2
Everything posted by angerthis
Transmission question about 3.7 and 3.9
angerthis replied to angerthis's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ya thanks all I just got the transmission back in my car I'll go do the tire mark trick hear in a bit. This is what I have found out OK my stock 3.7 transmission no good so I put a 3.9 in it was planning on taking my 3.7 LSD and swapping it to a 3.9 but have not so I have been running around in 4wd Hi and no frunt axles the gear ratio sucked not a good set up guttlis from 1 to 2 gear. So last night I put that other transmission in did not put front axles in just to see how the car would acted in my opinion it was not guttlis like the other transmission so I don't no well see I just mite end up throwing the rear differential in my car don't want to go to 3.9 but just mite have to -
I have an 86 RX 4door it has the 3.7 gears in it the transmission went out in my car I picked up a parts car it was a loyal with a ej22 swop the rear diff is a LSD the car has rear disk braks and it did NOT have the push buttin 4WD it has 4WD low as well so I am assuming the transmission is the 3.7 but I just noticed that the axle stubs are not the same they are the smaller ones did they make a 3.7 trans with the small stubs?
good choice leaving Honda Just do not let your car get hot or u could pop a head gaskets the beast advice I can give you is have your radiator professionally cleaned by your local radiator shop
I am getting this car next week and I am cerise if any one knows a little history on this car it I a 98 outback 4" SJR lift with a 2.5 and 2.2 heads if any of u all can tell me more about it that would be great
WCSS ain't got nothin On this lol
angerthis replied to angerthis's topic in Meet n' Greet. Your USMB Welcome Center
As of now I have to call this off sorry to all that have pmed me but I had to move my shop so sadly now I have no mud pit -
Nicely put and he is right as for the why the head gasket blows my girlfriends lagasy hg went out a fu year back what I did was on the thermostat thare is a little rattler I cut it off so there is just a small little hole on the side of it to relieve any presher and remove the AC it blocks the rad from getting a good circulation of air with that being said we drove the car for 2 year with it like that and 6 more months with head stop leek in it tell I fix the HG'S . and now I always do the same thing to all my Subaru's thermostats win I get the car I have never had a problem with are bubbles in the cooling system
Is this RX still on the road if so please pm me I have ????'s I'd like to ask u about my 86 RX
Last pick no lift with factory adjustable coilovers Honda Accord coil springs in the rear 195/70R14 Middle pick same coilovers and tire wheels 2" SJR lift First pick 205/70R15 with a lot of rubing on mudflaps and plastic trim on corner of backdoors
O he does he just needs a vision in planted in that creative crazy mind of his
I'll let u know if I get more people that are interested in coming once I get a fu more people I'll talk to you all to come up with a date that will work for all of us -
A winter Wheeler in my opinion is something with a good heter lol The smallest lift with the biggest tires You don't need much suspension travel to go play in mud or snow I think that Impreza you picked up with dual range swop would be a great winter Wheeler
Wheelin with the buggy at Walker Valkey this weekend 26 sept
angerthis replied to Scott in Bellingham's topic in Off Road
so win is the next time you plan to go to WalkerVally Scott I know its the rainy season it always makes for good mud that's my favorite thing to play in -
need help with my rx turbo
angerthis replied to nduckworth33's topic in Old Gen.: 80's GL/DL/XT/Loyales...
All I have is a good cat and cross pipe of of my 86 RX 4door sedan no turbo no need for it as I went with an EJ22 I will ship make a fare offer its yours -
Well at least the mud pit part. I was thinking about having a mud pit Subaru party some time this winter/spring and was curious if there are anyone interested in coming it would be held on privit property out in a feld just out side of Bellingham WA. were my Shop is if any one would be interested in coming please let me know. The mud is sliker than snot as I like to say and lots of if too
Okay I'm starting this engine swap. I'm working on a 03 Outback 2.5 single overhead cam. The engine threw a rod i talk to a few people here on the message boards and they told me I can use any 2.5 dual overhead cam or single overhead cam. So I picked up a 2.5 dual overhead cam engine I am going to pull the heads and intake off the engine that I'm taking out of the car and I'm going to put them on the new block I just got. but as I am pulling out the engine right now I discovered there's more bell housing bolts then just 4 is that going to matter when putting the new block back in the car¿¿??
it's not the corner lights lenses that causes the bulbs to fall out the fixture that the bulb sits in the plastic brakes and that's why the bald falls out pm me your number so I can send you the picks that way
Swapping front drivetrain.
angerthis replied to wallaby's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Works great especially if you have a boom truck right Scott lol -
If you're talking about the dual headlight set up no I do not have that I have the regular GL single headlight setup 2 Parts Car to choose from if any of that helps let me know
And I just realized it was the wrong person that has the red car my bad
EA81's I believe that they are different but any EA 82's will work and yes I did mean head light bucket the wiring is slightly different you just gotta make sure you got the right ones to your high beam and for your low being because they're separate going to dual headlights If you say the front end of your EA82 is wrecked I've got a complete Parts Car if that helps I'll let the part go cheep but I am up by the Canadian border in Bellingham
Just need to find a dl parts car and get the light fixture and lights and grill They just bolt right up u can not swop out core support with out cutting and welding
It was like 23 miles down the Mount Baker Highway my RX with an EJ 2.2 in it, Honda Accord front coil springs in the rear of my RX with a 2 inch lift tows it just as good as any big truck would in fact I even tow legacies the same way with that car
