Everything posted by Dr. RX
How many miles on your conversion?
The odometer had 85,000 miles on it when I did the conversion, I just passed 120,000 miles this morning on the way into work, so that means that I have 35,000 miles on my conversion with very little (nothing unusual) problems. So, how many miles do others have on their conversions?
Who has schematics for EJ stuff? pinouts for the ECUs?
I think it would be a lot easier to match up the engine wiring to to the Impreza harness then matching up the Legacy harness to the Impreza.
Maybe be a little more expensive, but did you ever think of going over to Aaron's and getting a 2.2 Impreza wiring harness?
93 Turbo Legacy Sedan Turn Signal Help
Dr. RX replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXProblems like this is why I hate working on electric problems. It just doesn't seem to make sense, but it happens. Worst case senerio, replace the fuse box (which is a real pain).
10 Year Airbag Inspection
Dr. RX replied to the_bard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell, it wasn't a wrecking yard, but it did require a rebuilt title. I don't believe that there is any law that states if your car was equiped from the factory with air bags that the car has to have them after rebuild, if fact some cars come with a switch that you can turn the bag system off if you want to now. I can't believe how much damage is done by air bags deploying. My car would not have had a broken windsheild if it weren't for the air bag. When the one on the steering wheel deployed, it broke something that caused the horn not to function until you replaced the turn signal and wiper switch assys. The inspector also didn't check to see if the horn honked, which it didn't at the time of the inspection.
Dr. RX replied to the_bard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's funny, when I took my car in for it's inspection (Yakima), they never looked at that, in fact, I removed the bags in my car, the covers are there, but there is nothing under them.
Well I'll have to look in the motorhome, my personal manuals (93 to 97) have had the wiring diagrams combined so that I have a complete 1996 wiring diagram (well as complete as possible). In the motorhome I have all those manuals that Ken and I got from that guy in Canada a few years ago, I might have the early Impreza stuff still.
Last PRG rallycross of 2006---Oct. 15th.
Where did you hear that? The web site still has it listed for this Sunday. Never mind, I found it, http://forums.nasioc.com/forums/showthread.php?t=1105398 .
Thanks for the offer, but I need to get my car back on the road, if it isn't fixed on Saturday, I'll still be working on it on Sunday.
If I get the 96 running (darn cooling sensor problem), I might run down for the last event of 2006 (spectator only).
dohc 2.5 heads on a 90 ej22????
Dr. RX replied to offroadsubaruguy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you look on the intake manifold, just to the front of the trottle body, you'll see the 5th injector. I was put there for enrichment during certain engine conditions, it was later discontinued as they learned how to program the ECU better.
Dr. RX replied to offroadsubaruguy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLooks great, I'm planning to put JDM EJ20G heads on my EJ22T engine, that would be closer to what the EJ22G was. I probably would use the EJ25 heads if I didn't have a set of EJ20G heads already. Notice that you remembered to paint the timing belt cover red too.
It's Halloween! My favorite!
Sorry, going to have to pass this time, don't think I could make the drive back home in time for work on Monday.
ej2.71 stroker
What engine are you starting with? Why do you think you would have to do anything to the ECU?
Cracked piston sleeves?
Dr. RX replied to entrancetoexit's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWas it a Subaru dealer?? I ask because any Subaru trained mechanic or anyone who works on Subarus will tell you that Subarus don't have sleeved pistions. They have a block with the cylinder for the pistons bored into the block. The only time there would vere be a sleeve is if the psiton walls were badly scored by a broken rod and they had to sleeve that one piston hole. Get a second opinion from a reputable mechanic.
Ebay EJ20G
Here is one link, http://grahamberry2.co.jp/impreza_gc8/ and here is another, http://www.catherineandken.co.uk/sti/engine.html . I hope that they help, as you can see, information differs depending upon where you look. By the way, this is only for engines in Imprezas, not Legacys (Libertys).
Ebay EJ20G
'G' is the code for turbocharged DOHC, 'T' is the code for a turbocharged SOHC from 1985 to 1996 and on for some engines. For example, EA82T, SOHC turbo engine in EA82 series cars, the EJ22T, SOHC turbo engine in US Legacys from 1991 to 1994, the EJ20G, DOHC turbo engine in JDM (and others) Legacys 1989 to ??? and Impreza WRXs 1993 to 1996, with the exception of the 22B, it had the EJ22G, a 2.2 liter DOHC turbo engine. What information do you want to know about the engine.
I hit a deer.
Dr. RX replied to Tbird Man's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPrice will be all over the place depending upon where you get the parts. A 'L' hood is baiscally one piece, the RS/OBS hood is made up of 4 basic pieces, the hood, the scoop assy and the two vents, At a wrecking yard, you might be able to get the RTS/OBS hood at the same price as a L hood, but most Imprezas that I have seen in a wrecking yard have front end damage, so good luck looking there.
I don't know, for some reason I was thinking that the engine wiring on the Imprezas were different then the Legacys, maybe it's just the body wiring.
Did they have an EJ22 Impreza at PAP???
Ebay EJ20G
JHot is a pretty reputatble company, I have purcahsed many things from them, all quality goods. If it weren't for the fact that they are on the other side of the USA from me, I would have probably purchased more, including this engine setup.
Lagacy diff, 4.44?
Dr. RX replied to Phizinza's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLegacy/Liberty came with a 4.11 rear diff, if you could find one with a manual tranny, thne you would have all you need, that is assuming that the Legacy/Liberty D/R portion of the tranny does not effect that pinion gear.
Lagacy diff, 4.44?
Dr. RX replied to Phizinza's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't think it will work, all of the 4.44 ratio rear diff I know of are in R180 diffd, I believe your old Leg has an R160 diff. As for the tranny, the 4.44 ratio trannies are in Imprezas, but I'm not sure if they are the same as your Liberty/Legacy tranny. The pinion gear in the tranny is an important part of the tranny, and requires taking the tranny completely apart to change it. I'm not sure if the D/R tranny would have the same type of pinion gear as the Impreza trannies.
Lagacy diff, 4.44?
Dr. RX replied to Phizinza's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat are you trying to do? Most gear sets (ring and pinion) are matched sets, they need to be replaced together. Why are you looking for a 4.44 rear diff, are you installing a 4.44 ratio tranny? The tranny and rear diff need to match. (I'm assuming by "crown wheel" you are talking about the ring gear)
Boiling Coolant 2.5l fresh headgaskets Help!
Dr. RX replied to wiwrx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow soon after puring oil into you engine did you measure the oil level? I you did it soon after, then all the oil had not made it's way to the pan yet, that would amount to a small change in the oil level. Also, and it may not be needed with these head gasket, did you get the heads re-torqued? I'm not all that familar with the EJ25, but I know in the EA series engines, most of the time that engine over heated, it was not the head gasket that blew, ususally it was the head gasket that blew as a result of the engine over heating. What caused the engines to over heat was the radiator, they usually got clogged and cause poor circulation and cooling, thus causing the engine to over heat. You might want to look at the rest of the cooling system. Take it someplace and get the system checked.
