Everything posted by unibrook
2001 Forester 107k miles. A month ago, my knock sensor began to throw that CEL off and on for a few weeks. Now it is on steady. I pulled the sensor to see if obviously cracked in the housing or if the mating surfaces of the engine vs the sensor were corroded....no to both. So, since I am getting no drivablility symptoms, I am guessing it is the sensor insides which are dying. I will pull it one more time to try to improve the connector contacts, but if that fails, then I will buy a new one and replace it. 12mm socket with two extenders beneath the throttle cables. I needed a breaker bar to loosen that retainer bolt.
I used the Hub Tamer on my 2001 Forester rear bearing. Worked well enough. Another post on here said the Harbor Freight tool works just as well and is much cheaper, so you could try that route. The lateral link bolt is either frozen welded to the bushing or it isn't. If it is, just melt the bushing out with a propane torch in 5 minutes....not hard to do. But you need to have a new bolt and bushings ready to replace, of course. I can email you step by step instrux if you want them. nwlovell at yhoo.
#1 misfire
unibrook replied to jseabolt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
If you haven't replaced your front 02 sensor in the last 40k miles, try that. Worked for me. -
p0400 code
unibrook replied to vwbuge1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
From a diff site: >> Find the EGR valve (drivers side of the engine, on the back of the intake manifold, near the top) and the BPT is just in front of the EGR valve. The EGR valve also has a metal tube that disappears down the back of the engine to the exhaust port on the #4 cylinder. Start replacing all the rubber hoses associated with those 2 main parts...> Have you already done this? -
misfires
unibrook replied to wesmay's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
If it only misfires when warm, not cold, and if you have not replaced your front 02 sensor in the last 40k miles....then try replacing it. -
Hub/Assembly
unibrook replied to amr9000's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
In fact, my rear wheel bearing outer race was so tight, the Hub Tamer could not press it out before it began to deform the knuckle...so I stopped. I rented a slide hammer from AutoZone to yank/pound out the outer race. That was the toughest part of the job. I was SLAMMING that bear.
