8
Will 06 WRX calipers and rotors fit an 02?
Legacy777 replied to FBEANSSUBARU's topic in Subaru Retrofitting
The subaru sti 4-pots & 2-pots are what come on the 06. The front 4-pots will bolt onto the 02's without any issues. You will need a 17" wheel to clear the calipers though. The stock 02 wheels will rub the calipers. In the rear, it's not so simple. The mounting position for the 2-pots is different. The easiest thing to do is find a used spindle from an 06 and swap it onto the 02. Otherwise, you have to press the bearing out of the hub, and swap backing plates. In doing so, you'll need to replace the wheel bearing, because they typically come apart when they're pressed out. There has been talk about making a bracket for the rears, so the 2-pots just bolt on. Whether that's available, I'm not sure. You may want to search the brakes & susp. forum on nasioc http://forums.nasioc.com/forums -
Take it to a reputable shop or a/c shop. The amount of money some shops charge for a/c work is absolutely ridiculous. I bought the gauges and vacuum pump to do all my own work. It really isn't that much work for the shop to do. My only caution about used condensors is that you need to make sure they don't contain any contaminents like metal flakes from a compressor dieing, etc.
So.... You're saying the ignition relay has issues. Is this correct? Did you perform a test yourself to determine this, or did someone recommend that might be the cause? How did you determine the power going to the ECU needs "filtering"? What test did you perform to see the noise? If you don't mind sharing, I'd also like to know the details as to what exactly you did to modify the ECU to not be as susceptible to "electrical noise". And again, what wiring error, or difference did you find?
What's your budget? You're probably not going to find anything specifically for the outback, however there are probably quite a bit of stuff from the normal legacy and impreza of similar years that would work. You could put Legacy GT springs & struts on your outback, which will probably lower the ride height from what it current is, and give you better handling....without "slamming" it. I'd suggest searching on Nasioc http://forums.nasioc.com/forums in the legacy forum for more information on what's swappable.
I believe there are a few threads that show pics and have instructions. You may want to search. It's pretty straight forward. To be honest, I'd highly recommend you replace all four struts at once. I've been down the road you're going, and you end up with issues in having mixed-matched struts with different damping rates.
What are you wanting to swap? Everything, or just calipers? How are the 03's brakes better? Does it stop shorter, or does it just feel better. Once you get into the "feel" portion of braking, you get into the non-calculatable part that can be different for different people. Things like brake fluid, brake pads, vacuum assist, tires, etc can affect how the brakes feel. So what I would suggest you do, make a list of what's different between your 00 & 03. Try to remove some of those things from the list....but do this after you've answered the question, what's better about the 03.
