Aluxes
Everything posted by Aluxes
  1. Yea I just want a little extra since Ill be running some deltas in there.
  2. Good to know, but Ill be adding delta cams too. So I think I will need some better springs.
  3. Wondering if anyone here has ever ported the ej22 single port heads? I'm getting an extra pair and I think I'm gonna give it a go, with some deltas.
  4. Will the valve train for those years work with a 97 ej22? I'm going with some delta cams and would like to upgrade the springs as well. I think that delta can supply them though. But thanks for the idea with the ej22t.
  5. Anyone know what company offers 2.2 aftermarket, or hi-rpm valve train components. I'm looking for some better valve springs. I have looked at a few, but there are all for the 25 or 2.0.
  6. Yea I was a little suspicious. Its a 97 Impreza OBS. It does have 270xxx miles on it. Would probably be a good idea to change them anyway? Im gonna get some deltas and rebuild an extra set of heads and then just swap them at some point. OEM is the way to go then. Thanks for the input!
  7. Took my subi in to the dealership for a new front axle. Was told my head gaskets are leaking?? Must be external cause I dont overheat....ever. Anyways, was wonder what the best option is for head gaskets? I have a few mods, and will be adding some deltas very soon . Are there some thinner gaskets that might improve my compression ratio? Or just some quality gaskets that will last under spirited driving? Thanks!!
  8. Clean your MAF sensor, or get a used one at a junk yard. But either way clean it. I just went through this exact same thing with my car. Got a replacement at a junkyard for 40 bucks. All better.
  9. Guess Ill go for it At the worst Ill have new coilovers!
  10. Awesome, thanks for the advice everyone!! I just went ahead and found a used oem from the local junkyard. 40 bucks. Cleaned it, re-installed and all is good. Even feels like it runs a bit better now.
  11. Well kinda both. In the winter, and for summer time four wheeling, I want to run something like 215/70/15. And for my summertime work commuting (350 miles 1 way) I would like to have something like 235/45/17.
  12. Since most coilovers dont have a big spring perch, like oem struts, can one run taller than stock tires with coilovers?
  13. My MAF sensor has taken a dump I cleaned it, didn't work. Still throwing the PO102 code. Looks like I have to get a replacement. I have a 97 OBS. Is there such thing as a performance MAF? I have a snorkus delete/CAI. I searched all the forums but didnt find too much on the subject except a MAF from a 300 ZX. If this is a performance "upgrade" is there anything else that needs to be done when using the 300 ZX Maf? Thanks
  14. Hey need some advice.....so I found a local wrecked 04 sti. Engine has 140,000. Owner sold the intake and turbo. Wondering if I can drop my 2.2 heads and intake on there and drop it right in place of my 2.2 block and just keep it n/a for now? My car is a 97 obs. Would the ecu and atock wiring work? Also the car was in a front end collision and the driver's side timing cover was crushed. Will the head be ok, or is there some type of other damage I should look for? Thanks!
  15. Plugs and wires are new. I dont think there is an exhaust blockage. Just upgraded to EL headers and a magnaflow front cat. New gaskets all the way back. Intake gasket leak is a possibility. As for it running too lean....hmmm...when I pulled off the stock exhaust manifold I did notice that the exhaust valves did look pretty white. I was kinda thinking along the line of a possible fuel delivery problem? I have not changed the fuel filter. I will do that. Perhaps the fuel pump is faulty? Like there is proper fuel pressure for the first 20 min then it drops? Is this even a possibility? Can a fuel pump have that symptom? Im replacing the front pads and rotors soon. The rear are drum so I should check them out. It is a definite possibility that one could be dragging a bit.
  16. If you want some improved performance and great sound, go with a Magnaflow. Stainless steel, sounds awesome.
  17. Hello everyone. I've got an intermittent problem with my Impreza. My 97 OBS 2.2 with a hand full of mods. At 265,000 the engine burns zero oil, no leaks, great compression. The problem is that most of the time during acceleration, whether at WOT or just normal, it feels as though something is holding the car back. The reason I know this is cause after the car sits for a few days without being driven and I take it for a drive I notice that the acceleration is smoother than usual, and the car just goes very easily. WOT at this time is awesome! Its quick and has a lot more torque, significantly more MPG, and it just purrs. But after driving, say for 10 miles or so it just kinda goes back to its old self: not as smooth acceleration, MPG goes down, less torque, and it feels like the E-brake is slightly on. Just changed the diff and manual fluids. IDK anyone got any ideas?
  18. Ok. Im having the Subaru dealer do the removal and installation. I dont have the facilities or time to do myself. Thanks for that tidbit. Ill let them know.
  19. Cool! Thanks for that. The new 5sp is from a MY 01 Impreza 2.2 and its going into MY 97 Impreza OBS. I checked the final drive ratio at https://www.dropbox.com/s/1ia75cro4n1deou/TransmissionIDChart_Public.pdf and everything matches up. Thanks for the help.
  20. What is the difference between the Impreza phase 1 and phase 2 manual? Im replacing mine, and I hope that I bought the right one.
  21. Oops my bad Didn't scroll all the way down.
  22. Just wondering...why do you want the un-equal over equal? EL headers give you more power, as where the UEL headers just give you mostly sound. If you want some good rumble put a magnaflow glass pack muffler on it. They sound great!! I have one on my 97 OBS. I also just added some EL headers and it sounds even better now and has more pull. But either way, check out sube4x4 on ebay. He makes really nice headers, EL or UEL, for a great price. Just coat them with some high heat header paint and they will last a lot longer than cheap knockoffs.
  23. This should help. It lists the MY and trans info. https://www.dropbox.com/s/1ia75cro4n1deou/TransmissionIDChart_Public.pdf
  24. Hey was wondering if anyone has any experience with Super Stable Coilovers? They are pretty cheap, price wise, but look decent. I need new struts and springs all around and these are the best price compared to new struts, tops, springs. They are adjustable, but Im not looking to lower my car, actually was originally looking to do the legacy outback strut lift. But with these coilovers there is no spring perch so looks like taller tires might fit. If taller tires do fit I could gain a little more clearance by adding some strut spacers. Any input?
