Everything posted by nipper
Lift kits
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEveryone says its time for a ute
Lift kits
wa
So ill try again since no one answered me last time
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI wish the radio had more volume.
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere are may code readers, but a lot of them dont play well with subaru. Im not looking to hack it, im looking for a really good diagnostic tool for the entre car.
2019 Subaru Outback What are we doing for code readers that play nice with Subaru and can change settings without blowing the bank.
Diagnosing center vs front differential?
nipper replied to Charlie529's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCenter diff. Front diff will roar getting louder with speed.
make fog lights stay on with high beams?
nipper replied to sirtokesalot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFog lights on with the high beams will have no visual assistance to you the driver. Your eyes focus on the brightest light, which will be the high beam. High beams defeat the purpose of fog lights.
DIscuss ... Subaru EV
https://jalopnik.com/this-is-basically-the-entire-subaru-solterra-1847769985
Recomendations for an OBD scan tool
I want one for my 2019 which will let me fiddle with the "Dealer settings" I see them now from 20 bucks to 200 bucks. I am happiest 100-200 bucks.
2001 Forester - Misfire Codes - Major Bucking
nipper replied to Tony Cortado's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou dont really need the bung adapter for that, but true.
Slow acceleration from 4k-5k
nipper replied to Jarsky's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThats why Im wondering about what happens over 5000 RPM
nipper replied to Tony Cortado's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEveryone should own a vacume gauge, cheap easy to use and often overlooked.
Are EJ2.5 SOHC Engines Prone to Overheating?
nipper replied to Mike104's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAlso a stuck thermostat, clogged or decrepid radiator, bad cap can cause over heating. Its an old car. Old cars can overheat. Just on Subarus one tends to suspect HG. Actually on any old car that can be suspect.
nipper replied to Jarsky's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWill it get over 5K rpm?
nipper replied to Tony Cortado's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI was going to say look for a common denominator, the knock sensor
still chasing a shake
nipper replied to sirtokesalot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIm having a bad allergy day so cant read through the posts, but may I suggest inspecting the universal joints iand the carrier bearing n the driveshaft? My apologies if already discussed
nipper replied to sirtokesalot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCarrier bearing.
2019 HK radio question.
I just noticed today when listening to HD Radio station 0n the lower right of the touch screen is a "button" that shows 1 2 3. You can select 1 2 or 3 by touching the button. I gather it has something to do with the HD signal, but what?
Crosstrek Hybrid
nipper replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX50 miles would be acceptable for a PHEV (the gold standard seems to be the Volt and thats in that area) but 17 why bother
Crosstrek Hybrid
nipper replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOdd I replied but it didnt post. For 36K new and only 17 miles of electric range not worth it. I looked at them and it doesnt make sense.
Hybrid Crosstrek?
I looked at them. They made a slow car reasonably faster. New ones may be worth it as they are PHEV. I've heard nothing bad about them aside from being "meh". They only have 17 miles electric only mode so "meh" especially at 36K new.
we're sorry Baja
https://www.motorbiscuit.com/we-all-owe-the-subaru-baja-a-big-apology/
2010 legacy lite combo comes on
nipper replied to gduerson's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust get a volt meter and test it yourself.
- 7 replies
- warning lights
- at oil temp
- brake
- flashing
Tagged with:
2012 Legacy repeat headlamp failure and blowout
nipper replied to Daddybob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXInspect the pigtails. Look for signs of loose, overheated or brittle wiring. The pigtails suck in these cars and lead to healight failures. Dont go just by feel of the connection.
- Engine sputtering upon acceleration , missing, etc
