Everything posted by TheBrian
K&N filter and crazy drone?????
TheBrian replied to 98legacywv's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy intake does that when I open the air filter housing just a tiny crack. When I open the housing the whole way, the drone goes away, and the intake makes nice sounds. Sounds to me like your air intake has a small leak somewhere. I would get out the stethoscope and try to locate the source of the sound.
Lots of questions from a noob
TheBrian replied to BBYE V8's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDon't forget the '95-'99 Legacies with the 2.2. Good cars, those.
OEM Radio Knobs source?
TheBrian replied to 95LEGOBW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe Bass/Treble knob went flying off the first time I pushed the button, and I haven't seen the knob since. It's probably still in my car. Is that the same knob you're missing?
I finally put bigger tires on
Post a photo! I want to see how it might look on my 2nd gen Legacy.
EJ22 swap into EJ18...
TheBrian replied to 93imprezaLboy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell, there's tons of wires going to the computer and all throughout the car. Look behind the driver's and passenger's footwells and see. I don't know how many of the wires from your 1.8's computer will clip right on to your 2.2's. I guess that would determine how big of a project the wiring would be.
which subaru for me?
TheBrian replied to slim_slc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy opinion: A manual transmission is clearly superior from a reliability standpoint. But I insist on MT's only because I find them more enjoyable to drive. Others prefer not to have to shift. They should choose automatics, with the knowledge that the auto tranny might go bad before the rest of the car.
TheBrian replied to 93imprezaLboy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe transmission will bolt up. However, the engine will need to bring its computer with it. That's a wiring nightmare. If the '96 body is in good shape, you should consider putting the 2WD 5mt in it. That might be easier. Either way, it's a large project. I would put it off until the 1.8L engine dies.
Trip report speedo problems, and Seafoam
TheBrian replied to Gnuman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSome speedometers are adjustable via a rheostat in the speedometer gauge. I've never heard of such a thing in a Subaru cluster, so I'm guessing it doesn't exist. There's this product, though it's pricey: http://www.dragonaero.com/SpeedChangerPage.htm
Testing Oxygen sensors.
TheBrian replied to TheBrian's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTrue, but that requires $55 and a laptop. Though the in situ testing would be a huge advantage.
http://mymiata.paladinmicro.com/Miata4-WireO2.htm#O2SensorTesting This site describes how to test an oxygen sensor. Basically, heat it up, adjust the amount of oxygen while watching the voltage. I haven't tried it, but I hope you find it useful.
map or maf sensor???
TheBrian replied to ofairlane's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think my car (California '96 Legacy) has both. Is that redundant? I can see a MAF sensor right after the air filter. I'm fairly certain the thing bolted down right behind the air filter box, with the vacuum line and a wire harness attached to it, is a MAP sensor.
anyone ever read thier emmisions tag under thier hood?
Mine says it's a California-emissions compliant car. But the car was delivered to New York in 1996.
Tribeca B9 Photos
TheBrian replied to hklaine's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnd weigh 2800lbs.
How much torque can the stock clutch hold?
I'm asking because I'm trying to remove the crank pulley bolt, immobilizing the crank by putting the car in 5th and setting the P-brake. I think I put about 200ft-lbs on the breaker bar before the clutch slipped. I've got a Fenco P.O.S. clutch kit from AutoZone in there. 200ft-lbs doesn't seem like much for an engine that can make 140ish.
Sun Visor Sticker Removal?
TheBrian replied to axxiom's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm speculating, but I bet most airbag stickers are intentionally difficult to remove, for legal and liability reasons. I think you'd have a hard time removing the sticker and having it look like there never was a sticker there. What year Subaru do you have? In 1996, they sewed a plastic sleeve (which holds highway toll tickets nicely) with the airbag warning to the visor. It's not too obtrusive. The driver's and passenger's rooflines have opposite angles, so you can't just swap the two visors. It may be more than you're willing to invest, but you could have the visors reupholstered. Or if you have a '97 or '98, you should be able to install '95 or '96 visors.
check engine light
TheBrian replied to 96LegacyGT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTo change those bulbs, you have to remove the instrument cluster, which requires a screwdriver and about ten minutes. Most of which is spent trying to squeeze the cluster between the dash and wheel. The Check Engine bulb is the same as the gas idiot light bulb.
Do you know how to read the V.I.N.?
TheBrian replied to vic/se's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe best Subaru VIN decoder I've found: http://en.wikipedia.org/wiki/Subaru_VIN_codes Though it's obviously missing a few engines and models, and it only covers new-gen Soobs.
tranny swap
TheBrian replied to natr13's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://ultimatesubaru.org/forum/showthread.php?t=33414
Replacing speedo with KM
TheBrian replied to pedroelbee's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAh, but a metric speedo would look nice. I'd telephone a Canadian dealership. I'd say a Canadian junkyard, but there probably aren't a lot of wrecked '04s yet. It should be easy to swap out the cluster, or just one of its gauges. In a '96 Legacy, it's a 15 minute job.
tach compatability
TheBrian replied to (goldfish)'s topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have a '96 Brighton. I went to the junkyard and pulled the instrument cluster out of a '95 L wagon with 160k miles. I paid $40 for it. The cluster is nice and modular. All the gauges unscrew and can be replaced one at a time. The Tachometer is connected to the cluster by three screws that line up with traces labelled +, -, and TA. I'd be willing to bet your '97 gauge pod is almost identical. I can upload a photo of the '95/'96 version if you like
What EJ-series transmissions are compatible?
You do? Oh. Then here's another question about which parts might work for Al's upcoming AT->MT swap. 5MT's off cars with 21" outer radius tires are hard to find. But there are plenty of 5MT's from cars with 19" tires. Is there a way to install a driveline off a Legacy L (19" tires) on an Outback (21" tires) and have an accurate speedometer? They all have different final drive ratios, so there is no vehicle speed sensor out there that knows the correct relationship between turns of the driveshaft and distance travelled. Imprezas have a shorter wheelbase. Yet one might be able to use the tranny & diff of an Impreza and the rear driveshaft off a Legacy. Does anyone know if the transmission & diff mounting brackets are the same on the Impreza and Legacy, '95-'98? That would widen the field of potential donor cars.
top speed of legacy outback
TheBrian replied to lostinthebush's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe German-spec 2005 Outback, 165HP, 5MT, is rated for a top speed of 123mph and a 0-62mph time of 9.8s. BTW, Al, the 2.0L, 138HP, 5MT Legacy wagon is rated for a not-too-shabby 120mph. So you wouldn't exactly be blowing past me on a hypothetical Autobahn.
Tribeca B9 Photos
TheBrian replied to hklaine's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't care for the styling. But then I don't care for how most new cars (except sedans and coupes, which are generally reasonable) are styled. I guess it's good to see a Subaru big enough to put the H6 to use. Fold-flat seating achieved by raising the height of the floor in the cargo hold. Two questions: Is it officially a Minivan? Does it share a platform with any other vehicles, or is it based off of anything else?
Hp and Tq ratings for EJ22
TheBrian replied to Knichol's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAFAIK, there have been four different versions of the Legacy: 90-94 95-98 99-04 05-present And each gets worse gas mileage than the one previous. According to the specs on Automotive.com, the EPA highway gas mileage is as follows: 95: 7.6 L/100km 96: 8.1 97: 7.8 (a 4% improvement) 98: 7.8 99: 8.1
can an ea82 handle hydrogen power
Don't assume that just because I live in the U.S., I agree with our current policies or our leadership. No, actually, I fully understand Iceland not complying with Kyoto. They have a good reason not to. And unlike the U.S., they're taking innovative steps toward being green.
