dp213
2
Everything posted by dp213
I put a 93 2.2 in a 99 outback this week. I used an intake from a 96 2.2. Everything is done and it runs great, but it threw the p0106 code. The 99 had a map sensor sensor and only 1 tube running to the intake. The 96 intake had 2 tubes running to the map sensor. As it sits I have put the map sensor from the 96 in to accommodate both tubes. Should I put the 99 map back in and plug off 1 of the tubes. About 8 of these type of swaps and this is the first time I have ran into this. Any help would be great. Thanks Dp
I have done a lot of motor swaps, but have not done head gaskets on one. I took heads from a 2000 outback to a machine shop to be surfaced and have valves done. Today I got the heads back and they are KIND OF done. What I mean is, they did the surface and valves, but when I picked them up they were not completely reassembled. I have about a 1" thick piece to be put back on (which looks like it needs a gasket under it) and then I have to put the cams back together. I like doing new things, but I have not torn heads apart before, let alone reassembled them. Is it actually a gasket I need, or is it an annorobic sealer. Also do I need to put a grease on the races where the cam sits. Any little tips would help. If I can figure these heads out, I do live in the Subaru capital of America. I would rather figure this out, because the older 2.2 motors for the phase 1 swaps are getting hard to find.
2000 outback
dp213 replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Thank you. I have a couple laying around. What head gaskets? Phase 2 2.2, phase 1 2.5 -
2000 outback
By the way, the 99 block was from an outback, so it was kinda the phase 1 phase 2 motor they did in 99 -
So I bought a 2000 outback for my son real cheap ($200). The engine is done, can't turn it by hand. I'm looking to do a cheap as possible replacement. So my question is this. Can I use the 99 2.5 block and 2.2 phase 2 heads that are sitting in my shop and make it work. The block j know is good and the heads are brand new. I know I have to change the exhaust, but will this combo work? Thanks Dp213
97 outback
What turbo motor did they use for the JDM imports in 97. -
The transmission service should be pretty easy. The tranny has a drain plug for draining. You will need a new washer for the drain plug, same one as used on oil drain plug. The tranny probably also has an external screw on filter. It looks like an oil filter and it's located on the drivers side of the tranny. Add about 4.5 quarts of tranny fluid and check the level. I'm not positive about the e brake. On my 2000 I had the same problem and replaced the e brake shoes and that fixed it.
Carpet kits
I guess I will just have to try it. I will post the outcome when I do it. Might be a week or 2, but I will let you know. -
I have done a similar work around as the above link on a few cars and it works perfect. The only thing I did different is that I used the brass egr tube and cut it about 2" after the first bend from the intake and turned the tube to point at the passenger side then just put a piece of hose on that with a hose clamp
Are the carbureted motors changeable to spfi
The intake probably is, I just don't know about the heads
So I have a line on a mpfi motor from a 1989 xt. It has low miles on it, but he said it dies when in get warmed up. Will the spfi intake from the 90 loyale work on that motor
Wow, auto correct sucks????. That was supposed to say, or even a closer comparison
Ot even a user comparison is using a 93 ej22 and putting the 95 ej22 intake on it.
Very cool, so it's basically like putting a 95 ej22 in place of a 98 ej25, which is a very easy swap that I have done many times.
I need to replace an engine in a 90 loyale. Someone else tore the motor apart and I don't have the intake. What I'm wondering is, are the TBI mfi long blocks interchangeable? From what I have read the car could have either one. I will have the original intake tomorrow, I just need to find a good motor and am hoping I can get either long block and use it. Thanks Dp
