dp213
2
Everything posted by dp213
Atf temp light
dp213 replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I pulled the pan yesterday and found a single blue wire broke. I was able to but splice it and all is good now. Thanks -
Atf temp light
Here's a stupid thought, when I pulled the radiator not once but twice, I lost about a quart of tranny fluid total. I forgot to add some before starting it. Would that possibly throw a code -
Atf temp light
Forget the code number but it said valve pump I believe and speedo works -
Atf temp light
No, the motor went right in within 1/8" before I used bolts -
When you replaced the battery, there is a ground wire from the negative post to the fender wall. Mine came loose at the fender and caused me issues.
- 15 replies
- 1
I am trying to get the ac out if the way in a 2002 Wrx so I can pull the motor. The problem I have is a small rigid tube sticking up in the way of the back bottom bolt. I can't get anything on that bolt. What is the tube? It stops and is capped about an inch in front of the bolt and how can I get that bolt off. Thanks Dp213
Frankenmotor
If I go with option 1 is it a non interference motor -
OK, I know it been beat like a dead horse, but I have a couple thoughts and questions. I am getting ready to build one and have a couple ideas, maybe. I'm building this for a 95 legacy 5 speed. Option 1, if I use a 2.5 phase 2 block from a 2002 with 95 2.2 heads, is it an interference or non interference motor? Option 2, I have a new set of 2002 Wrx dual cam 2.0 heads. Would that be a good combo with a 2.5 motor? I know I would have to change the ECU and wiring and I'm fine with that if its a better option. Or should I just be smart and do a basic 2.5 with my 2.2 heads? Any input would be welcomed. Thanks, Dp213
Engine swap
I can't find a 99 phase 2 motor anywhere local. Would any other motor be a direct swap
