Esteban32696
Everything posted by Esteban32696
gas mileage challange
Esteban32696 replied to schreckman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I might win this contest !! '88 Justy,2wd., 240,000 miles, runs like a champ. I go to Daytona Beach, & back= 46.4 mpg. -
Now, why did they do this ????? http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2467472903&category=6467
'88 Justy carb problems
Esteban32696 replied to Esteban32696's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Help ? -
Wanting to change from 12" to 13" wheels on my 88 Justy. What wheels, if any , will bolt right on ??
I have an '88 Justy, 2wd, with carb problems. It runs pretty good at speed, but will not idle. I do know that I need a thermostat. Never really warms up.Screw adjustments are not the problem. Parts stores want a ton of money for a rebuilt carb. Any other options????
1988 Justy, original engine, 3 cyl. 235,000 mi.
As stated above, changing to a larger diameter tire size can achieve the higher speed with less RPM's. But a trade off is more top heavy, finding rims & tires that fit, & inaccurate speedometer. I don't know if you have 12" or 13" tires, but use the chart http://www.miata.net/garage/tirecalc.html Just use your original tire size on the left & try different sizes on the right. At the bottom, you will see the difference in %.Also, cut back speed 5mph or more will help.
What might this XT be worth?
Thanks for all the advice.Supposedly the air suspension, turbo, & tranny are fine. I am going to try & go look at it first. -
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2455487270&category=6467 I may bid on this car, but don't have an idea of its possible value. I live about 7 hours from Miami, where it is located.Thanks!
Help! My '88 Justy Just Keeps On Dying!
Esteban32696 replied to Gene's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It does sound like it is in the distributor to me, also. But, the only fuel filter is that one above the panel under the driver. That is the fuel pump there with it, as well. If it is bad, there is a universal Purolator electric fuel pump that is almost identical to it.It is 3-5 psi & you just need some minor fitting changes & it works fine, but is noisier than original. -
I will need a new car soon, & it has to be able to tow about #1200 all on level Florida ground, inclines on boat ramps, etc. Will the OB Sport be able to do this. Auto or stick shift?? How dependable is the OBS?I like the 98-2000 Forester but am wary of the 2.5. Are there any years that the 2.5 is better? Thanks!
Craig, I am not sure what that hole is for, but mine is just a smooth bore & plugged at the other end.Nothing in there to leak. Use a mirror & flashlite & you can see in it. As said before, mine has always leaked from the distributor & that may be where your oil is coming from, too. Just a few drops of oil seems to make a mess, but never do I add any oil. Mine has 231,000 miles on it & never had the head off. If yours leaks a lot, you could see about getting the valve cover gasket, an O ring on the distributor shaft replaced, & anything else that may be leaking. These ARE a 1.2 Fuji[ Subaru] designed engine, in America.
I am not exactly sure about your description of where the leak is coming from.These engines DO leak thru the distributor shaft & that gets on everything below it. Maybe that is it????
The Justy is still alive and well
Esteban32696 replied to bajavwnsoobnut's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I can only attest for my Justy.1988 with 231,000 miles. Still has original starter, alternator, CV joints,just replaced original clutch, never removed heads, does not use oil. Oil changed every 3-4000 miles & gets 38mpg city/ 44 highway@ 60mph:D
