Everything posted by chazmataz
Winter 2010-11
Hey greg, is that your old outback or did you get another one? it looks very different. hey wheres the hatch at?
Pics Here she is, thanks for all your help
alignments will not get rid of shaking. shaking is cause by other things, tire balance, axles, wornout steering and suspension parts, broken mounts and sometimes wheel bearings. if this has a suspension lift you will have shaking issues all the time due to stress on your inner axle joints (DOJ).
Toyota sr5 wheels
i would strongly recommend not drilling the wheels! if you really want to use these wheels iwould drill the hubs out and knock out the 2 studs that dont line up, drill the 4 extra holes knock the 2 studs in 2 of those holes and go to the part store buy the extra studs and install in the 2 remaining holes. Bam! 6 lug conversion. i did it on my 86 wagon, love it, good conversation piece. but try and get the right drill size, mine was a little to big and now after 7 years of running them i need to weld the studs in. to drill the hubs just knock out the 2 studs bolt the wheel on with the 2 remaining studs and lugnuts then either mark your hub or drill through the wheel just be careful not to drill the wheel or get a steel wheel from a wrecking yard as your drill template. any 6 on 5.5 wheel will work for your template wheel. i drilled mine on the car but it would be better to take the hub off and drill it off the car, they are not hard to remove. BTW! you will need a BFG to modify your wheel wells to keep them from hitting when you turn and probably have to cut your fender wells. a lift on your rig will help reduce this modification some. BUT! if these are 16" wheels they may not fit on your car without low profile tires.
Biggest tires with no lift?
i just put some 225/70-14 open country A/T on pug wheels on my 84 GL wagon (EA81). they rub slightly need to trim a little more off the front edge of the front fender, they rub under hard braking and hard cornering. i haven't taken them offroading yet to see how they do but the are a 26.6 dia. and 8.9 wide. BTW my wagon has no kift but the suspension cranked by the factory means. i had 215/70-14 blizzaks on before and they we're 26.10d x 8.70w. i will try and get some pics posted up here soon, they sure fill the fender wells though.
Why do I have no up travel?
here is some up travel for you, this car has all ea81 suspension. this is my 84 wagon has aftermarket kyb struts and shocks, i'm running a 1" rubber spring spacer in the front and the rear torsion bar is cranked. i'm also running an lsd rear end and 215/70-14 blizzaks in this picture. and this thing wheels just fine and i have never had any problems getting any where with it. it has plenty of flex and this picture was taken during a camping trip in eastern oregon, it is fully loaded with gear and 2 teenagers. no this will not do any rock crawling but it is very good in the mud, good in sand and really good for general trail use with some minor hardcore use but nothing wild since its my DD. again as has been said before quit worrying about about what it doesn't do and just go wheel it and have fun. if you want more go and buy something different.
Sand Lake run in february?
ok well i haven't been on here in awhile. i posted on this right after it went up but i'm not going to be able to do anything until march. so have fun guys i'll be ready next month. as always get lots of pics to make me jealous.
i'd be in but it will depend on the date everyone wants to go and how the move goes. otherwise march looks better for me. i will monitor this this thread to see what you guys deside on.
Let's see your LIFTED Soob off roader 2010 edition.
same old rigs, new pictures. 86 GL wagon, still powered by EA82 32/36 weber carb 5spd D/R, about 1 3/8" frt and 1 1/2" rear suspension lift 235/75-15 SXT MT 15" mitsubishi wheels 6 lug conversion welded rear diff. custom bumpers off road lights 84 GL wagon EA81 w/ 32/36 weber carb, 4spd D/R, stock suspension cranked, LSD rear end, 14" pug wheels 215/70-14 Blizzaks
my '84 hatch...
hey gregg, glad to hear the hatch is finally up and running and out of the shop. once i get my moving done we'll have to get out so i can finally see your hatch.
What part of the front suspension kills travel?
hey no problem, just thought i would clear it up.
Chain reduction Hub
its seems like almost all of his threads are pretty much worthless. he does more thread starting and posting then actually getting any wheeling experience with his subaru the way it is. i'm with the other 2, just get out and wheel it, have fun and start threads with pictures of you wheeling it or of it dirty. i've been wheeling mine for about 6 or 7 years and it does just fine the way it is.
moving the wheels forward is positive caster, this increases steering returnability or response. moving the top strut mount forward of the wheels is negative caster, this kills steering returnability.
Sand Lake run January 17th or 24th???
DANG IT!!!!! i knew i would regret not going but i did get alot done. hope theres as good a turn out next time when i can go. Glad to hear you guys had a good time. Now lets see some more pics:popcorn: the white hatch there in the middle of the pic with the brat, hatch and wagon. is that cody's from the st. helens area?
you guys have a good time and be safe. i'll see you on the next trip.
well, i hate to say this but it looks like i'm out for this trip and i hate making this decision just because of the group of soobies that are going. looks like this is going to be a great group to go hang out on the dunes with but i don't have a choice right now. i haven't been able to get my car ready even though all i need to do is put on my new tags, the seats i got from cmiller and install my cb radio. but, the main reason for me not being able to make this trip is because i need to get serious about my move out to estacada. i have alot to do before the end of next month and because of my work schedule i don't get much time to move. so i should be all done by late february to make the next trip. jason, the bearing aren't hard to get any part store should be able to get them with in a day if they don't have them in stock. i can't remember how much they cost though.
Southern Oregon Off Roading
thanks for sharing the picture, those are some awesome views. what mountain is that in your last picture, Mt. Lassen? thats a very clean looking wagon you have there.
Goat Mt., Oregon New Years Day
Ok, Stanley huh? i'm not sure if we're going hillockburn or colton yet. i have some other people i know and they are going up there also but don't know what time. they usually go up colton. but if you want just give me a call if your on your way and i'll try to keep the masses at bay if not i can let you know which wat we're going. at this time it looks like i'm going to be the tour guide though.
your welcome we'll see you in the morning.
i'm hoping to be in my grey 86 wagon but tags are expired and i would have to go up to my parents on the way to get the new one, they came in the mail yesterday. otherwise my green 84 wagon DD will be my rtrail rig. yes your toyota is fine, we'll have a mix of rigs anyway. i know atleast 1 maybe 2 jeep cherokees for sure but not sure on what else at this time.
ok sounds good, i'm doing beer. got a growler of nut brown from highland pub(mcmeninmen) on the way home. well try to make it, its not going to be to early. call me if your on your way and running a little behind. be nice to go wheelin with you again.
Updated meeting info for anyone thats interested.
Cool, as far as i know i'm in for now. shouldn't be a problem.
New Years Day some wheeling friends of mine (and me) are going wheeling up on Goat Mt. just east of Colton, Oregon. We'll be meeting up at Estacada Les Schwab at 9:30 am. hope some of you make it, don't want to be the only soobie going. like i always do with this group.
TSF Sunday 12-27-09
Oh man! :-\ you should have let me know you was going i could have gone. that looked like an awesome trip. awesome pictures too. i like uni-mogs alot, wish i could afford one. what have you done with your car? looks taller. other then meeting up with cmiller the rest of my day was messed up and didn't go the way it was suppose to. oh well maybe next time. yes i'm up for sand lake. i'll see if gary might want to go too. iam moving through out january but get ahold of me i may need to take a break. oh btw i'm moving out above eagle fern park up in the george district between the base of wildcat and squaw mtn. P.S. so what other board do you belong to other then the ones i know about?
my '84 hatch...
so how are things going? haven't had any update in....5 days, know its x-mas eve but was just curious if there have been any progress.
