Selling 99obw keeping 99legLsedan move alarm?
Legacy777 replied to darkknight's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou should be able to attach them to the board. That would provide a long term storage spot.
Why no one talks about rebuilding a motor
Legacy777 replied to zzzasy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX\ That's correct.
Code reading on '95 Legacy
Legacy777 replied to Rob Kuhlman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDitto what Olnick said. You should be able to plug an OBD2 reader into it.
Feels like someone rear ends me when I am stoped
Legacy777 replied to jpsnowbumb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo you feel the car lurch when it's in park or drive? Does it happen immediately after you put the car in park? Or does it take some time?
Early 90's Impreza - Is headlight lense glass?
Legacy777 replied to Commuter's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat sucks that the legacies got plastic....they yellow and turn nasty over time.
4wd not working
Has the transmission fluid been changed/flushed recently? You may want to start with that. Have you tried putting the gear selector in 1 and seeing if you get more then one wheel peeling. Torque split will be 50/50 when the gear selector is physically in 1, and possibly 2. Are you having someone watch on the outside to see if the rear wheels are going? Also, you don't have LSD, so if you're only looking at one side, the other side could be spinning. josh
Legacy777 replied to darkknight's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat format are they in? You should be able to attach them to this post.
No horn
Legacy777 replied to bhelser's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOne of the engineers at work put a set of train horns under the body of his wife's excursion. One of the mechanical guys helped him size an air tank for a 2 second burst.
No horn
Legacy777 replied to bhelser's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.main.experiencetherave.com:8080/subaru_manual_scans/1990_Legacy_Owner_Manual_Scans/118.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/1990_Legacy_Owner_Manual_Scans/119.jpg You can d/l the whole manual in pdf if you want. http://www.main.experiencetherave.com:8080/subaru_manual_scans/1990_Legacy_Owner_Manual_Scans/ It's for a 90, but should be the same/similar.
Legacy777 replied to Commuter's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPretty sure the US models got plastic, not glass. I know this is the case for the legacies.
Lift points for engine removal, 98 Forester
Legacy777 replied to Top's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen I pulled mine I used a chain, and connected it to the loop/plate that the alternator bolt goes through, and the hole on the back. There may be a pic or two in these pics http://www.main.experiencetherave.com:8080/subaru/images/ej22t/
STOLEN 1992 Legacy Turbo (touring wagon)
Legacy777 replied to SuperRallyRoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou may want to post in the meet & greet forum, the legacycentral bbs, and the northwest forums on nasioc.
99 Forester Keyless Remote (Replacement)
Legacy777 replied to bbridges51's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbump. Anyone have any info to help Brian?
Outside air temp sensor question....
Legacy777 replied to soobcollektor's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo you know how the old temp sensor is wired up? I would assume if they're wired similarly you could use it.
Legacy777 replied to zzzasy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRebuilding a motor and doing it right isn't overly cheap. Most people aren't going to have the tools & skills, so they'd just rather replace it. I rebuilt my ej22t this past summer and subaru motors are a little more complicated then your standard inline engine IMO.
Finding Part Numbers for 2000 Outback Sedan
Legacy777 replied to ThomasJacobs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttps://www.subarugenuineparts.com/oe_parts_cat.html www.subaruparts.com
Looking for rear wiper gear
Legacy777 replied to tmscarborough's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTry a local junkyard or online www.superrupair.com http://www.4subarusuzukikiaparts.com/
IHI Turbo Sale
Thanks for the explanation. I haven't decided what my final turbo plans are, but I'll keep you in mind.
Anyone using 5W-30 oil on 2.2L Legacy?
Legacy777 replied to illanrob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat year 2.2 legacy? The owner's manual says not to run 5w30 if you drive at highway speeds, higher rpm for long periods of time. Hogweed, care to elaborate why 10w40 is the worst oil?
Transmission Fluid Leak
Legacy777 replied to FlameSkyeFox's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXShouldn't be too bad. You should be able to drop the driveline, pull the seal, put a new one back in, and reassemble.
Aftermarket Steering Wheel
Legacy777 replied to mattyg41383's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it fits a later model subaru, it should fit your 90 legacy. Be aware that you will lose the controls for cruise control, and the horn may not be right....things to keep in mind.
2005 Baja Trailer Wiring Adapter
Legacy777 replied to TWClark06's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot sure what to tell you. Have you called the dealer to ask for a wiring diagram? You can d/l wiring diagrams from subaru http://techinfo.subaru.com
Faulty Fuel Pressure Regulator?
Legacy777 replied to iajw2k2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt sounds like a faulty coolant temp sensor. The only reason I can see them thinking it's the FPR is that it's not keeping the pressure built up, but I'd suspect the coolant temp sensor over the fpr.
Impreza EJ20E non turbo AWD tranny?
Legacy777 replied to Gonzalo Bravo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat sort of info are you looking to know about the transmission? You should be able to swap a WRX motor into your car. You'll have some wiring issues, but it should bolt up.
IHI Turbo Sale
Just a quick question about the description on your website "The VF34 is similar to the VF30 but has improved spool up due to roller bearing design. This is the standard turbo on the New Age Sti RA Spec C. This turbo yields good throttle response and mid and top range power. It also uses a ball-bearing center section, which reduces friction and positively locates the shaft-wheel assembly to improve spool up and avoid turbo failure. " How are the bearings configured to utilize both roller bearings & ball bearings?
