Everything posted by pbilt
Help with running issue
When you did your timing belts which marks on the flywheel did you use the three marks and you line the center one up to the marker on the bellhousing or the top dead center marks on the flywheel
Weber DGAV flooding
I never have the return line hooked up on my Weber's they all run fine if you have the hookup though it doesn't hurt to hook it up what about the coolant passage on the intake manifold did you ever seal that when you put the Weber on mine are welded shut but people do it with a piece of screen and JB Weld also
Rough idle, & check engine light.
Check timing belts could have jumped its a long shot. check if its arching anywhere start it up at night and look around a spray bottle will help if you can' see any arching
Weber DGAV flooding
When you did the swap did you plug the water Inlet on the manifold anybody's done to 3236 loves it over the crapTachi that's the first thing I do when I get a Subaru take carb off and swap it trans dapt 2107 is the one peice adaptor plates for the 32/36 you just need the smaller air filter
How to lift the rear end of a GL wagon
I' Just doing the 2" blocks not buying a kit I thought I seen some lifts where they put a block on the top hat' in the rear springs but after looking at mine it looks like I need to put another bracket dropping down 2" and welding or bolting it to the other bracket
Sweet thanks man I appreciate it
Does anybody have any pictures of how to lift the rear suspension on a 85 GL wagon front is already done 2 Inch spacers the write-up on the 2 inch lift is gone since they updated this website
No power to the ignition??
everything work before you wired the pump? is the 87 fuel pump controlled by its own system not a relay if it was wired backwards could he have shorted that box out i know the pump should prime and stop till the distributor starts spinning long shot but if it was working before the pump and not after it was wired backwards id start there if you already checked fuses do a parasitic draw test something is drawing alot of power do the test on your fusible links also
Weber DGAV flooding
did the weber ever get jetted or float adjusted is it electric pump if the pump is running can you see gas going into the carb with out cranking the engine or touching the gas
Ignition Coil ground???
the 2 yellows go to - one from the harness other to the distributor. the 2 black whites go to+. you may have 3 yellows one runs to the dash one comes from the harness and one goes to the distributor i unhooked the one that goes to the dash i dont know what it does tack works still. the black wire that has the condenser on it goes with the yellow - so - side of coil has 2 yellows and the black condenser wire + has 2 black whites. the coil bracket has to be mounted to the strut tower it grounds it the condenser bolts to the top bolt of the coil bracket and the end that is not connected to the coil grounds to the bolt on the water neck of the block and another ground wire from water neck to body
- EA82 distributor and timing
85 gl wagon why is the xt6 5 lug worth it what other options is there for suspention
sweet that answered everything i was wondering about thank you i have the dual range also so 23 spline seams like alot of parts to find just for bigger brakes if it was a considerable difference in handling like night and day i would do the swap ill think about it after i run out of parts in the parts car thanks for the time
Weber to spfi harness help
had me stumped for months if not a year till i was talking to some one and put me on the right track i hope this helps someone cause no one eles has heard of this before everyone just says plugs and wires whitch is the first thing i thought also
Light show
check and make sure you dont have a hot touching the block o2 sensor, fans, ext also by the battery there is a round plug that the main engine harness plugs into that is a common spot from the battery rubbing i had the exact same problem i used this thread to prove to people im not the only one to have this problem mine turned out to be a hot in the main harness touching the block i fxed that car runs fine now try a parasitic draw test probably wont help if your battery isnt dying though
Light show
if this is not dead yet i had the exact same problem turned out to be a short in the main engine harness mine was 85 cali carbed emissions weber swapped
thread probably died by now but it turned out the main harness was shorting out to the block thanks for all the help but im sticking weber now that that non sence is fixed
thank you for the reply its going to be a camping/woods wagon but im going to have fun in it also im thinking just drill out the hubs just wondering how much of a6 differance the full swap makes suspension wise is it a more stiff autocross set up or a nice flex in the woods. from what iv been reading 88-89 honda accord springs work in the rear not sure about the front without the swap
iv been doing alot of reading on here about the xt6 5 lug swap now i just have a few questions about is it any better. 1 why is the impreza or legacy suspension better then the ea82s. 2 if you do do the swap what are the advantages other then the 5 lug rims. 3 .with the 5 lug set up can your run 14s and 15s im not sure which set up i like yet. 4 if the suspension is better is it worth finding all the parts compared to drilling hubs to 6 lug yota rims (is there a noticeable difference) thank you for reading this have a good day
EA82 coolant temperature sensors
Can you see the injector firing if you look down the thought of the tb? If you give it one shot of starting fluid at fist start it will run fine all day at all rpms or do you have to keep feeding it fluid to keep it ideling sounds to me like cam timing. But if its idleing and driving fine after a shot down the thought that rules that out
Need a SPF I wiring harness diagram please anybody
Thank you I'll set up drop box thank you for your time I appreciate it
Thank you for all the help I appreciate it alot to everyone gd much respect to you thank you I got an email from a few people I think one might be you IV been busy so I haven't had time to read them but as soon as I do I'll post and tell if they work hush77 (I think that's his name) hooked me up with a manual for the swap it's for an ea81 but should be about the same harness wise I think if I butchered my harness I'll be in the market for another one if anyone was one up for sale
Thank you I'll check that out
Does anyone have a wright up on this conversation everyone says you are the man general disorder posted a bunch of wright ups all I need is a diagram or schematic everywhere online or in the books just gives me gives me a bunch of emitions or Dead threads or dead posts
Thanks man i have been talking to gd but it seems he can't seam to find his wright up he is very knowledgeable though respect to him my email is cody_155@hotmail.com
I'll put a vid on YouTube
