Cylinder head, head gasket questions.
The AC system does not have to be touched - just dismount the compressor from it's bracket and flip it off to the side - your manual is wrong about that. As for the head gaskets - your engine is an EA82T (T for Turbo) and is notorious for blowing head gaskets and cracking heads. While the head gaskets can be done in the car, it is easier to pull the engine. Everything you need to know about this engine is here on the forum - just do some searches for EA82T and EA82T head gasket, etc. You'll quickly find out all you need to know about them. If it's got a lot of miles and you think there may be more to the HG problem than just the gaskets (cracked heads, etc) then just get rid of the car. Those turbo engines are more trouble than the are worth and it would be better to get a non-turbo model or a first generation Legacy (EJ22). GD
HG Option ?
GeneralDisorder replied to Mike104's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo an EJ22 swap. $1000 or less for a good used engine or donor car and not that hard to swap in. More reliable with a minimal hit on the HP (30 or so). GD
EA82 Cams
Are you sure you aren't moving two teeth instead of one? It's really easy to miss a tooth. And if the teeth mesh - then there is the same number of them - ergo it shouldn't matter where the teeth are cut in relation to the cam profile. There are enough teeth that the slot's for the distributor can move fully between the increment's of the gear teeth. GD
cooling fan/water pump assembly question...
Yep - replace the pump. The bearings went out and are probably not seated in the housing anymore. You'll have to remove the timing belts and replace the pump. Don't forget to replace the heater core bypass hose when you do it. GD
Pressure plate Bolts, lock washers?
They are typically the "trapped washer" style bolt where the washer's can't come off (they spin above the threads). But yeah - lockwasher would be prefered over just a flat washer and I don't think I would use a bolt by itself. GD
Yay! I love my weber!
And it was a pleasure to work on too - simple and easy the way I like them. He has a 32/36 DGV-5A (manual choke) from carbsunlimited.com. My only complaint is that (like Redline) they send the tall filter element and those don't fit properly under the hood of non-lifted Subaru's. The other bothersome part is that the fuel inlet is on the wrong side of the carb so you have to yank that out, tap it to 1/8" NPT and install a new barb plus cap the other side off for it to look right and be routed nicely under the hood. The carb was poorly assembled (Weber's fault I'm sure) - I had to re-center the secondary butterfly as it wasn't closing completely - couldn't get a proper idle speed with the secondary slightly ajar like that. The new one I bought a few years ago had a malajusted float level - all relatively simple fixes but sad that I would have to dissasemble two brand new Weber's for adjustment right out of the box. Maybe you could blame the float on shipping but the butterfly was flat wrong. Hard to believe you can't get these in NZ? GD
Rear Main repair sleeve?
GeneralDisorder replied to Gloyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSpeedi-Sleeve's are not typically sold by application (though some are) they are a generic seal surface repair and are availible in any size you could want. You just have to get out the Mic. and find out what size you need. They are sold through industrial supply and bearing/seal houses - check with McGuire, Applied Industrial, etc. JB weld would not be the product to use, but there is a product called DevCon that could be used to repair it - but the process would be to remove the crank, fill the area and turn it on a lathe. You might get by for a short time with filling the area and then fileing and sanding it smooth but I don't think I would try it unless it were my personal vehicle. Not a professional repair. Of course if you were going to remove the crank then you would just have it spray welded and ground. GD
GeneralDisorder replied to Gloyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSpeedi-Sleeves can be had in any size you like. Just find a dealer and place your order. GD
What are the options when the rear frame rails for the 86 brat is all rotted out?
Part it. Not worth the trouble. GD
Motor verification
You have a single port - the dual port means it was either MPFI or Turbo. After 90 they didn't make either one for the Loyale. 91+ Loyale's are all SPFI thus they are all single-port. GD
Project junkyard monster! EJ22T block/EJ25 SOHC heads - advice?
The stock computer will not support much if you plan to throw big boost at it. It simply does not have the capability or programming for boost enrichment and will not "understand" positive manifold vacuum/pressure (higher than atmospheric). There are piggy-back solutions that can handle some of the issues - go over to the legacycentral board and do some searching around there. The biggest problem is that you will need larger injectors to support the boost enrichment but the computer will think you still have the stock small injectors - it will run super rich when it's not boosting. You'll want at least a wideband O2 to tune it properly and I would strongly sugest Exhaust Gas Temp sensors on both banks to monitor for a lean condition. In my opinion those three are the minimum additional gauge requirements for turbo-charging with a non-stock setup. I would also want cylinder head temp and coolant temp in accurate digital format's. GD
EA82 Electrical gremlins
Sounds like you have a dead short somewhere downstream of that black fusible link. Start pulling fuses till you lose the short on your meter. If that doesn't do it the short is on an unfused circuit (fusible link only) or before the fuse box. First thing - check the connector from the harness to the ignition switch. Those like to melt sometimes and then you can get a short as two connections touch when the plastic melts away. GD
lost key no spear any ideas how to get started??
Yeah - it's easy enough to pick GL locks. Then just take the passenger door lock cylinder to a shop and have the new keys cut from the code. GD
Key stuck in ignition
It makes *sense* that you wouldn't want the steering to lock while the car is in gear..... maybe it's just usually broken or something. It's pretty typical that you can't shift out of park when the key is not turned on and your foot isn't on the brake - there is a brake pedal interlock with the shifter. I just haven't experienced the key interlock. I avoids automatic's and most especially the 3AT in the EA82's so it's entirely possible that I have overlooked this system since it doesn't apply to my cars. GD
Intersting - I'm not aware of any interlock mechanism between the key and the shifter on the EA82's. I just went out and tried it on the '87 coupe I have (FWD Automatic) and you can turn the key off and remove it in any gear. Perhaps the Loyale's have this feature..... I don't remember having that feature on the Legacy auto I just sold either. Hhhhmmmm - maybe someone else will know. 8 years around here I've never heard of this either..... perhaps I've blocked it from my mind from hating on the automatic's so hard. Give the graphite a go and see what it does. Never a bad idea to add some graphite to your locks anyway. Can't hurt a thing. GD
The lock mechanism is likely eating itself internally and all the metal bits are loose and sometimes binding, etc. Graphite may work to free it up but it should probably be rebuilt by a smith or just replaced with a good used lock. I would get a can of the graphite that has oil in with it and see if I could get some of that to flow past the key then grab the key with pliers and work it back and forth as much as possible without breaking the key. If the key absolutely won't come out then pull the steering wheel and column covers and remove the whole lock. Take it to a smith and have the thing repaired the right way. GD
Alternator Woes
That would be the main output from the alternator most likely. That's the main supply wire to the fusible links (main junction). GD
In a bind
GeneralDisorder replied to Adamski's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you like the Forester then by all means keep it - if the engine blows up you can install an EJ22. How much of the work/maintenance are you going to be doing yourself? The head gaskets aren't a big deal if you can do them yourself - but it's $1000 to $1500 to have them done right at a shop if you can't. The '98 was the only year Forester with the DOHC phase I engine. The '99 and up have the phase II SOHC engine - much better IMO as they don't overheat unless run low on coolant - the leaks in the HG's on them are external. The phase I's also seem to have a lot of issues with piston slap (annoying, but not fatal) and quite a few people have had a rod failure - probably from being overheated due to neglected HG failure. The rear wheel bearings have issues - replace them with Legacy rear bearings to end the failures. GD
Alternator Woes
If those don't have what you need I can look in my FSM and tell you what fuses are run from the link you are having problems with. GD
I need a new carb.
None of that is a good idea - the pump being on a toggle switch is a fire hazzard in a wreck or when left on overnight - at the very least it should be on an ignition switched relay with proper fusing. And the pump should be back by the tank as they are more efficient (last longer) when they are pushing the fuel as opposed to pulling it. GD
Alternator Woes
Sounds like a bad voltage regulator to me. The blown fusible link could be a short caused by the AC from the bad VR damaging something.... you'll have to trace down the short, repair the VR, etc. Do you have an FSM? It will tell you what circuits are run by the different fusible links..... GD
New Subaru Owner with ?'s
GeneralDisorder replied to Adamski's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes - it's much easier to do the job right if you pull the section that has the sensor in it. As I said it's only a few extra minutes. This is a Subaru - not a Honda. O2 sensors in general seem to enjoy getting seriously welded to the pipe. They are notorious for this. Penetrant spray is neccesary and sometimes it's best if you can loosen the sensor when the exhaust is hot. As for the head gaskets - with a phase I EJ25 it's really only a matter of time. They had to redesign the gaskets because they just didn't hold. They can let go as early as 50k miles or as late as 200k but sadly they don't last for the life of the engine like earlier and later designs often do. Timing belt interval is 105k so you are comming up on that as noted above. When you do the belt I strongly sugest you replace the tensioner, idler and tensioner bearings, front seals, and water pump. GD
My daughter needs a Soob
GeneralDisorder replied to pyropyro's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGo for a low-mileage first-gen Legacy. That's 90 to 94. You just can't go wrong with those years. Simple, reliable, inexpensive, plentiful parts, and made before they "cost-cut" the whole lineup in '95. If she's responsible and can handle the insurance - for 4k you could likely find a 92 to 94 Turbo Touring Wagon with the EJ22T. Best. Engine. Ever. Nice ride too with leather appointments.... Stay away from phase I EJ25's and frankly might as well avoid the phase II's while you are at it (the aforementioned head gasket nightmare engines). That's pretty much everything through '02 or '03 or so. If she's set on an Outback - find a '96 with a 5 speed. Last year for the EJ22. Cheap interior like all '95+ stuff, but non-interferance EJ22 and Outback looks. Regular "L" models still got the EJ22 on into the later 90's but they became interferance in '97. Still a good engine but watch the timing belt interval. I see you are in Lapine - I'm in Portland. I have a '95 L wagon for sale very soon. 165k, EJ22, Auto, ABS, 6 speaker factory CD, AC, rear spoiler, etc. I've done a full 60k service (timing belt, all front seals, idlers/tensioner bearings, water pump, etc), and it is getting a repainted front bumper cover shortly (cosmetic damage). I was looking to get about $2500 for it. It's metallic red. GD
Caution: Lengthy EA-82 / Timing / POST
Are there any codes stored in the computer? GD
I need a new carb.
Factory pumps seem to work just fine on the Weber. Pressure regulator would do the trick as well. Regulators are cheap - like $25 to $35. Depends on the regulator. Inexpensive one's just drop the pressure. More involved unit's are capable of returning excess to the tank - usually one's that are designed to raise the pressure via a vacuum/pressure signal from the manifold (often used for forced induction). I've used it on some and not on other's. Doesn't seem to matter much either way. GD
