2
Everything posted by sumoco
Finally got some real wheels and tires put on the brat, Also half the weight and a couple inches taller than the previous rims and tires Still need to bash the corners in a little bit so j can still have full turning abilities
5 Spd conversion plus lift shifter questions
sumoco replied to iluvdrt's topic in Subaru Retrofitting
You should talk to jerry about that one, I'm about to order from him and he has to lengthen mine due to my 6 inch lift -
Glad you're gonna put that wagon to good use, sorry to hear about the rear drum issues
Problem solved, it was a mixture a of things, the alt was out of a 91 legacy with some extremely shoty wiring which then popped the 80 amp fuse on the bottom of the leg( why I couldn't see it thank you nestek). Replaced the alt, found a new alt plug from the junk yard, and bought a new fuse from oreilys. you people rock thank you for all of your help
Sorry, it doesn't turn over at all, I can hear the relay clicking but no actual turn over, it will fire up if push started though
Drove it for about an hour right after changing the timing belt, parked it, came back and no start, battery is full starter was replaced, the relay is clicking, it fired up once for a reason unknown to me. Changed all fuses (heater started working again woo!!) and checked all fusable links. What's up guys?
Also mods could you please change the title to: Sumoco's Radical BRATacular Adventure
Got so caught up in my new projects I almost forgot to update this thread. Broke a bolt taking off the torsion bar ( totally forking sucked, not a fun fix) Got the brat lifted up ( sorry for the awful picture) Put a built hi pro 390 in the back of it( let's just say don't do that)
Jus ordered every version of the 70-79 workshop manual available on eBay, (chilton,Haynes, Clymer, and the Subaru service book) when they come I will make sure to PDF them all and post them in the workshop thread
Damn, you just saved me a ton of money. This project shouldn't be as hard as I imagined then
I know it's gonna be a ton of work, but I just got my dream job with better pay than I could of even imagined, I may go with the ej22t, will the ej20t not fit? I thought it was either just as wide or a little thinner
I'm super excited scooner, I've been wanting one of these for a few years now. Also does anyone know of a good online service manual for these? Everything I find seems to just be for the 2nd gens
I don't know, they make the car look like subarus attempt at Dumbo though, and Leroy, Im planning on making the green one mine, gonna swap in a 6 speed with an earlier wrx engibe in front of it, then lift it about two inches and throw some wider wheels and tires on it, gonna make it into the most badass sleeper there ever was. The white one I'm planning on taking the small amount of parts needed to complete the green one,get it running and then give it to my mom so I don't have to deal with fixing anymore of her new American made garbage
So after weeks of talking this guy down he finally agreed to my offer of an entry level AR and 500 bucks. Neither of the wagons have battery's or fuel pumps, both are 4 speed(top mounted starter) transmission and both are in honestly pretty amazing shape, white one has a little rust on the drivers QP, but nothing insane. Green one has some beautiful paint hidden under some grime and I can't wait to buff it out ANYWAY without further adue.my new projects
