Heads
They have smaller exhaust valves, slightly less valve overlap on the cam, connections on the passenger side for turbo coolant oil lines. Don't use them on a n/a motor, they won't help.
Clutches
Legacy777 replied to ctoth's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm unaware of any differences, but I'd suggest you ask in the transmission forum on NASIOC http://forums.nasioc.com/forums
0MG WTF 10L JDM tYt3 y0!!!11!!eleventy!!1!
Legacy777 replied to DerFahrer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah....my brain hurts too.... BTW, I don't like steering wheels with a bottom spoke. I like to rest my hand at the bottom of the wheel when cruising down the highway. I swear most of the new cars have that bottom spoke....
new addition to the family
Legacy777 replied to subaru_styles's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo you get a key in ignition beep/buzzer when the engine is off, and door is open? If not, there's a chance someone disconnected the connector coming from the ignition switch assembly to disable to beeper. The connector is a 2-pin, T-shaped connector coming from the ignition switch. Look for it, and make sure it is plugged in.
Bull bars for Baja's?
Legacy777 replied to Spacinjason's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMay want to check the offroad forum. Also, you may want to email these guys http://www.renickmotorsports.com/oscommerce/catalog/index.php?cPath=664 They can get stuff from Australia and may be able to get you a bull bar.
ej22t heads on n/a block?
Keep the n/a heads. the exhaust ports on the turbo heads are smaller then the n/a heads.
Legacy777 replied to subaru_styles's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat codes did you get from the seatbelt computer? Did you look at this? http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/autoseatbeltdiag1.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/autoseatbeltdiag2.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/autoseatbeltdiag3.jpg
Temperature sensor?????
Legacy777 replied to RisSanSubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere's a bleed screw on the passenger side of the radiator. This MUST be removed in order to get all the air out. Also, if you are using anything but an OEM thermostat, replace it with an OEM subaru thermostat.
EGR Error Code 56
Legacy777 replied to wookiemail's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't know if the 95 impreza is like the first gen legacies. It has two sensors, one for the gauge, and one for the ECU. Even if there's only one sensor, and it reads correctly, it still could be the sensor. They can be cranky, be bad, and still read the correct voltage. You can get them for 20 bucks at www.subarugenuineparts.com So I'd recommend just replacing it....it does wear, so either way, it's a good idea. What color are the connectors? You can also pull the EGI/TCU fuse for 30 minutes or so and accomplish the same thing.
Legacy777 replied to subaru_styles's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck out www.bbs.legacycentral.org If the fan doesn't work on position 4, then it's probably not the resistor pack....since full power should be going to the fan.
Can anyone help me out?
Legacy777 replied to Pacs_Legend's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can find some pics here http://www.main.experiencetherave.com:8080/subaru/images/injectors
rear drum to disk conversion question
Legacy777 replied to dmanaenk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd suggest searching, there's been a lot of threads about it. Do the threads you read specify why they changed the cables?
Sunroof Binding
Legacy777 replied to charlierh2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs the roof pushed in at all? Anyone else have any ideas?
Rear Pinion Seal Leaking
Legacy777 replied to LanceGillette's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou'll need to remove the nut that holds the shaft to the mounting plate. You could probably do it on the car.
While the 4EAT is off..
Legacy777 replied to Suzam's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey could check the rear separator plate, but it's probably ok.
Moist Seat belts on the 95 Legacy
Legacy777 replied to RallyKeith's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCould be the seal. I'd keep an eye on it, and see if it happens again.
What do I need to get functional cruise control on a '92 Legacy?
The cruise computer is on the passenger side of the car, to the right of the glove box. It's a pain to get to. here's pics of what it looks like http://www.surrealmirage.com/subaru/images/swap/18/default.htm This gives a better view http://www.surrealmirage.com/subaru/files/swap/elect_unit_loc/6-3_electrical_unit_location05.jpg These electrical info scans may help as well. http://www.surrealmirage.com/subaru/swap/electrical.html#cruise
2002 turbo mod information needed.
Legacy777 replied to BabyAidan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would highly recommend not doing this. If you don't know what you're modifying....don't modify it. It sounds like their telling you to remove one of the hose connections going to the solenoids/valves. What does this mod claim to do?
97 2.2 valve adjustment FSM Info
Legacy777 replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you have not found the info you need, email me.
EGR Error Code 56
Legacy777 replied to wookiemail's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd reset the ECU, and see what codes come back. However your warm up symptoms would point me towards replacing the coolant temp sensor.
WRX replace clock w/3 gauge cluster
Legacy777 replied to t-wrx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd recommend you search on http://forums.nasioc.com/forums Other place you will probably find info is www.scoobymods.com
Engine type?
Legacy777 replied to 2X2KOB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell....according to that information, it looks like things changed half way through. Look at your vin #, and see if it matches the VIN 6 thing.
Evap relay location?, fuel smell
Legacy777 replied to tjxtreme's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, I'd remove the solenoid if you can't test the leads with it bolted to the manifold.
1st new gen post: svx question
Legacy777 replied to jeffast's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMay want to ask on www.subaru-svx.net
1990 Legacy L Wagon Overheats!
Legacy777 replied to DirtyMech's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid you remove the bleed screw on the passenger side of the radiator? Do you get heat alright? Does the waterpump sound ok? Is the thermostat and subaru thermostat or is it a generic one?
