2
Everything posted by angerthis
redrilling ea82 flywheel for ej swap questions
angerthis replied to joe5's topic in Subaru Retrofitting
I just went to the hardware store bought a brand new colbalt bit and for the template I use the spacer from the automatic transmission that went between the crank and the flexplateq welded it to my ea82 flywheel And clamped it to a drill press and drilled them out with no problem Took my time at it as I spent maybe 4 hours only used one colbalt bit work perfectly grinded the spacer off after I was finished and done it was like 20 bucks with some change back from Lowes -
I agree I just pulled the multi port fuel injection engine out of my 86 rx as of right now I am in the middle of doing my own EJ swap the multi port fuel injection on a 1.8L doesn't give you that much more power as I change the block to a non turbo block and eliminated the turbo it was much more efficient but still not that much more power then the standard throttle body injection
Subie in Seattle!
angerthis replied to SeattleSitka's topic in Meet n' Greet. Your USMB Welcome Center
Well you need to find a mechanic at lees a back yard mechanic that you can trust soob'$ are eazy to work on if you know what you are doing like my self and win i get stumped i am not frayed of asking frends or USMB -
Another 2wd to four wheel conversion...
angerthis replied to mickytrus's topic in Old Gen.: 80's GL/DL/XT/Loyales...
No I just did a 92 loyal 4 door sedan 5 speed front wheel drive car Just converted it over to dual range 4WD and I had to drill out the holes as my picture shows so I can hang the rear diff as for the carrier bearing yes I cut the ones of the parts car installed the rear end and the transmission obviously first bolted the tabs to the carrier bearing lifted the drive line up and held it with a jack stand and tack weld in the tabs into place and then finished it off with the complete weld all the way around -
Is the common for a 92 EJ 2.2 liter To burn an exhaust valve on number 1 cylinder because this car I just picked up hase 0 compression i the number one cylinder And 150 and all the rest Check the timing its good just fouls out number one spark plug or is it a slim chance that valve stuck or broken spring?
Okay I just picked up a 92 Legacy Wagon And the parking lights stay on not just a couple of them all of them yes I do know about the switch on the steering column the threads I have read about it state possibly the switch itself is no good is this correct? Please let me know what else to look for before I go to tearing in to my steering column in swapping it out when it could be something super easy
Dont forget about drilling for holes to hang the rear diff i just drilled straight up into the trunk and used long bolts through the trunk to the diff brackets as you can see in the photo little dimples is where you got to drill at in the unibody -
I have had the car for Over a year now Paid $400 cash for it. It was in real bad shape When I bought it getting ready to go to the scrap yard. But a new engine not once but twice. Lots of blood sweat and beers And even more TLC than I ever thought I could put into a Subaru And it's still been the best damn little car I've ever had I will try to post as many pictures as I can the picks i have right know are of most recent i have to get in the pc for the older picks
Looking for somebody that's Familiar with the ECS system In my 86 rx turbo 4 door sedan What is happened is I'm thinking the ECS control module Has quit working bur I have spark but when you turn the ignition on there's no blinking light on the ECS module so if you're familiar with this system I would like to actually call you and talk to you in person my words on pen and paper don't work for me half the time so if you could PM me with a contact that I can get ahold of you at or I can give you my number it would be much appreciated thank you have a good day
where do these gaskets go?
angerthis replied to angerthis's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Oh yeah I knew that Like I said I was brain farting the older Impreza they had the 1.8 right I have never seen an XT with that motor I've seen them with the EA82 to multiple fuel injected Like what's in my 86 rx -
I must be brain farting What is spider manifold? Is that just a fancy way of saying multiport fuel injection Like my turbo EA82 is -
I thought the TBI Gasket was more like an o-ring type of material? I see if anybody else can play the guessing game lol -
Okay I'm just curious I'm almost certain I don't need these for my RX Turbo EA82 I'm just curious I'm not even familiar with these gaskets on any ea82 engine If you could tell me where they going what they are that would be awesome thank you guys
Thanks man that's all I need to know
I am just about ready to rebuild my engine Ea 82 Was curious on which of the two valve stem seals Goes where There is two different sizes and so I assume one is for Intake the other is for exhaust So which one is for which part?
EA-82 cam rockers, and oil pump
angerthis replied to Mack Truck's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Where in the heck did you find lifters for 16 dollars a piece? I know the local O'Reilly wanted like 37 a piece and my dealership told me 80 for 4
