cookie
Everything posted by cookie
I like 2004 and up but I have a 99 myself. Your car is getting a bit long in the tooth. If everything else is fine I would be tempted to do a major service and either give it head gaskets or plan on keeping a few bucks for them. Every mile you get is free at this age I figure. I did big time service on my 99 Forester a couple years ago at 90,000 miles and at over 122,000 it is better than it was a few years ago and trouble free. At this point it looks like it will hit 200,000 and my smile gets bigger every mile.
I hate to discourage somebody from a purchase in Humbolt right after harvest time but omce donw to SF. We have a ton here. Look on Craigslist. A 99 Outback has a phase 1 head gasket eater in it. 200 should have a phase 2 which is a better engine. If you can't trust them on mileage how can you trust them for the engine?
Code P0420
cookie replied to rugbyben's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Only your Subaru dealer can help you with warranty. I hope they are reasonable because it is a very old car. If they turn you down ask to talk to a district rep. -
Emergency Help
cookie replied to PeterD's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
If Jiffy lube just worked on it and she is on the way home check to see if the oil is way overfilled and the tranny is empty. -
It is pretty likely to be piston slap. It tends to increase with engine wear and last winter the anti-slap coating may have still been on your pistons. My forester does the same thing only it does not last very long as its not that cold here. Adding a heavier oil helped mine quiet down except for the first morning warm up. If you want to you can adjust the valves easily, but if the mechanic did not offer to do that for you its probably not the valves. If you can make a customer happy with a valve adjustment you would do it. Piston slap is another major step as it requires replacement of the block and then might only cure it for a while. Subaru does have another piston kit but my dealer does not service them that way.
Code P0420
That would be great if you can get it done on warranty! I suspect my cats are tired too but I know 122,000 is a bit over. -
Man that sure would put oil past the valves like seals. You ought to be able to test the pcv valve by sucking on it. It sounds like you are getting oil into that intake for sure. I can't think of any reason unless you mixed up a hose. As far as I know the pcv valve should seal the crankcase from the manifold.
creaky clutch
cookie replied to kevinL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
the sticking down usually means its time for a new slave and or master cyl. You can get by bleeding it for a while but there is a TSB on this.
