8
The subaru specific haynes or chiltons manuals don't tell you squat about the AC system. I would suspect you overcharged the system. On converted r12 to r134a systems, you should run about 75% of the original R12 refrigerant capacity. Did you do the conversion, or did someone else do it? Can you give details on what exactly was done? What pressures are you seeing? A book I would recommend is the Haynes Air Conditioning book. It's very good, and has a lot of info.
To be quite honest, the older transmissions just had a screen, and no filter. The screen is in the pickup piping. Usually they stay pretty clean unless your tranny is eating itself up....in which case replacing the screen is the least of your worries. I'd really just recommend draining the fluid without removing the pan. If you want to remove the pan, I'd recommend calling your local subaru dealer and see if they can decipher which one you're supposed to have. Typically they should be able to determine which one you need by the production date of the vehicle.
Does the compressor clutch engage when the ac button is depressed? If not, I think you're on the right track with the issue being electrical. BTW, the search engine requires a minimum of 4 letters to search. You can search for 3 letter things by using an astericks a/c* or 2 letter word by using two astericks *ac* However you're going to get A LOT of other stuff if you just use the search term *ac*. For that search to be effective, you should add another term.
That part is a clutch damper. There should be a line running from the clutch master cylinder to the damper, and then to the clutch slave cylinder. As to what exactly it does..other then "damp" something....I'm really not sure. I did not install the damper when I did my AWD & 5MT swap, and I don't really see an issue to not having it on there.
The air control valve is the idle air control valve. To me, both of the codes retrieved wouldn't indicate/cause the problems you are having. I don't recall if this has been asked but are you aware that there is a bleed screw on the passenger side of the radiator that must be open to properly bleed the cooling system of air? If this has not been open, open it, and see how things go. However I'd probably suspect a headgasket or similar issue with the symptoms you described.
The R22 connector is under the rear seat on the passenger side. That scan is for the 90-94 legacies. As I mentioned, the low fuel light is triggered by a separate device on the older cars. It doesn't sound like that's the case for the newer cars....so the test procedure I posted probably won't work. Here's a pic of the fuel pump assembly http://www.main.experiencetherave.com:8080/subaru/images/ej22t/28/DCP_5290.JPG The thermister is the round silver looking thing attached to the bracket where the sender is located. Some additional pics http://www.main.experiencetherave.com:8080/subaru/images/ej22t/28/
