montana tom
    12
Everything posted by montana tom
  1. Hard to say for sure but it sounds like your new starter is N/G ! your old starter most likely could have been easily repaired but ... I suspect that you had to turn it in for a core... I have heard of adding a relay but have never had to. Take out that new one and using jumper cables and a screw driver test it on the bench . Pos cable + battery to pos starter connection , neg cable -bat to housing of starter( at bolt holes) use screw driver to jump from solenoid to + battery terminal . A good starter should turn over as soon as you make contact... if not ... big spark.... its bad ,take it back and get another.
  2. Could be electrical... but look at the timing belt first. A sudden no start on the 2.2 with fast cranking is usually a timing belt. That engine is a non interference motor so not a problem if the belt has broken/slipped. Pull the end timing cover off (3, 10mm bolts) and check belt for condition and tightness... you won't have any doubt if the belt is broken .
  3. My small town tire guy takes a grinder to the rims every time he dismounts an alloy rim , subaru's especially seem prone to slow leaks at the bead. Two minutes with the grinder on every rim pays off for him with less comeback repairs and happy customers . I'm sure that if I had a can of clear coat he would take the time to spray and dry them for me. A large tire franchize may not offer service like this ... (liability)... i'm sure they would be glad to sell you new rims though.
  4. Rooster2, both my 00 & 01 as well as my 94 have needed lube inside. That one pivot bracket seems to rust up quickly. This new one (ha ha its 2015 now) well this 08 one still has a standard latch on the back even though they removed the key switch. But the mechanism is flawless, seems the actuator decided today was the day to go.So darn good thing they put that lever inside or it would be a bugger to access . My buddys 2013 only has an electric soft touch button ! no mechanical latch at all ! Hope i'm not around when that one quits working. Oh new switch just over $50 online.
  5. Ok , update, seems subi must expect the electric lock to fail... they put a manual over ride switch right on the electric switch. Under the little 3x2 plastic cap on the right side, is a white plastic lever , moving this lever puts the door in a permanent unlock position. Then you can open the hatch to replace the electric unit inside. Flipping that switch back while the hatch is open will alow the hatch to lock but to unlock it you must crawl into the back and flip switch to manual again . I should mention that subaru, in their image of a wonderful electric world , completely removed the key switch !!! Going online now to price out that electric switch.
  6. 2008 obw , hatch worked normal ,went to town , hatch won't unlock , with remote or at drivers door , all other locks work normal ? Suggestions ?
  7. EBay - look for vent visors. They stick on .I have them on my 00-01 obw also have them on a 13 obw Love them !!! No drip on your arm or the window controllers.
  8. Hi terry; here is the name & number of the japanese importer that I use , it's in coeur d' alene Idaho. 800-552-1595. I have installed over 2 dozen of these (not all subi) had one motor self destruct and they replaced it instantly no questions asked. Give them a call I think they have outlets everywhere. They are called "Foreign Engines" japanese specialists . They do ship anywhere. A wrecked low mile car is always a good choice if you can find one. Keep looking one will turn up!
  9. Wow, an 012 dropping a valve ! Other than my EA 71 race engine, I have never seen a subi drop a valve (i'm sure it has happened , just not much) Break a belt and bend them happens all the time ,BUT this is a big time factory screwup ! After its been fixed you should be fine. Maybe this was a monday morning hangover induced engine build .
  10. Hey michael; I never used timesert, always helicoil, but i'm old school, you know, can't teach an old dog a new trick ... unless he wants (HAS ) to ! The coolant trick could help the next guy that isn't familiar. Good Luck
  11. If its rusted thru then have it replaced , if the metal is sound then have somebody remove it and either braze or wire feed weld it. JB weld could work in the short term but you need a better fix , if you want to trust your car. The real question would be how did a hole get in this pipe ? If its rusted is it from the inside ? like water and no antifreeze ? or from outside like road salt making its way up there ? Or did you bang it somehow ? Fix the cause and the problem won't return !
  12. Scat; Surprised you tried this without taking the 2 motor mount nuts off ! You already have the exhaust down and out of the way . One 14mm nut on each side for the motor mounts and one 14mm bolt & nut on the pitch stopper. raise it up and you will have a much easier time of it. Like 1982 said let the bolts ride in the head as you remove or replace makes life a little easier !
  13. 30K on a 2008 wow low milage. One thing to check would be the support link on the top of the motor , could have come loose, could have a bad bushing (but i haven't seen that ) Such low miles for anything to go bad. This could be a tough one to diagnose remotely. Kinda need to jack it up and crawl around while the noise is happening. One thing ,have your front axles been changed ? possibly with aftermarket parts ? I have always used aftermarket axles BUT ... on this forum i am reading of people with problems using them. Good Luck let us know what gets discovered.
  14. The dealer does stock this bolt and replacing it with new is definitely the way to go! However it will still be stuck even after cutting , usually in the rubber bushings on the links. No good way i've found to remove it but twisting , heating (carefully) swearing loudly, bloody knuckles it is a piss poor set up that they changed on the 2000 up obw but not on the impreza ??? WHY !!!!!
  15. Michael; Yes straight is important !!! lol This happens to aluminum motors. Take your time , use locktite red on your helicoil. Nicholi mentioned proper filling of the system. Here's how , After rad is installed and all the connections except the upper hose are attached and tight. Connect upper hose to engine (with clamp on ) pour your anti freeze directly into the upper hose keep going untill water is staying in the upper hose, quickly swing it over and attach to radiator. Now fill the radiator, there is an air bleeder valve on the pas side top of radiator. I don't use it ... as you get water to show up at the rad cap gently squeeze the upper hose burping the air out . Once its full put the cap on and start motor and turn on the heater inside. Once you get heat in the cab and do your test drive to check things out . Park the car let it cool off then double check your radiator level and overflow level. Your Done... A new subi mechanic is born!
  16. Michael: Bummer ! bolt size is 10 x 1.25 Can't believe that you haven't removed the radiator, makes everything easier, and there is nothing to it. Unplug the two fans, Should be able to leave them bolted to the rad. remove the overflow tank if you haven't already, if is an automatic then disconnect the rubber lines to the tranny. Upper / lower radiator hose then 2 bolts on top should do it . I have only used helicoil before, always worked good for me , but there may be newer better stuff out there that I haven't tried yet. In hindsight maybe... 30" 1/2" drive BREAKER BAR was a little big... lol oh well ...drill it , tap it and carry on.
  17. I have never had any luck with those bubble levels ... I just park level facing a blank wall and put them where I think they should be. The next time you drive in the fog you will know if you got them correct.
  18. OMG ! Thank you... My 01 OBW limited has had passenger side wind noise since the day I got it . Driving my wife crazy , I never would have thought of pushing out to make that darn window seal !!! Took all of 2 minutes ! FIXED ! this forum is so cool ! Now if I could magically get the roof body seam to seal itself without pulling the headliner...
  19. Hey Rock; 120 # on a turbo motor is not that bad... especially with 220,000 , how does it run ? Sell the ej 22 and use the $ to max out the turbo.
  20. It happens to those hubs when they get old. I have bought several cars over the years that were stripped just like that . They were a great find ... buy them dirt cheap throw on a hub and away you go. Is it caused by a loose nut ? I don't think so, to much spline contact. I think they get old and crystalize and one day under load "POP" sound familiar?
  21. Lol; Ok If.. fluid was added by mistake and it does happen, even to a certified mechanic or a teenager at a quick lube. You need to change that oil again very soon!! Was your radiator yucky also ? If so it needs flushing, repeatedly. If no oil in radiator ,that's a good sign. If you check your oil every time you can and it stays clean..and your car is not overheating... maybe it will be ok... Change that oil again SOON
  22. Terry ; Are other people adding fluids to your car ? The water reservoir is near the oil fill but... 1/2 mile 3 days a week... exercise ? bicycle ? shoe leather ? lol sorry couldn't help myself. SOMEBODY ?... could have added a wrong fluid. No clear easy way to check gaskets , but as bad as yours was, if it is the gaskets you will know quickly. Be warned every time you start it, if there is coolant in the oil you WILL be damaging your bearings.
  23. Scooner is correct on both points ! A brat with a 2.2 5 speed dual range would be more fun than almost anything ... And a EA 81 will drop in and give you a little more power. Old subi's need to be wrapped up to perform well , that means 3000 rpm and up, all the time if you want it to get out of its own way. I ran an EA 71 on a high bank dirt track and was holding my own against the 4cly ford motors that had every part / trick known to man to use and my little 1600 4wd could kick their butts on the corners, sadly on the straights they did it to me... I did get a 2.2 with a 2wd auto trans put in the car (custom intake to run a holley carb and a dist from a (get this a FORD) But alas they sold and then closed our track... So Sad , best fun I had in years but a great big black hole to pour money into also. Scooner; the 2.2 did sit in a 1980 hatchback just fine problems came with the tranny and building axles with doj,s from tranny year and cv,s from older year. Dont know about rear driveline as I only had a 2wd tranny to play with.
  24. If you are hoping for head gaskets only, then before you even start it again drain out the milk shake oil and change the filter, add as cheap an oil as you can buy and still try not to run it any more than you have to. Make sure the mechanic uses subaru head gaskets only. I still think that if you check, somewhere nearby (Chicago?) there will be a company importing used take out Japanese engines , around here they are called (foreign engines ) Good used 30,000 mile take out motors.
