Legacy Twin Headlights
Legacy777 replied to Cret's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe ones in the picture were the ones I was referring to as being custom made.
Legacy777 replied to Cret's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthere's some for the second gen legacies, but I haven't seen any for the first gen......I've only seen one, and it was a complete custom jobber.
Checkin the TCU on a 4EAT
Legacy777 replied to haru182's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXso are you saying the power light does not illuminate? Other then a select monitor, there's no other way to check the TCU codes except with the power button procedure. There's not going to be a fuse for just the power light. If it's not working and the rest of the bulbs on your dash are, the bulb is probably burnt out, in which case you'd need to pull the combination meter out to replace the bulbs.
93 Legacy Misfiring??????
Legacy777 replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can pickup a new coil for like 60 bucks. On your diagnosis, with the design of the coil pack, there is no way for one side of coil to go bad. There are two coils in there. The front coil handles the front two cylinders and the rear coil handles the rear two cylinders. If the coil went out, both front or rear cylinders would not work, or not work properly. The only way I could see one side going bad was if there was a massive crack or something causing a disproportionate flow in current. If that was the case, I would think it would show up by measuring the resistance. Just to verify the resistance values, For testing the primary side, you meased from terminal No 2 on the connector of the coil pack to the Number 1 & 3 spots on the coil itself and got around 0.7 ohms. The next test that the fsm gives is confusing, but the readings should be done solely on the coil pack female connectors. 1 & 2, and 3 & 4 according to the diagram. http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/coilpacktest.jpg If anything is out of spec, replace the coil pack.
Auto Trany Lagging Shifting Into Forward Gears
Legacy777 replied to VLOHMB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPlease refrain from posting in all caps. It gives the impression you're yelling.....which maybe you want to be after the problems....but in the future please don't post in all caps.
Freshly zymol'd
Legacy777 replied to Legacy777's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHey Gilles...it's alright.....yes I have been a little tired lately....I'll be ok :-) The wheels are made by racing gear, model is M7. I have no idea if they are still even in business. I've never personally seen these wheels on another vehicle, ever. I've seen them on a prelude on the net, and I've only seen wheels by this manufacturer one time, and that was at a speed shop in seattle area. I got them back in 97, so they are pretty old....
Headlight Yellowing
Legacy777 replied to EOppegaard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHere's the thread in question....at least that I did http://www.bbs.legacycentral.org/viewtopic.php?p=5821#5821
Location of Loyale A/T Trans Computer?
You'll probably get more hits on the old gen side.
Freshly zymol'd
Legacy777 replied to Legacy777's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks for the compliments guys :-)
Oil question
Legacy777 replied to Reason01's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd probably say just stick with dino oil
Oil question
Legacy777 replied to Reason01's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhow many miles are on the engine?
Exhaust fitting
Legacy777 replied to Reason01's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI know this is for the BC legacy, but most of the stuff will probably hold true for yours as well. http://www.bbs.legacycentral.org/viewtopic.php?t=640
Fuel filter change help
Legacy777 replied to kirk25h's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUnder the rear seat there is a connector for the fuel pump, it's on the passenger side under a little foam protector. Disconnect that, start/turn over the engine to relieve fuel pressure. Then do the work on the fuel filter.
Freshly zymol'd
Legacy777 replied to Legacy777's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXtrailer huh......
Freshly zymol'd
I know I haven't posted much lately.....life's been rather crazy....job, etc, etc. I've been just trying to keep the car running and fix the little issues. I finally got around to waxing it and getting it fully cleaned up after a year here's some pics http://www.main.experiencetherave.com:8080/subaru/images/legacyzymol/
Radiator concearn
Legacy777 replied to applegump's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcheck for a crack on the pasenger side plastic end cap. The crack would be facing the front of the car.
Legacy MT Ident # to Gear ratio
Legacy777 replied to ScoobyDoo1061's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwithout checking my books for the decode key, as far as I know all the normally aspirated MT 90-94 legacies had 4.111 gearing. I'll see if I can find the decoding for the trans.
Red spark plugs
Legacy777 replied to subaru_dadeo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would tend to agree about the reddish plugs and it being a certain type of fuel or additive. The timing, you really can't adjust the timing, the computer sets it based on varioius sensors, including crank & cam. knock sensor, if it's never been replaced it's probably the old style which are known to crack and become oversensitive. There is a new style out that is supposed to alleviate these problems.
Strut tower brace for 94 Legacy
Legacy777 replied to ringe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat's special about the wagon bars?
Tranny swap
Legacy777 replied to Reason01's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFor your car, Disconnect the battery for 1 hour, reconnect, start car, make sure accessories are off, let it idle for one full warm up cylce, shut off car, and then go drive. I've done it without the warm up cylce, and it seems fine with it....so I'll leave that option up to you.
Legacy777 replied to ringe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXpretty much any of the strut tower bars for the gc impreza should work on the bc/bf legacies.
Aftermarket wheels/tires for 1994 Legacy non-turbo.
Legacy777 replied to ringe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes they'll work, you can figure out your new tire size with this http://www.miata.net/garage/tirecalc.html
Tranny swap
Legacy777 replied to Reason01's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXjust curious, have you reset the ECU recently? You may want to try that....you may be experiencing subaru's famed hesitation. If you reset the ECU and it gets better, then that would probably tell you if it's a hesitation issue or some other mechanical issue independant of the ECU maps.
Tranny swap
Legacy777 replied to Reason01's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe autos do have low end grunt.....I'd suspect some sort of problem... but to answer your question, read this on the tranny swap http://www.legacycentral.org/library/transmission/convert.htm you didn't mention what year/model legacy you have, but without knowing too much about your legacy, I'd say there's 99.9% chance the WRX tranny will not have the same final drive ratio as your legacy. So....you would need a new rear diff as well. Other solution would be to find a tranny that has the same gearing so you don't have to swap rear diffs.
Where do I dump a used Fuel Filter?
as mentioned.....dump out all the gas you can, and throw it out. If you want to let it sit for a little bit for more of the gas to evaporate, that's fine.
