44
Everything posted by brus brother
Well is there any rust i.e. is the car now useful only as a planter? So far, she "gave" you a free car that you may need to dispose of. Tell us more about the interior, exterior and the car's general condition. What are your skills or interests in getting down and dirty with this car. You may be able to part out the car on this website if it isn't reasonable for you to repair. You might want to "store" this gift in the woman's yard until you figure out which way to go.
Several years ago, a friend returned a car under the lemon law after Subaru failed to remedy the same situation. Get it all documented. It sounds like you are not willing to own the "runt" of the litter. Make them change the CAT, O2 sensor, front bumper, CD player (if equipped), whatever, to make your car perform as any other on the lot. Alternatively, park your car outside the dealership on any given day with a sign in the window advertising the aforementioned aromas.
The January 05 issue Automobile Magazine describes in detail this nifty cross of the 3.0 liter boxer 6 from the OB with Impreza STi based 6 speed shifter, inverted front struts similar to STi as an uprated suspension, Bilstein dampers and 18 inch wheels, 247 hp, 0-60 in 6.5 seconds tops out at 150 mph. Spec B package is $3000 more than the 3.0R in Japan. Most of the above means little to me as I don't really speak "car" and I don't speak Japanese either. Apparently David Davis, the founder, formerly of Car and Driver , is a big fan of Subes as there are several articles of praise in the issue. He is quoted as saying "If Henry Ford had lived to enjoy the Reagan years, his car of chocie would have been a Subaru". When Davis left C and D in 85 to start his magazine, the naysayers derisively said his magazine would probably be about Mercedes and Subarus... not bad company. Buy the issue or steal the magazine from a doctor's office.
The apparent "fix" is to pinch the top of the triangle of the gusset while the window is down. The apparent cause of the problem is that since the window is without a frame on the door, when opening or closing the door, grabbing or pushing the glass is the culprit. It is a rather long lever arm that you create and you supposedly can twist the gusset sufficiently to cause the distortion. Also, if you find yourself in a tight parking situation and have to squeeze your body past the door, the effect is the same in distorting the gusset.
Hello
brus brother replied to 7thSubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Well the title "new user" under your member name seems like a misnomer. -
And the answer is....Today, after 51/2 years of complaining, a clever tech pulled the covers off and checked the cam timing. It was off by one tooth. The pinging is much reduced but not completely gone. I had them change the timing belt early at 72K since they were in there and it only cost me $40 for the belt. Dealer suggests injector cleaning. Is there a DIY version or is the $129 dealer service worth the bucks? I have used BG44K every 30K but will this clean the injectors as well as the other service?
They changed the knock sensor today... no change. I showed the tech Blitz's IAT sensor option and while it is a different variety, it apparently chacked out. As far as my grammer, she and my grampa have been out of warranty for many years. Tomorrow they'll pull off the timing covers and check the cam timing.
My 90 Loyale had the usual rust as a result of dirt and debris collecting in the space behind the front fender that you can see when the door is open. I first detected the problem area through a rust hole from the outside. I have since had occasion to check the same area on my 2000 Legacy GT and sure enough, tons of road sand, mixed with salt here in NE. I flushed the area out with a garden hose while the nose of the car was pointed uphill. If the AWD ever fails, I know where I can get some sand for emergency traction. Another great idea from SOA.
http://www.ultimatesubaru.org/forum/showthread.php?t=1138&highlight=Ccr+engine CCR Engines Inc. has a good rep on this site for the dollar range you mentioned and you get a totally rebuilt engine for probably less than what you were quoted. You get a 36K/3 year warranty on the engine top to bottom. The above link has opinions on merit of rebuild or HG alone.
On my 90 Loyale, aside from the usual front end seal leaks, there were leaks from the valve cover gaskets and the little rubber grommets where the bolts atach the valve covers to the engines. It seems Subarus use leaking oil as somewhat crude anti-rust program. You can also earn some spare cash resealing asphalt driveways with your leaking car.
SEARCH function is is the gray bar at the top of this site, next to "new posts" and "quick links". Click on Search and a window will open below. Put in your key word and it will display results. My understanding of the oil leak is that it is a rear engine seal and is unrelated to the front of the engine where timing belts would be replaced. Good luck
I think I made it clear that the car has behaved this way from day one, so the various treatments meant to eliminate carbon etc. wouldn't have come to play with a brand new engine. The car has new plugs and the recommended gas line additive/cleaner BG44K. It behaves well when it is very cold outside. It is noticeably worse with warmer weather and high humidity(low air pressure?). Tech feels it is something mechanical. All guesses accepted and I will report back with any findings. PS I had originally been running 91 octane but ran into other owners who had no problem with 87 octane and since I'm still under warranty, I figured that I'd let them try and figure why the runt of the litter is in my driveway.
