Everything posted by 83subaruGLchick
My 88 Hatch "Monster"
Wow dude sweet build you’re way deeper than I am. Keep up the good work.
1983 GL Wagon build thread
I’m slowly tackling almost everything. To be honest I don’t think I’ll do the whole undercarriage I just don’t have the resources for that.
What the rear looks like currently I’m gonna start tearing it apart next luckily I’m only doing shocks and painting and sanding back here. It should not take nearly as long as the front has....
The new and improved front wheel wells lol I think I’m also going to do that shifter bushing upgrade I read about on this forum somewhere while I’m doing all this other stuff
- 1983 GL Wagon build thread
Okay so much to update you guys on. So what I thought was a shocks, struts, tie rod(inner and outer) and ball joints job turned into a brake lines in the front, parking brake cable, rotors in the front, pads in the front, tie rods(inner and outer), ball joints, bearings, seals, shocks, struts, steering stabilizer bellows, passenger side cv axle and a lift kit job. Once I started tearing it all apart I realized all of that was either bad or close to needing replacement so I just am doing all of it at once figured why not right? Anyways so I’m in the middle of that and am currently waiting on the bearings and lift kit to come in to put it all together in the main time I’ve replaced almost everything else on that list, sanded down the fender wells and painted them, cut the front fenders, finished deleting the smog pump stuff, painted and sanded down the front end, finally repainted my rear spoiler and I think that’s it. Pics of all this progress to follow- 1983 GL Wagon build thread
Little update finally got around to cleaning up the hubs and knuckles and spraying them to help against rust today because it was somewhat decent out. Also started putting the new struts together trying to get the ball rolling on the suspension stuff I’m doing so I can be done with it and focus on the EJ swap that’s also approaching! I’m waiting on brake lines and brakes and seals and bearings right now because once I got in there and tore everything apart I realized that all of that needed to be replaced or was close to needing it so might as well do it while I’m there right? That’s just how my mind works anyways might as well spend a little more and take the little bit more time if you can and do it once and do it right.- I've bought this gc8 ej 20 litre none turbo with an ej25 turbo it was swaped before I bought it is there any way of telling what car this motor is out of e.g. wrx sti /forster
83subaruGLchick replied to Natedogg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLook for the punch / serial number. There’s one right above the crank and one on the back on the engine bellhousing. Should be able to track from there.- Crank but won't start.... Subie Newbie 2000wrx
Sounds to me like the timing is too retarted for the engine to crank over if everything else is perfect. Make sure you put the cam gears back on right and pulleys and I’d just take the timing belt out and fully redo it to make sure it’s dead on. Subarus are finicky- 1983 GL Wagon build thread
- The One Behind the Wheel! (Pics of Us!)
Here’s a picture from the adventure weekend that I broke my exhaust and officially tired my suspension out. It was an amazing weekend we will be going back to these hot springs.- 1983 GL Wagon build thread
Here’s the new roof rack. And her new spot in the garage for the next little bit while I install and fix some more things!! I’ve been toying with the idea of a snorkel so if any of you guys have more knowledge on ones that work the best or what have you I’d love to hear it.- 1983 GL Wagon build thread
Evening everyone following the build. I have a few updates!! Alrighty so I have officially ordered all new suspension and that should be arriving any day now so that’ll all be fixed a friend of mine also recently wrx swapped his 93 legacy so he had an OBD1 2.2 sitting there with motor mounts, an air box and a complete wiring harness with ecu. That being said I got an amazing deal on it all and I’m officially going to start the swap process (insert super happy screaming and girly jumping up and down here). I’m no wiring guru so I’m having SJR trim my harness for me. I also bought other little things for my car too that I’ll be installing. I’m so in love with this car I can’t wait!!! - 1983 GL Wagon build thread
- Tap the lock icon next to the address bar.
- Tap Permissions → Notifications.
- Adjust your preference.
- Click the padlock icon in the address bar.
- Select Site settings.
- Find Notifications and adjust your preference.
Safari (iOS 16.4+)
- Ensure the site is installed via Add to Home Screen.
- Open Settings App → Notifications.
- Find your app name and adjust your preference.
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
- Select Notifications in the sidebar.
- Find this website and adjust your preference.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
- Click Permissions for this site.
Firefox (Android)
- Go to Settings → Site permissions.
- Tap Notifications.
- Find this site in the list and adjust your preference.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
