8
There is an internal screen on the transmission, but unless something has failed, and you have chunks in your transmission, you shouldn't have to worry about changing it. Torque split under "normal" straight line driving conditions on the automatic are 90/10. As slip is detected, torque split can change from 90/10 to 50/50 as needed. When you physically put the gear selector in 1, you force 50/50 torque split. I recommended that because it forces 50/50 torque split and would give you a better indication of whether the AWD is functioning. The LSD reference was because, if you are just looking at the driver's side wheels by sticking your head out the window, the passenger rear tire may be moving. Which is why I asked if someone was outside the vehicle observing.
Has the transmission fluid been changed/flushed recently? You may want to start with that. Have you tried putting the gear selector in 1 and seeing if you get more then one wheel peeling. Torque split will be 50/50 when the gear selector is physically in 1, and possibly 2. Are you having someone watch on the outside to see if the rear wheels are going? Also, you don't have LSD, so if you're only looking at one side, the other side could be spinning. josh
No horn
Legacy777 replied to bhelser's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
One of the engineers at work put a set of train horns under the body of his wife's excursion. One of the mechanical guys helped him size an air tank for a 2 second burst. -
No horn
http://www.main.experiencetherave.com:8080/subaru_manual_scans/1990_Legacy_Owner_Manual_Scans/118.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/1990_Legacy_Owner_Manual_Scans/119.jpg You can d/l the whole manual in pdf if you want. http://www.main.experiencetherave.com:8080/subaru_manual_scans/1990_Legacy_Owner_Manual_Scans/ It's for a 90, but should be the same/similar. -
Thanks for the explanation. I haven't decided what my final turbo plans are, but I'll keep you in mind.
