Had to give the car up...
Legacy777 replied to TurboTbird's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah.....once you drive a good Subaru....you start comparing other cars to it. I drive lots of rental cars due to traveling for work....and I'd rather drive my old legacy then those new cars.
auto to 5 speed swap in 98 GT?
Something like this, but more work since it's OBD2 www.surrealmirage.com/subaru/swap
1999 outback wagon- where are the woofers?
Legacy777 replied to sunking247's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPlease only post once on related questions/issues. Going to close these threads since you have another thread with similar questions. Please continue any conversation there. http://www.ultimatesubaru.org/forum/showthread.php?t=54237
1999 Outback- New speakers?
92 turbo legacy center diff question "free car"
Legacy777 replied to archemitis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere is no center diff on the autos. They use a multi-plate clutch system to transfer power to the rear. Which CV axle broke? Front or rear? Here's more info on the auto trans. http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/AWD_transfer_system1.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/AWD_transfer_system2.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/AWD_transfer_system3.jpg
1990 Legacy Door Lock Probs (PICS!)
Legacy777 replied to DirtyMech's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust to add. I used gary's info back in 98 or so to fix my locks. I just used a paper clip to hook the spring. Getting the plastic piece off around the door handle can be tricky. There are two clips at the pivot point of the lock button. Detach those, and then push the entire plastic piece towards the front of the door. That will unhook the last clip in the front.
Wrong alt belt from Subaru - '99 2.2l - advice?
Legacy777 replied to Scottbaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWho knows...they may have just got things mixed up in the system. As long as they're making good on it, I wouldn't worry about it.
trans shifting
Legacy777 replied to subaru girl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would say what you're experiencing is for the most part normal.
Service Manual for 98 Forester S, 5 spd
Legacy777 replied to Randall's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can buy the factory manuals on paper back. http://www.subaruparts.com/catalog/?section=385 or d/l them http://techinfo.subaru.com I'd recommend the paper backs. You may also want to search ebay. They sometimes pop up on there.
Legacy777 replied to sunking247's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey are a subaru item. So I would check with your local subaru dealer, or check on ebay as well. You may also want to post in the WTB forum in the marketplace.
Legacy777 replied to sunking247's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI will pose this question to you. When you go to a concert, do you face the music or do you turn and face the other way? You face the music. So why would you want to have the music behind you in your car? Rear speakers for all intents and purposes on pro type systems are nothing but rear fill. They are capped so the frequency range they reproduce is not too high or too low (band pass). That's how I've got mine setup. If you just want to stay with the stock deck, no amps, and other stuff, I would recommend you get new speakers to replace all four speakers. Also, if you want more bass, get a dedicated subwoofer.
1992 Subaru Legacy ECU Codes
Legacy777 replied to mikeamondo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou are absolutely correct in your understanding of the codes and the diagnostic connectors. The canister purge solenoid is part of the evaporative emissions system. The ECU tells it to open at certain times so that intake manifold vacuum draws the gasoline vapors out of the charcoal canister in the front of the engine (black round thing). The purge solenoid is located under the passenger side intake manifold and isn't too bad to get to. These pics should help http://www.main.experiencetherave.com:8080/subaru/images/injectors/ Second row down you'll see a pic of the the solenoid valve.
Need Some Guidance with a 1993 Legacy
Legacy777 replied to ammanti's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCan you describe the noise you were hearing a little more thoroughly
Re: New Gen Subaru FAQ Sticky Compilation
Legacy777 replied to ryan tranholt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've moved your post out of the FAQ sticky, because that's not where it belongs. Please provide some additional information about your car, model, year, etc
TCU part numbers
Legacy777 replied to bridorf's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAny time a change is made, even insignificant changes, the part # changed. There's a good probability that the TCU you have will work fine.
90 Legacy engine code 33?
Legacy777 replied to Syrinx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFor future info, You can find out how to pull the codes and what codes are what by reading my post at the bottom of the FAQ http://www.ultimatesubaru.org/forum/showthread.php?t=51554
Legacy777 replied to Legacy777's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow to read the ECU codes for OBD1 Legacies & Imprezas How to read the TCU codes for OBD1 Legacies & Imprezas
clear/red tailights for legacy gt?
Legacy777 replied to damien's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAsk in the Legacy forum on NASIOC
recurrent TPS problems 2000 legacy
Legacy777 replied to friendly_jacek's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPersonally, I don't think your TPS was ever the problem in the first place. Too many mechanics are just parts changers any more, and don't actually troubleshoot. Do like your doing...check all the wiring. The problem may be temperature dependent as well....if so, it's going to be tough trying to track down which wire is the actual culprit.
my fan makes noise
Legacy777 replied to WRXgirl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah...it's probably a leaf. Follow setright's advice. You can remove the glovebox to give you some more room.
'91 legacy door lock hang up
Legacy777 replied to saw's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTake the door panel off and make sure the linkage isn't binding, and is working properly. If it is, your problem is with the lock assembly.
Anyone with an 06 Impreza 2.5i 5speed?
Legacy777 replied to 75subie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've got some friends who have an 04 or 05, and they like them. You may want to ask on NASIOC http://forums.nasioc.com/forums There's going to be more people that are going to have them.
2.2 bucking, rough running, MAF saga....
Legacy777 replied to bluegrasssboy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot sure about the IAC valve error. It's possible it needs to be replaced. As for the 5-pin vs. 4-pin. It shouldn't matter. The Black JECS MAF sensors on the 90-91's I believe had the 5-pins, and then in 92 they went to 4-pin. The reasoning is due to because the first gen legacy had two different MAF sensors. The ECU detects when the incorrect MAF sensor is used by having an extra pin on the MAF that grounds. I believe on the JECS MAF sensor with 5 pins, that pin is not really hooked up to anything. They probably went to the 4-pin setup to save money...or whatever. I've used 4 & 5 pin JECS MAF sensors without any problem.
Legacy777 replied to bluegrasssboy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot sure, if not, I'll add it.
ashtray light
Legacy777 replied to wrongturninwv's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif it's like the previous gen legacies, you have to take out the cover/metal piece that the ashtray slides into. On mine, there's one screw in the back and two screws that face upwards.
