Everything posted by MDW25gt
Will WRX 6sp fit to '99 2.5 legacy
Will a WRX 6 sp fit into a 99 Legacy gt with 5sp? I thought it would be a nice setup if it could be done??
Well, I got a LGT WGN
MDW25gt replied to iluvdrt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGotta love the wagon! GT no less.
Headers for my wagon???
MDW25gt replied to Danbob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have had Borla headers on my car for 2 years and over 30 k miles. No issues! Easy to install. NO problems. I paid close to 300 for mine.
99 leg gt cv joint ?
MDW25gt replied to MDW25gt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks for the info. The boots never dryed out on the original axles. Had at least 30k miles with the headers. the original axles lasted 155k without a problem with the boots. They just started making noise. Motor and tranny mounts are only 30k old. Rotors and pads are only a couple weeks old. I did not have the problem before the last axle change. I will need to check for loose bolts. Where is the axle pin supposed to be? Thanks again.
I have a 99 leg gt with a borla header. I had both front axles replaced in June. I noticed the other day that the inner boot on the passenger side was open. The guy that did the work replaced the axle no charge. However he mentioned the header could have caused the boot to dry out and open?? My question is, could the header be causing the boot to go away? Has anyone had this problem with headers? Second question, After replaceing the axle, I now notice under WOT that there is a feeling like something does not fit right. Shifter shakes, steering shakes, not right! Has anyone ever had a problem like this? Could the axle be bent? not installed right? Any ideas?? Thanks
code 0420
MDW25gt replied to jct61765's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah right!
Rough Missing Idle NEED HELP Please!
MDW25gt replied to wiwrx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMaybe fuel injector??
Old shool guy needs new shool rig for wife
MDW25gt replied to El Toro's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmine has 5 door open lights.
Clutch question, help please......
MDW25gt replied to Megell's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had my clutch replaced by the stealer. I had a similar problem with engagement. Ended up replacing the hydraulic cylinder. Easy to do, and cost me about $75. I got the same answer. That is the way it is supposed to be. Bull ************! My guess is the hydraulic cylinder.
Best brake pads
MDW25gt replied to jpsnowbumb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI like the HAWK HPS.
my gameplan for the wagon...opinions?
- Tranny?
MDW25gt replied to Danbob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think nipper is asking if you trans has heat shields? Does it happen more in tight turns?- brake differences?
MDW25gt replied to offroadsubaruguy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou talking about rotors or calipers?? Guess I dont understand?- brake differences?
MDW25gt replied to offroadsubaruguy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHere is what I have found. I have a 99 leg gt wagon. The front rotors are causing a shudder in the steering wheel under brake on the highway. I initially thought it was the bracket slide pins because one was seized and the other very stiff. Called Hal's in SC (Subaru yard) and had them send a drivers side bracket. Installed it and it heald the caliper out and about a .25 inch of the pad was off the rotor. i.e. it appered to be from a car with a larger rotor. To solve the problem I called TireRack to check on brembo oem rotors. Asked them to check the diameters of the rotors. For a 99 they found 10.2" on gt and legacy. 10.7" for the outback! (I had not measured mine) Called Hal's back and asked them to double check the year, model and diameter of rotor the original bracket can from. He told me 98 outback and the rotor was 10.7" diameter. So I had them send me the calipers, and the other bracket. Then called back tirerack and ordered the 10.7" brembo oem's. (Also got the stainless lines) I will let you know how it goes when I install. Mike- Spark Plug Removal
MDW25gt replied to Dickensheets's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI agree with SubiGal. Its not really that bad of a job. Remove the washer tank, and the air box. I would not pull the valve covers off just to change plugs, but if you need to replace gaskets go for it. I still recommend pulling the washer tank and the air box. Its a hard job when you have to pull the engine to replace the plugs!- 99 leg wagon 5mt with binding
MDW25gt replied to MDW25gt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes the thumping you talk of occur when in a tight turn? If the carrier bearing is bad, do you replace the entire drive shaft? What makes you say TB? I have delt with torque bind, never had thumping?? I dont think this is the same. This is a 5mt, not an automatic! Mike- 99 leg wagon 5mt with binding
MDW25gt replied to MDW25gt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat is involved in replacing the center carrier bearing? How do I determine if that is the problem?- 99 leg wagon 5mt with binding
I have a 99 gt wagon with a 5 sp. I have started to notice a slight binding in slow tight turns. I am very familiar with this in the auto. My question is what causes this? and What is the fix? I have 160k miles on the drive train. Thanks Mike- 99 Leg GT wagon brake shudder
MDW25gt replied to MDW25gt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI understand what you say, however the seized pin cant be removed. That is why I think I need a replacements. Do you have suggestions to remove the seized pin?- 99 Leg GT wagon brake shudder
I am having periodic brake shudder at highway speed. I have looked at the calipers and found that the slide pin on one of the caliper brackets is seized. I would like to find another set of brackets for the front calipers to fix this. What brackets will fit? Year? Model? Thanks in advance, Mike- Stumble, 1998 Forester S
MDW25gt replied to Randall's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had a problem with intermittend stumble. Someone suggested MAF sensor. So I removed it and cleaned with a spray cleaner (dont touch it) just spray. Let it dry and replaced. After this the stumble has not come back. Knock on wood:o).- Independent service in NE Ohio
MDW25gt replied to zippypinhead's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXStay away from the Subaru dealer in Massilone. Forgot the name? They are crooks. I went to the NAPA service place between Wooster and Orrville once thinking I had bad rear wheel bearings. They did not do work because they diagnosed cupped tires, but they seemed very capable, and very honest.- 2002 impreza torque bind
MDW25gt replied to kennyz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think its a stretch to drive on a tire with 10psi and not realise it?? For 50 miles? If 10 psi was the case, seems someone was out of touch.- Gasket Dressing
MDW25gt replied to Top's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI did the head gaskets in my "99 and I replaced the head bolts. I would be surprised if the '98 was any different. Need to replace.- cough/stumble 99 GT
MDW25gt replied to MDW25gt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUpdate: I removed the MAF and cleaned with a spray cleaner. Put it back on and have not problem since. I will probably swap out the 4 power Bosch's for NGK's eventually. For now its happy. Thanks - Tranny?
