Everything posted by brus brother
05 Impreza Speedo, Trans, timing Belt
brus brother replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMake an appointment with Google for repairs? Seriously, do the same search "Subaru loss of power, switch to neutral back to drive and resolves" for a deeper dive. AI Overview: A Subaru losing power while driving but recovering when shifted to neutral and back to drive (N-D reset) usually indicates a transmission control module (TCM) glitch, a faulty inhibitor/neutral safety switch, or a torque converter solenoid issue. This action effectively resets the transmission's active gear command.
00 Outback legacy..Anyone know what this part is and if it is replaceable?
brus brother replied to DarkenLX's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXColorado time machine?
Stumped on my highschool daughters first car - 2008 Legacy can't go up hills and has no power
brus brother replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhoah an educational "free ride" and a Subaru rust free ride! Graduating debt free is liberating. Congrats to your daughter.
brus brother replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had an 05 Outback and in chasing the dreaded P0420, I was "thrilled" to discover that there were 3 cats and 5 oxygen sensors. Somewhere there is a Subaru engineer busting a gut with laughter... and a parts manager handsomely salaried.
brus brother replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI just spoke with buddy and he reminded me that he used 2 vacuums. One blowing in and one sucking out the other end. Save the pieces and find a recycler.
brus brother replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTry just banging on it and dumping out the broken bits.
brus brother replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRuns perfect albeit on the loud side. VAROOOM!!!
brus brother replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPossibly clogged cat converter(s)? Broken bit's of the honeycomb will follow gravity and clog the exhaust when car is heading up hill. The noise will startle the neighbors but if you can disconnect the cat(s) and test drive, that will help in diagnosing this issue. Buddy had this issue and just emptied the broken bits and drove on.
- Why do I steadily lose power in 5th?
Replaced evaporative canister solenoid, catalytic converter code off now too
brus brother replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid the p0420 code go off by itself or did you reset it? Keep us posted if it returns.
brus brother replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhat was your catalytic code? was it the P0420
Anyone own a Baja and at least one 2000-04 Legacy?
brus brother replied to moosens's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXVery clever. So rather than continue to reduce your hoarded inventory of Subie parts, you intend on hiding it in plain sight from your wife in the form of a Baja?
2000 Legacy/Outback driveshaft for AT - unavailable except for more than $600!?
brus brother replied to Boringchuck's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI bought an aftermarket shaft for my 05 (I think) now sold that worked out just fine. I will search my posts here to see what other info I may have posted. check out Parts Geek. They have some for Auto at $300+ https://www.partsgeek.com/catalog/2000/subaru/outback/driveshaft_-ar-_axle/drive_shaft.html?rp=driveshaft
P0638 in a 2005 Outback
brus brother replied to Ravenwoods's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhave a look here: https://www.icarsoft.com/Article/s-269-269.html a reasoned step-wise diagnosis and treatment for your code
Vibration at 25-35mph and light load and at highway speeds - getting worse!
brus brother replied to Boringchuck's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo you feel it under the seat when the vibration occurs. Something similar in mine turned out to be drive shaft. Got an aftermarket since the u-joint was not replaceable and all was good.
Retrain Window Switches After New Battery Install
- Why is there oil on top of the engine?
if near front ps fluid?- After brake job, electronic parking brake set, idiot lights ALL lit up, car immobile
brus brother replied to craigmcd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWould love to hear from anyone who did rear brakes on 2018+ Want to know how far up Shitz Creek I'll be heading before starting out if this ordeal can be expected (or avoided.)- Idiot Proof TB Repacement?
- Tach and speedometer stopped working (intermittently) yesterday
brus brother replied to mickytrus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX2 years ago I was in Lake Placid NY overnight -30F Alternator screamed like a banshee in the morning. Went into local Autozone and clerk said to wait til noon when temps return to tolerable. Followed his advice and all was good after a late breakfast. Before jumping to conclusions, I suggest pancakes and bacon.- 2001 outback cant get rear tow right
From your title, I thought "Tow" was referencing towing the car not "Toe" 😀- Shaking at high speed - 2009 Impreza
brus brother replied to DaveD's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdrive shaft U joint?- 2008 OB 3.0, Sudden onset of bad misfires
brus brother replied to Hocrest's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy 2008 ran like crap after high humidity/cool conditions. Was ready to change out coil pack and instead dried out the interior contacts of the pack where the wires plug in and sprayed with WD40 and all was well. Have you tried spraying water around the wires when dark outside with car running to see if there are any sparkly light shows? In my case, I didn't have the light show but the rough running was related to the damp coil pack. Fingers crossed for something simple.- Strange Electrical Issue
brus brother replied to Daskuppler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXalternator?- Exhaust Pipe Rusted Out Downstream of Resonator Replacement Options
brus brother replied to Daskuppler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI just packed the hole. No mesh. My repair was in the crotch of a y as the exhaust splits to 2 mufflers. Just checked out of curiosity and it is still holding strong. Couldn't hurt to create a "wrap" of the edges of the hole where some material is on the inside and some on the outside and then fill in the middle. Or tuck a tiny piece of copper mesh on the inside slathered with the sealant. Attach and use a piece of dental floss or thin string to pull the patch up against the inner wall and then slather on a coat on the exterior surface. The area I worked on wasn't conducive to cleaning so I just relied on the silicone to do its best. - Why is there oil on top of the engine?
