with my supervision. I was basically unpaid - just wanted to participate from an educational perspective. Prior to me stepping in he had already bought a bunch of stuff - some of which wasn't correct or was uneccesary. His point is simply that his lack of knowledge and skills led him down the wrong path on buying parts on more than one occasion. What should be pointed out is that Jacob's Brat was built expressly for the purpose of Rally-X racing and his desire was to have it as reliable and trouble-free as possible. As such, my sugestions on how to spend his money were toward that end and to get the thing moving as quickly as possible. Lots of money went to OEM parts that may or may not have needed replacement (new O2 sensor, replace cracked knock sensor, etc) because he didn't have the time to screw around - it needed to run right the first time to make it to the first race. Even at that we had an unexpected ignitor failure that rendered it inoperable after only a single run. I think his point is that he traded money for insureing it would be right the first time and not gambling on old used parts. GD
Spark Plug and Wire advice
GeneralDisorder replied to RedRum's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNGK plugs, and wires from the dealer. Depending on if the engine is a turbo or not - I would replace them at every 60k service interval. More often on the Turbo's - they don't like large plug gaps. GD
engine swap.
GeneralDisorder replied to ellets's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe oil squirters were of dubious benefit at best. Mostly they just fall out of the crank and end up in the oil pan. The 22B impreza, which used the same block and put down 300+ HP didn't have them. There were a hedge-bet for the US market and don't really do much. The standard practice when building/rebuilding EJ22T's is to block the oil-squirt ports with set-screws. I would agree though - you don't want to pull out the turbo engine. They are excelent engines and while you could run a non-turbo at about 5 psi or less it wouldn't be as durrable as the turbo block. You will ruin the value of the car as well. Turbo's are worth several times what a non-turbo is worth and non-turbo cars are everywhere. GD
Front Hub Issue
GeneralDisorder replied to 97ws6's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt is my opinion, based on a lot of bearing work over the years, that there is no way to press out a hub and then press it back in that will not incur potential damage to the bearings. Anytime press force is transmitted through the rolling elements of the bearings you incur potential for damage. There are cases where the design of the bearing and bearing pocket, etc have enough clearance that it can be done but that is NOT the case with Subaru wheel bearings. The force needed to dislodge the hub from the bearing inner race is considereable and can only be done by using the bearing as your press adaptor... thus transmitting the full tonnage of the press through the rolling elements of the inner bearing. That is BAD and anytime a Subaru wheel bearing must be pressed out it should ALWAYS be replaced. There is no grey area here. You cannot remove a Subaru wheel bearing component without replacing them - it is not done and it should not be done. Any dealer will tell you the same. Find another shop - those guys are amatures. GD
1999 Sebring Coupe (Mitsubishi) - ignition failure
Everything went very well. He picked it up and was quite pleased. He talked to a friend of his with a '98 Sebring and he had a similar tale of woe that involved he and his wife being stranded after dinner one night - also a distributor failure and no warning at all. So he's thankful that it didn't leave his wife stranded somewhere and that I was able to get it fixed and on the road quickly and at greatly reduced cost over the dealership. He said he's sending all his friends to me...... so I guess in a way I should thank Mitsi for keeping me working GD
check engine light 89 GL
No - you do have to remove the lower portion of the kick-panel under the steering column. It's about 4 to 6 screws or those threaded push-lock deals. I just pull it and leave it off while troubleshooting, etc. Note that if you leave the panel off, when the CEL comes on durring normal driving you can just pull over and leave the engine running - the code will flash on the ECU regardless of what mode you have the test plugs in. GD
The lamp that flashes the codes is on the side of the ECU itself. Under the steering column. The white connectors are used to retrieve stored codes. The green connectors are to put the car into D-Check test mode or to set the timing. All of them are DISCONNECTED for normal operation. The other connectors in that group are for the dealership diagnostic computer. GD
Yeah - I got it fixed - not much thanks to the people on the Chrysler forum. I swear those people are a few beers short of a 6 pack. Hate having to call the guy and tell him he's got to fork out another $400 for a distributor and installation . Oh well - I guess that's the game when you own a Mitsi. 6 months ago he put in a new transmission. So at 93k miles it's eaten a tranny, radiator, and distributor. I hear these V6's are notorious for crank-walk problems as well. Yikes! GD
just got a 3D STD
Change the fuel filters first. Other than that it's probably wanting a carb refresh. Distributor cap gasket is gone or shot. Subaru's don't like them. NGK is the gold standard for Subaru engines. 100% of the members here will tell you the same thing. Yes but it won't fit your engine. Manifold is too long for the 1.6 DOHC EJ turbo engines are very difficult to fit. Suspension requires custom work - it's not bolt-in. Very few people have done either of those with an EA81 (EA71) body. Very unlikely it would be targeted for theft. Too old, too undesireable, and not 4WD. Best way to do a kill switch is to interrupt the ground signal to the fuel pump. They won't get far without gas. GD
just got a 3D STD
That stuff could have been changed over the years and obviously you have an aftermarket stereo - the stock front speakers in a DL/GL would be in the dash not the doors (where that coin pocket is near your left knee and between the dash vents above the glove box) . 1600 with a 4 speed FWD is defintely a STD layout. Looks like you don't have *actual* carpet from what I can see - it's all rubber around the shifter in that picture. That's what I'm refering to - not the floor mats. The carpet they do have doesn't fully cover all floor surfaces and it's a more industrial, less plush version. You defintely have a STD model. That's for certain. Some things have been changed/added but it's still not a DL. They are rare and were only offered for 1 or 2 years - 80 and 81 models and only on 4WD's. The advantage is in how the radio is installed but it's not as big of an issue now that non-mechanical decks are on the market that are shallow and can fit the normal console. You should only use NGK plugs. If they are some other brand pitch them. GD
If it is the transmission you are going to have a very hard time finding a replacement. Your best bet is an early 1600 5 speed instead. Should bolt up the same just with an extra gear. It's either that or swap out the engine as well since they stopped using the top-mount starter 1600's in like '82. The STD's are sweet little cars though - if you decide you can't or won't be fixing it - I might be interested in it. I've always wanted a STD platform to build a wheeler from and I could care less about the engine or transmission. I just need the shell. GD
just got a 3D STD
That's not a DL - it's a STD (standard). They were even more stripped than the DL's. Didn't even have carpet. Plain clear dome light, single speaker radio, etc, etc. And it would be a 4 speed 2WD. They did not even have 5 speed's. GD
It would not be a 5 speed unless the transmission AND the engine were swapped out to later versions. STD's came in 4 speed single range 4WD, and 4 speed 2WD - they never came with any flavor of 5 speed. GD
"Cut the blue wire!" "They're both blue wires!"
There is typically a way to shove a thin, stiff insturment down into the connectors to pop the spade or pin out of them. Just look closely and you will see how they work. You need to do some soldering most likely. The door lock indicator will be on as long as the doors aren't locked. . Normal for those cars. GD
EA81 Heater Flush
That is the size, but the stock hoses are anything but standard (they are formed hoses with special bends in them). You can just replace them with generic hose though - get about 5 feet of 5/8" heater core hose. Works fine. GD
Loyale Wheel Bearings
What you guys might be experienceing is a bad cone-washer. People beat the hell out of them trying to get the hub off and then they don't seat properly and lock down to the shaft. That causes them to shift and eventually to wear to a point where the axle nut is loose even though it was torqued to spec. If the nut comes loose again and the noise returns you are going to have to dissasemble things to inspect the hub, cone, and so forth. Replacement of the hub and cone is typical for this type of failure. Junk yard parts are usually sufficient if they aren't similarly damaged. GD
EA81 Heater Flush
You can slice the hose with a razor to get them off the nipple. But if there is that much corrosion it's time to wire-wheel those nipples and fill in any divets, etc with something like Devcon and then file it smooth so you don't have leaks in the future. Replace the hoses with generic 5/8" heater core hose. GD
