Everything posted by msteel
Returning after years...
Thanks. Looks like a pushbutton 5 speed will have to do for now. This morning we towed home an '87 GL turbo parts car and that is what it has. Hopefully with the parts car the turbo swap will just be a lot of "doing" and not so much figuring out what to do and how.
I haven't posted here for years, partly due to login issues. @Turbone fixed those for me recently (thank you!). All the Subarus I had before have moved along, but I have more than ever before - 2006 Outback Wagon, 2004 Legacy Wagon, and the newest arrival is a 1994 Loyale AT my son just bought. The engine is suspect from a large oil leak that resulted in the engine's being run low on oil. We'll see about the leak and then if the noises clear up. His goal is to put a dual range MT in is but we'll see how easy that is to find...
2007 Outback A/C compressor clutch?
msteel replied to msteel's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX(short version) Bingo. (Long version) My meter was acting funny so I replaced the batteries. Now it says the coil is 4.5 ohms. I jumped the coil to the battery and the clutch clicked in (but engine wasn't running) Looked at the my Haynes manual for wiring diagrams to locate the relay. Somewhat helpful but the diagram shows a different relay block than I have. Finally found the relay by.....um....actually reading the cover to the relay block under the hood. Removed AC relay, took voltage readings to verify the pressure switch was supplying power and things looked good. Swapped the A/C relay with the second radiator fan and, I now have working A/C and non-working radiator fan. Alas, none of the relays in my junk pile match (mostly they are from my '94 Loyale parts car), so I had to order one from the local parts store.
msteel replied to msteel's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI did read the voltage on the harness (unplugged the coil and read the connector) and open circuit the coil connector was getting decent voltage. The voltage would come and go as the A/C button was turned on and off. So it seems to me the control circuitry is asking the compressor to run. I tapping the front of the clutch did not produce any effect - it did not engage, or try to engage as far as I could tell. I think my next steps will be to one or more of the following: * Check coil voltage with the coil in the circuit to detect excessive voltage drop in the supply relay or wiring. * Bypass the supply wiring with a fused line straight from the battery and see if the clucth engages under those circumstances.
So, I think my A/C compressor clutch is bad (2007 Outback Wagon 2.5i Basic). I'd like some comments about whether my diagnosis is reasonable and any "gotcha's" in the replacement process. I noticed my A/C quitting - intermittently at first then as time went on less and less often. It seems like it is more likely to work when the engine is cold, first thing in the morning. When the air works it cools well, but it doesn't usually run very long before it stops. I thought it might be low on refrigerant, but I put a gauge (borrowed my dad's cheap one from a refrigerant can) and the low side read 150psi, so I didn't put in any refrigerant and looked elsewhere. When it doesn't work the clutch is does not spin. Once when it was not working, I measured the voltage to the clutch coil and it was plenty - I think it was around 14 volts - but that was no load. The coil resistance measured 20 ohms, and from what I read several places on the internet the coil should be more like 3-5 ohms (really, the thing pulls 4 amps?). Any other diagnostics I should try before I order a clutch kit? It seems Subaru doesn't sell the clutch separate from the compressor but I do see an aftermarket kit on amazon and the coil by itself on eBay so there are some sources. Am I likely to have a pressed on pulley and have a hard time getting the pulley off with the compressor in the car? Thanks.
Subframe likely to be damaged in read end collision?
msteel replied to msteel's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, my sister got checked out and was sore for a few days but seems fine. As to her car, I don't have pics and am not at the car at the moment, possibly could have pics later today. The hit was square on. The center of the bumper is pushed in at least 6 inches, the hatch is crumpled and the spare tire area is affected at least enough that the hardboard cover won't sit flat anymore. The hit was hard enough that the car also sustained significant front end damage as it was pushed into the car ahead (likely would have bumped without damage without the rear hit). I had not been aware of the subrfame recall until a few days ago and do not know if the car had the cleaning/rusproofing done under the previous owner. I can still ask him in case he remembers. Otherwise I suppose I'll have to have the dealer look up records?
My sister has the same 2002 outback as me. Mine has a rusty subframe that is starting to make me nervous. Hers is not rusty but it got rear ended a week ago and is totalled. If she buys it back from the insurance (she knows someone interested in the engine) I am considering if it would be wise to swap the rear subframe from her car into mine, or of it is likely to have been damaged in the collision. Anybody seen enough wrecked Outbacks to have an opinion?
Losing brake fluid without obvious leaks
msteel replied to msteel's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk, well I finally got this thing back together. As several people suggested I put new flares into the lines under the rear seat. From there I ran a length to the factory unions and this part was pretty easy. I had bent premade lines before, but I hadn't done any double flares before so it took some practice on scrap and old lines to feel like I knew what I was doing. From there the line to the passenger side wheel was pretty straightforward. But I found the driver side line to be a royal pain as it went practically over the gas tank and had obviously been installed at the factory before the tank was put in. I finally decided on the tactic of bending the line as I fished it rather than ahead of time. This worked ok, but getting the bends right was more difficult that way. Of course the rust is the reason for the line failure, but the rust also meant rusted bolts, trouble getting access panels off, broken rusted bolts, drilling and tapping out a rusty bolt, etc. I told my wife several times that when her dad offered me an amazing deal on his current Outback (which is how I got this one) that she should remind me how much I hate rusty cars. I'm just glad it's back running after a week.
msteel replied to msteel's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOK, well the leak is obvious now. It is at the couplings ahead of the right rear wheel. All four lines are pretty well rusted at the couplings, although the two that come from the front are in pretty good shape up until then. It it reasonable to put a new flare in those lines? Or am I faced with the joyous task of replacing the lines all the way from the proportioning valve under the hood?
msteel replied to msteel's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI hadn't thought of the fluid coagulating, that would explain not seeing a leak. I guess I'll have to pull the wheels then and check that. Even though it's a southern car now, it does have rust from its early years in New York State, so I'll have to keep that location over the gas tank in mind. My previous Loyale had an exciting sudden brake line failure from a rusted line, and I'd rather not repeat that. There is only one vacuum hose to the booster, right? I didn't notice any signs of wetness when I checked it. The ABS unit does bear some investigation. It had a small amount of some kind of fluid, but I was thinkng it was engine oil that got there during the recent valve cover gasket job (had a misfire and found the plug seals were bad and plug wires were oily). I'll have to clean it off and see if it returns.
My 2002 Outback is losing brake fluid. I keep having to top it off. I have put in at least a pint in the last few weeks. It seems like it pretty much happens only in colder weather (which in this context is around freezing). I don't see any obvious leaks - no fresh spots on the ground. On a couple of occasions I have pumped up the brakes after shutting off the engine and hours later when I got back in the pedal was still firm. To me that makes it less likely I have a leaky line (unless the ABS keeps pressure even when a wheel line leaks in those conditions?) I pulled off the vacuum hose on the brake booster and didn't see any sign of fluid in the hose - so it didn't seem to me like the booster was leaking into the manifold. Any common places I should look next for this leak?
Outback 2.5 Heistating/Backfires While Acclerating
msteel replied to WeezWagon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust fixed these exact symptoms on my 2002 Outback. It was hesitating and then as the problem got worse, I started having small explosions in the exhaust. One cylinder was not firing and unburned fuel was getting into the hot exhaust. I replaced the plugs and wires (and the valve cover gaskets since the seals around the plugs were leaking oil onto them) and all was well again.
Front axle won't come out of hub...SOLVED!
msteel replied to msteel's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSuccess! The combination of this loaner tool (OEM puller 27037) from Auto Zone: And some hammering with an 8 pound hammer got it loose. Once it was out, the new axle went in easily. I disconnected the knuckle from the strut instead of the ball joint because I was also replacing the struts. And it needed aligned anyway.
msteel replied to msteel's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat sounds like a very safe thing to do. Aside from the quality of the HF puller, would a good puller of this style be made to be hit? In any case I'm out of time until Monday or Tuesday. Maybe the answer will become clear by then.
msteel replied to msteel's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnd I thought that now that I've left EA82 land for Legacy land, the axles would be tons easier :-\
msteel replied to msteel's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks for the suggestions. P'Blaster has been on it several hours, but because the hub is still on the car it's not quite in a position to soak. I'm considering bringing the knuckle inside because I already have the strut loose and all I'd need to do was disconnect the ABS sensor and one end of the ball joint or the other. I'm a bit afraid I'll need a drill and a tap to get the pinch bolt out... I'll have to see about Kroil. I've seen it but never used it. I also have some "Berkebile" I think, was in the car when I bought it from my father in law. Never heard of hammering on the screw of the puller. That would at least give me something stable enough to let me use both hands on the hammer.
[EDIT - solved!!! See below] Anybody got any hints for getting a stubborn axle out of the hub? I have the nut off, and have the inner end of the axle disconnected from the transmission, but I can't get the outer end out of the splines in the hub. I've tried beating it out, and I have tried a 3-jaw puller, which resulted in breaking the puller (Harbor Freight...) The car is a 2002 Outback. I suspect rust is involved...
Show off your roos Mileage!
My '92 Loyale 4WD wagon is approaching the 183,000 mile mark. It will take a long time to get to 200k because the Sienna gets all the long trips these days.
A/C Question
Check that the sensor that tells when the compressor is running is there and properly aligned. If it is not detecting compressor rotation then the clutch will disengage and the air won't be cold (because even though the pulley is turning the compressor is not). I didn't see that sensor in the pictures. Now, my AC is the other one where the alternator is on the outside of the compressor, so I don't know where it is supposed to be on your system. But on mine it is on a bracket that goes over the belts and hangs over the compressor. The little "arms" on the compressor pulley pass by and it detects rotation magnetically. I had mine come loose once while in Florida and was woried that it would be a very long trip.
88 EA82 Wagon Won't Start
It does sound like it could be a timing belt, with a valve stuck open on each head. But, if after all this there is still spark, then that means the distributor is turning, so the belt isn't broken in that case. If the cam is turning and you still have 0 compression, then it's the head gasket or something worse.
Have you rechecked the spark timing after the distributor was off?
Crank pulley...what about a gun?
+1 for the Thing in the Flywheel. Until I got my father in law's Special Tool Made For That Purpose, I used a steel rod that came out of an old floppy drive. But if you use such an article, be sure you don't drop it into the bellhousing. If you do drop it into the bellhousing, do not try to pull it out with a magnet. Do not try to separate the engine and transmission. Instead, note that there is a removable plate at the bottom of the bellhousing. No need to ask how I know what not to do in this situation. That was at least 200 posts ago .
SPFI "cold" weather won't start - now running
Functionally, yes. But even that one has the collector on the tab, so it can't be mounted directly to the grounded heat sink.
Yeah, sorry. But the big thing is that the round connector actually feeds 12v from the coil on to the condenser, not into the coil. So if you unplug it you won't read any +12 on the harness there. The rest of the stuff is only going to be useful if you need the part today, can't get the real thing, and have the resources to build something functionally equivalent.
Jacinta is running!!! I got an ignition amp from mdjdc and got it in this morning. Jacinta fired up the first time. Because it is pretty warm (40's) this morning I am not yet convinced whether the amp was the original problem. The fact that it started right up does support that because a fuel issue would have probably required some cranking. Time will tell. Along the way I learned some more about the ignition amplifier module and how it is wired. I'm sure many here know all this already but some this info might be of interest to others. The two-bladed connector on the ignition amp is the input to the coil. It carries the ignition timing signal from the ECU (white/yellow wire) and power (black/white wire). As best as I can tell the amp module itself is mostly an NPN darlington transistor with a protection diode, in a TO-3 case. Electrically, this is a common combination. However, because the TO-3 case is grounded through the coil bracket, it needs to be the emitter terminal on the transistor. This is is unusual since every TO-3 transistor I looked up had the collector connected to the case. The ECU signal goes to the transistor's base, and the power simply passes through the amp module to the + side of the coil, and from there through the round connector to the condenser (capacitor) which is taped into the wiring harness. The collector of the transistor goes to the - side of the coil and becomes the tach signal. It also goes through the round connector to the regions beyond. The emitter of the transistor is grounded through the heat sink on the coil bracket.
