25
Everything posted by nipper
Transmission?
nipper replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
check the transmission mount and the linkages first. nipper -
Blu now has 225,000 miles and change. At 191,000 Blu got a new engine, and a new Engine temp sensor. Last week Blu started twice then immediatly stalled, twice in a row. The second time he cranked like he sounded like was out of gas. Since his fuel pump had been screaming for some time, i replaced it thinking this would solve the problem. He was also cranking a bit longer then i liked, but that went away with the used fuel pump. Today, twice in a row, Blu would fire up, then I would take my hand of the key, and he would stall. After counting to two, he fired right back up and ran like the champ he is. Since he never technically started, there is no code thrown nor stored. When he would stall, it was electrical in nature, like i shut the key off, as opposed to a stumble. Since he runs like a champ (just did NY to baltimore and back on saturday without a hitch), i am a bit short on ideas. If this was an old chrysler I would say tha ballast resistor is going bad. Any ideas, or do i just replace the crank position sensor now and cross my fingers. nipper
Doj...
nipper replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Then you were very lucky. nipper -
Doj...
Aftermarket axles suck bigtime. you need to get one from subaru or from the prefered supplier, which someone here will mention. Did you replace the springpin? nipper
