8
These may help http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/autoseatbeltdiag1.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/autoseatbeltdiag2.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/autoseatbeltdiag3.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/auto_seatbelt_wiring_diag1.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/auto_seatbelt_wiring_diag2.jpg
Yup, you're in the right section. The board has several different forums, each forum has threads, and threads have posts replied to them. As for keeping tabs on your post, there's two main ways. When you submit a thread, there's an option below that says "Thread Subscription" You can set this up to email you whenever someone replies. The other way is use the search engine and simply type in your username, and find all any posts by you. Hope that helps.
Like I said, you've got a short some where. If the dimmer switch keeps things from blowing, then the switch may be shorting out, or one of the interior illumination wires or bulbs could be shorting out. Either way, you need to have it fixed, and fixed properly. Electrical shorts are not something to take lightly as they could burn your car to the ground.
No, only after the car would sit overnight or for extended period of time...AND....if you just put the car in gear and kept your foot on the brake, and didn't touch the gas pedal.....it wouldn't do it. I say that because I brought it to the dealer and they just started it up and did what I said, and it never reproduced the problem. Once you touched the gas pedal is when it would stumble, and then it'd be fine. I really don't know what the issue was. So on yours, do you get the problem when the car is "warm" as well? My car was originally FWD AT & normally aspirated. It's not AWD, MT, & has a turbo legacy engine. So way too much stuff has changed....however I have supspicions it might have been auto transmission related.
