Everything posted by MDW25gt
Wagons only - post your pictures here!
MDW25gt replied to kevinsUBARU's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX1999 Legacy GT wagon.
Shudders when stopped at lights
MDW25gt replied to Chip's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow would the axle get longer?
Losing water from overflow tank
MDW25gt replied to Dickensheets's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMine did that for a year before overheating started. Try some barrs stop leak. After the over heating started it was down hill from there. Head gaskets were shot. When it was all said and done I had a new engine. If you are dealing with a good shop they should be able to do a pressure check on each cylinder to see if it is blowing back into the cooling system. If so get the head gaskets replaced by a good mechanic. Mike
MDW25gt replied to Chip's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had a 90 auto leg that did this. Turned out to be a bad fuel injector. When the problem is happening disconnect one by one the fuel injector connections. If the problem gets worse go to the next one. If there is no change then I would say you have identified the bad injector. On my 99 5spd I noticed shudder when letting the clutch out from a stop. Checked the fuel injector connections and found a broken clip on the connector. Used a zip tie to secure and the problem is fixed. I dont get the connection to the discribed problem and axles?? Mike
Anyone Else's Throttle Touchy??
MDW25gt replied to Phugoid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSeems to me the computer spools up the engine quick at low speed. I have the same thing in a 99 5spd GT. Clutch is new and so ar all mounts. I am not sure it has anything to do with drive line lash?? Its very hard to make a small change or smooth start with the manual tranny. With an automatic it is similar but you dont have the user coordination of the throttle and clutch to balance. I believe it is typical of the Subie.
So, I bought a Stromung....
MDW25gt replied to 1 Lucky Texan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTry a Borla header in front of it. It completes the install and sounds great. Very nice.
torque binding
MDW25gt replied to nosajh9's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had a '90 legacy wagon with the torque bind. took it to the Subaru stealer in Massilon. They did $1400 worth of work. At least they took my money! Then on the way home the torque bind was still there. Took it back, and they claim they could not make it happen again. So I was stuck by the Subaru stealer in Massilon. Ended up putting a fuse in the FWD holder and just drove it. Only 2wd but torque bind was gone. Good luck! Don't take it to Massilon!
Buying a factory demo: bad idea?
MDW25gt replied to shmerham's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI got a written quote for an 05 leg wagon i, new, USD $20343. The 06's are coming in and the US auto makers employee priceing is also helping.
apexi super ground system
MDW25gt replied to MDW25gt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI guess it must be magic! No one know about magic??
Does anyone have experience with the apexi super ground system? What are the benefits? Draw backs? How does it work? Mike
Hello to you! / car break in period?
MDW25gt replied to Zephyr's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI used the suggestions in this http://www.mototuneusa.com/break_in_secrets.htm when I broke in the new EJ25 I put in. So far so good! I currently have 10k mile on the motor. Mike
DIY Caliper rebuild?
Does anyone have suggestions doing rebuilds on 99 legacy brake calipers? Mike
What brand of oil do you use?
MDW25gt replied to swc7916's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhats wrong with Fram??
Cel Po420
MDW25gt replied to MDW25gt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks for the reply, The sensors have maybe 5000 miles. The front I believe is a 3 wire and the rear is 4. Stock replacements. I switched them when I went to a borla header and stromung exhaust. What is with the ground?
Cel Po420
Got a CEL today that is PO420. Catalyst system efficieny for Bank #1 is below threshhold for the current operating conditions. (Bank 1 identifies the location of cylinder #1, while bank #2 identifies the cylinders on the opposite bank.) Plud wires are 2 months old, fuel filter is 2 weeks old, plugs have 8000 miles on them, engine has 5500 miles on it. any ideas?? Thanks, Mike
So....i did a few things to the RX today...
Neat stuff. I am interested in learning more about the RX. What years did they make them? What engine? How long have you had yours? Pictures? Thanks, Mike
Wiper arm removal 99 leg wag
I would like to remove and paint the wiper arms on my 99 leg gt. (front and rear) Any suggestions on removal techniques?
Suspension repair/upgrade
MDW25gt replied to bfg9k's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI put KYB GR2's on a 90 leg wagon that originally had air. I was very pleased. Required going to a yard and getting the upper bearing mounts and springs + the new struts from tire rack. $150 from the yard. OEMs where too high for me. On my current ride (99 Leg GT wagon) I put the KYB GR2's. Again very pleased. I would guess that the KYB's would be good on yours. Then maybe look at larger sway bar. I dont really know what the difference is with the GT vs L suspension. I can check the diameters of the sway bar if you are interested. Good Luck, Mike
99 leg gt slight miss
Ok theres my problem. The engine is new. 5000 miles. I have a problem with intermittent miss. Comes and goes. Runs like it has a bad valve. The motor "thumps" rather than sings when I go through the gears. It just does not pull the way it does at times when it is running good. It does not do it all of the time. Seems to come and go with no direct cause and effect that I can tell. Wires are new and plugs have maybe 8000 mile on them. Any suggestions would be appreciated. Mike
Phase I and Phase II?? help a newbie!!
MDW25gt replied to wendybradley's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo what is the difference between the Phase I and II? I have a 99 gt EJ 25. Is it I or II? Been through the HG failure. My impression is the HG can fail in a I or II. I thought there was a problem with the Head gasket it self. What gives?
rattle coming from the tongue that touches to the clutch cylinder!!
MDW25gt replied to 98legacywv's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had the same problem. turned out it was the slave cylinder. easy to change and costs about $75. (2) bolts and the hose, then bleed the system. Seems the spring gets lazy or the cylinder bore gets fouled. this inhibits the piston from maintaining contact with the fork.
How to track down a bad wheel bearing.
MDW25gt replied to syphon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI thought I had a bad one in my 99 gt wagon. turned out the tires were cupped. When they were moved around the sound moved around too. Raising the tire pressure to max eased it some. the mechanic put it on a rack and put a stethascope on the axle but was not able to hear anything when the wheel was rotated.
Cincinnati Beechmont Subaru
MDW25gt replied to phatirejunky's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTry Joe's Subaru repair. 513-221-8585 1608 Hoffner St. Off Springgrove. Joe is the best I have ever seen. He takes his time and is very methodical. I would not recommend any dealer over Joe.
remove plug wires
MDW25gt replied to 99legacy2.5GTLTD's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI replaced the entire set in 20 minutes. Had to pull the windshield wash tank and the air box cover out of the way. Twist and pull! Not on the wire! But since you are replaceing who cares?
milage question?
MDW25gt replied to lostinthebush's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX99 legacy gt wagon, motor with 2200 miles on it. borla header and stromung exhaust. I got 25.6 mpg today on the highway. seems to drop to 21-22 around town.
