Pulling engine with minimal disassembly
Legacy777 replied to Max Power's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe oil separator goes on the back of the engine. Here's a pic http://www.main.experiencetherave.com:8080/subaru/images/ej22t/05/DCP_4421.JPG Here's a pic of the plastic separator http://www.main.experiencetherave.com:8080/subaru/images/ej22t/04/DCP_4381.JPG What it does is help reduce the oil vapor the crankcase blowby gasses. It sort of performs a similar duty as an oil catch can, by providing a baffled restriction for the gasses to go by/around.
speedo died.. but an 'easy' fix
Legacy777 replied to nickb21's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo worries
low fuel light went kaputz
Found the info I was looking for today when I was testing my own fuel sender issues. The test does work, I tested it on my car. The only issue I can see is that it sounds like the newer cars do not have a separate device to turn on the low fuel warning light like the older cars. Anyway, here's the scan http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Legacy_Low_fuel_warning_light_test.jpg
Legacy777 replied to nickb21's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNope....the neutral switch does not prevent the car from starting. The neutral switch tells the ECU when the car is in neutral so the ECU adjusts timing and what not so idle remains steady. It doesn't really do much on a MT, but on an AT, it does. The clutch interlock system prevents the car from starting without depressing the clutch.
1998 Legacy occasionally not downshifting on hills
Legacy777 replied to misterstubbs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere's been some recent posts about this. Next time floor the accelerator, and it should downshift.
How much should I pay for used WRX wheels
Legacy777 replied to RedRum's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI personally wouldn't pay more the 200 bucks. I believe that's what I paid for mine.
Ej25 Vanagon
That'd probably be a good idea. How do you currently have the oil pickup configured? Is it stock? Are you using the stock subaru oil pan? There is a new oil pan design that has a secondary set of baffles. You can see the difference in these pics http://www.main.experiencetherave.com:8080/subaru/images/ej22t/06
New 06 WRX; Shudders at idle?
Legacy777 replied to OmahaScooby's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere's a guy that does amazing dent removal down here. I had him do my car a few months ago....then about 3 weeks ago so asshat at the airport put a huge ding and gouge on my rear driver's side door. I had the ding removed, but the paint is still buggered. Freakin people need to be slapped around!!
Transfer case - Dual Range 4WD
Legacy777 replied to AlpineRaven's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow does the transfer case sit on the trans? Are there any additional supports/subframe bracing that might interfere? I haven't seen any of the legacy/liberty transmissions that are dual range, so I'm not sure how they're setup.
Engine H4SO U5
Legacy777 replied to dpoppeli's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHmm....not sure about the US designation. Yeah the 20 pdf an hour thing sucks. You may want to ask the guys on www.legacygt.com/forums as they may be more familar with the manuals.
Cam interchange?
Legacy777 replied to Knichol's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOne of the members on the legacycentral board had his cams reworked for a reasonable price. I'd suggest searching the board, and you should be able to find his post. www.bbs.legacycentral.org
Ej25 Vanagon
What sort of pressures are you seeing out of that engine?
Dealership can't even figure out engine? problem with my Legacy Wagon
Legacy777 replied to thedena's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere's been some weird happenings with some of the 05 Legacies. You may want to check out www.legacygt.com/forums to see if anyone else has had similar issues. A friend of mine had subaru buy her LGT back because it would randomly turn off while driving down the road.
Timing Diagram/Marks
The marks should be similar to the first gen 2.2's. here's pics from my t-belt job http://www.main.experiencetherave.com:8080/subaru/images/timingbelt/
Legacy777 replied to OmahaScooby's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe white wheels look good Here's the latest pics I have of mine. Waxed it a 2 weekends ago. http://www.main.experiencetherave.com:8080/subaru/images/zymol2/ sorry for the thread hi-jack......
Legacy777 replied to Max Power's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can also build one of these http://www.main.experiencetherave.com:8080/subaru/images/ej22t/16 In action http://www.main.experiencetherave.com:8080/subaru/images/ej22t/18
'93 Legecy, won't start
Legacy777 replied to buddyepa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJohn, It's normal for the fans to come on and you to hear clicking if you connect the green connectors. However, the code retrieval procedure is different between the first gen legacies and the XT's. See my post above for recommendations on what to do.
Legacy777 replied to buddyepa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXReplace the knock sensor first. The plastic gets old, cracks, and the sensor shorts out. The O2 sensor may or may not be bad, but if you have not replaced it and your car has higher mileage, it'd be a good idea to replace it. The idle switch is built into the TPS sensor, and you can adjust the TPS to properly set the idle switch, if it needs to be adjusted. http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/TPS_testing3.jpg What I recommend you do is clear the ECU, drive the car around, and see what codes come back.
Legacy777 replied to buddyepa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAfter 1990 I believe, the ECU's did not get the little green O2 monitor LED light. All the first gen legacies need to have the black connectors connected to read stored codes in the memory. The green connectors provide a more "active" diagnostic check.
Legacy777 replied to buddyepa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes connect the two black connectors together. If you've had the battery disconnected from the ECU for an extended period of time (hour or so) more then likely any stored codes have been erased. You don't need to start the engine to pull the codes, if any are there. Just put the key in the ON position with the black diagnostic connectors connected.
Engine H4SO U5
Legacy777 replied to dpoppeli's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat year and model are you d/l for? From what I have seen in some models....the main difference is how the wiring is laid out.
something is Slipping....!
Legacy777 replied to AlpineRaven's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd recommend replacing the rear main seal and resealing the oil separator plate on the back of the engine. You'll need to remove the flywheel to get at these things, but it's a good idea to do that stuff while you're in there. I'd also suggest doing the pilot & throwout bearing as well.
Cam interchange?
Legacy777 replied to Knichol's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm assuming you're talking about the SOHC 2.5's. I'm not sure. I suppose it's possible, but I don't know for sure. You'd probably be better off just getting a set of used 2.2 cams reground.
I know there's a way to test it. I gotta dig through my manuals some more to try and find that procedure to test it.
Nope.
