moshem74
Everything posted by moshem74
  1. .045 and I'm stickin to it.... Wider the gap, longer the spark, the better the combustion you are wrong my friend....the smaller the gap is - its better: 0.7mm is the best for your car. you can open google ans search for spark plugs gap and read some articals about it....
  2. so...what do you say? it worth ? it will make the engine work better? thank you?
  3. hi to all does anyone knows if its a good motor oil (10w40), i mean this company product http://www.royalpurple.com/index.html http://www.royalpurple.com/techa/whyrpa.html http://www.royalpurple.com/techrp/summary.html http://www.royalpurple.com/arta/arta.html is it whrilly good as it look like?...... does anyone use this kind of oil for the subaru loyale? i'm using till now castrol 10w40, is this royalpurple better then castrol? (it cost here 1.5 times then castrol), is it worth it? thank you all moshe.
  4. hi to all. i have a subaru leone dl automatic. latly i got a steering wheel of subaru loyale gl-10 year 85 that have a 2 push bottems on its right side-it saphose to work as crose control, i wand to change my steering wheel to the gl-10 one...i took out mine and the new one fit to its place but on its back side it have some holse for connecting and when im turning the steering wheel to one side -its stuck and dont want to move, also the horn doesnt work. how can i make it work, only the horn! does anyone did that before? changing from dl-gl steering wheel to an gl-10 steering wheel? the one that i have of the gl-10, its a new one , its looks just great....how can i make it work? thank you all, i hope you can help me with any halp thet you can thank you. moshe.
  5. hi you are right: 1600-1800-1800turbo ....ok now?
  6. hi where i can order an open filter to the stock air box for subaru leone 1600cc? can anyone help me with this thing...? and another thing, how can it be that the original Rear Muffler fits for 1300cc-1600cc-1800cc-1800turbo ? it's mean that for subaru engine 1300-1600 it's like an open Rear Muffler if its fits for 1800turbono? look here: http://cgi.ebay.com/ebaymotors/ws/e...&category=33636
  7. hi you need to replace your radiator - i had the same problem .
  8. hi. if ill make some holes in the stock air filter box,will it make more air to come in or will help the engine to suck more air from outside? will it make any deferent? and another thing , frome where i can order an stock open filter for subar leone 1.6L - from what site...i need a link. thank you all. moshe.
  9. http://www.angelfire.com/sc/cosmo/MR2_PCV2.html
  10. with the k&n open filter.... http://www.electricsupercharger.com/ thank you all.
  11. hi i had the same problem, listen: 1. change your gear oil + filter 2.take out the governer,clean it , take some silikon and new 3 screws and put it back (close it that it will be close complitly,close it very well, even for air - like in vacum). good luck.
  12. what is this thing? http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7958062693&category=33597 or this one: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7958019834&category=33598 does it feet to subaru dl with ccarburator? thank you all for your fast answer. moshe.
  13. hi how much power the air condition takes? i'm talking about subaru leone 'with original air condition, how much power does it takes from the engine without operate it, i mean , just when the all air system is under the hood-connecting to the engine with belt. does someone take out all the air condition system out from the engine? does it makes any different? thank you all for your fast answer. moshe.
  14. hi you need to clean your carb...dont use the spray, take it to a place that will take the carb out of the car ,and clean it. have a nice day. moshe.
  15. hi what is a finer filter,and is it make any diferent? can i add something like this before the carb(the same as before the feul pump? Typical External Fuel Filter
  16. hi i took my car to aplace to clean the carb, now the car its like something alse...driving a lot better, and i mean a lot.!!! i tought maby to add another fuel filter, in that place they told me it's good to add one. i want to add another fuel filter before the carb,the gas that you put in the gas station is not so clean and also the car it's old so maby to add an extra fuel filter will clean better the gas that comming into the carb. now, will it effect the feul pressure? i mean will it effect the fuel pump and will make the pressure less or harm with any way the feul pump because its like something that stop the fuel pressure in some way , no? thank you all for your fast answer. moshe.
  17. hi you can add METHANOL , it will give you the same thing... http://www.green-trust.org/2000/biofuel/dwg/dwgch3.htm and it cost less then fuel.... have a nice day. moshe.
  18. hi it doesnt matter what kind of oil do i use? if im using half syntetic or full syntetic,and not the cheap oil , the best one , it wont hold for more time? thank you all for your fast answer. moshe.
  19. hi what is the best for changing motor oil, i use 10w40 castrol ,and my engine is in perfect condition,120000km year 1993 EA71 , is it 3 -4 or 6 mounths? thank you all. moshe.
  20. hi its not correct ,look here: http://www.corollaperformance.com/TechInfo/sparkplugs.html also i asked some peole who work in the car improve performance and i've been told that if you want more powerfull spark-make the gap smaller: If you tend to just drive in traffic or have a light foot, go ahead and open up the gap a couple of thousandths. You will give away some wide open performance (hey, it may do fine for you), but you will gain some gas mileage (disclaimer: your mileage WILL vary – I am not promising any numbers!). For those who live by the millisecond of a quarter mile, I would be curious to see what happens if you stayed stock or even at the low end of the spectrum (say 0.028", or even 0.026"?!?). It should help with the reliability of ignition at WOT which would give more power. As for temperature rating, again if the stock heat rating plugs appear clean and unfouled for your driving conditions, then try a lower heat rating. Remember to check your plugs frequently to see if they are fouling or still running clean. The basic recommendation is that experimentation will lead to the preferred type and setting. If you do not want to bother changing these many plugs, just use the manufacturer's setting – they will not let you down.
  21. its not true....look here: if you want more performance...you should make the gap smaller: http://www.corollaperformance.com/TechInfo/sparkplugs.html have a nice day.
  22. the bigger is better or what? i have an aftermarket coil + msd ignition stakker 7000pn(spark amplifire)...do i need to make the gap bigger? is it make any different? thank you all. mosh.
  23. hi what are the best spark plugs for leone from this list, this is the site that i order from, what are the best ones...? this is the link: http://www.sparkplugs.com/results_app.asp?productTypeID=1&AAIA=1268456 how much should be the center electroda ? is 0.044" is the best of lower? in mm....how much should be? meny people told me diferent sizes...from 11m to 7mm , what is the best for better performance? thank you all for your fast answer. moshe.
  24. hi it happhand to me also .....some mounths ago.... you have too much oil, you need to chack your oil level and see if you have too much, you need to take out some... have a nice day. moshe.
