Some new pics
Zymol'd the legacy today here's some pics http://www.main.experiencetherave.com:8080/subaru/images/zymol2/
How do you disable AWD 96 Impreza?
Legacy777 replied to Killian44's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you put a fuse into the FWD fuse holder, then the AWD is disabled.
some inspiration
Legacy777 replied to leon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA little low for my tastes, but cool pic.
Front Left + Back Right speakers aren't working
Legacy777 replied to Jutboy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHmm....that's weird. Are you using the battery directly at the speaker, or are you tapping into the wiring behind the head unit? If you're using the wiring behind the head unit, it sounds like some wiring is screwed up.
just did seafoam on a 195,000 mile 2.2
Legacy777 replied to seanski06's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLawson, The older EJ22's do not have that hose. Or else I would have used that. So yeah, if you have that hose, use it....other wise use the PCV valve.
Legacy777 replied to Jutboy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat exactly did you do? Just replace speakers, install a new head unit, etc? Was the existing setup working properly?
ej fwd auto to awd auto
You're welcome to it. That's why I did the AWD & 5MT swap write-up.
So, which one is the thermoswitch (EJ22)
You may want to look at these pics. I've tried to label various sensors and stuff. http://www.main.experiencetherave.com:8080/subaru/images/injectors There's a few more pics here http://www.main.experiencetherave.com:8080/subaru/images/timingbelt/
Legacy777 replied to seanski06's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWith a normally operating PCV valve you have to seal off the other end of the hose that you've put the seafoam in. i.e. put your hand over the other end. That will cause the PCV valve to open and suck in the seafoam.
Sharp learning curve - FWD transmission
Legacy777 replied to Viking_Steel's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat's holding the inner and outer bearings together? The force provided by the axle being there, and clamped in place by the axle nut. Sure you could do what you say, but you will destroy the bearing, and possibly have the inner and outer bearings separate, and have your wheel along with the hub fall off and chunk up into your fender. Do what you want, but I as well as all the manuals I've read say do not put weight on the bearing unless the axle and axle nut is in place. Josh
I have some wiring diagrams from my swap write-up. Whether the wiring is the same for overseas models....I don't know. http://www.surrealmirage.com/subaru/swap/electrical.html Take a look and see if you can use anything, and if things match up.
legacy auto trans
Legacy777 replied to bvh56's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat thing you replaced is the flex plate. Only MT's have a flywheel. Have you verified that the torque converter is spinning with the flex plate through that access hole in the engine bell housing?
92 Legacy 235k - High speed humming
Legacy777 replied to danbennett2u's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo it does happen at speeds above 70 mph? Does it change pitch with speed?
Legacy Sapporo
Legacy777 replied to nixon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds like you're on the right path for replacement of parts. I'm not sure what kind of power or mileage you can expect, since most of our members are US-based. I do think there are some UK based subaru boards if you search around the net. As for upgrades, a fair amount of the goodies from the impreza line is interchangable.
Are you looking to convert the car from FWD to AWD? I think the wiring is there, however you could use an ohm meter and wiring diagram to verify connectivity between the ecu connectors & transmission plug.
Outback'05 datum dimensions
Legacy777 replied to arumis555's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd suggest asking over on www.legacygt.com/forums
Legacy777 replied to Viking_Steel's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe axles support the bearing, so once they are removed, the car really won't support itself on the wheels through just the bearing. The axle stub portion at least needs to be in there.
Legacy777 replied to seanski06's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou should use the PCV valve because the brake booster line only really gets one cylinder. Also, you really shouldn't have gotten rid of that black goo. It helps keep carbon from building up.
no stop lights, horn, blower mtr, 94 impreza
Legacy777 replied to aa8jzdial's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI know it may sound basic, but have you checked all the fuses?
Impreza exhaust to WRX downpipe?
Legacy777 replied to Caboobaroo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt may work. I really don't know the length of the older gen cars. On the legacies, the impreza exhaust are a little short. However you can probably make it work.
Stalls going uphill and acceleration
Legacy777 replied to brama's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou could try replacing the coolant temp sensor Have you checked the ECU for any codes?
98 impreza gearbox on a 92 legacy
Yeah, the 98 impreza gearbox should fit.
Legacy777 replied to Viking_Steel's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't know if there was any one thing. When you go to pull things out, you'll get an idea of any obstructions. If the car is getting crushed, getting things out should be easier
99 Subaru 2.5RS Transmission Upgrade?
The final drive ratio will be different, but other then that....it should be relatively swappable.
EJ22 headgaskets
Other thing to consider, you may have made the engine an interference engine now....
