Everything posted by BlindSight
before you shoot the pump..replace the sending unit...real easy to get too and just turns right off with a wrench or pliers even if your desperate...doesn't cost too much. Had the same problem with my loyale, everything seemed to be running fine but the pressure just started reading low, then eventually it started dropping to 0 at idle, I just replaced the little sensor/sending unit and it jumped back up to normal on the gauge. my $.02
Very interested in a hood with a scoop or spot for a wrk scoop to be mounted for an EA82.
Brat & XT6 CarbonFiber Hoods
BlindSight replied to Gravityman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Am really interested in a CF or even FG hood for my EA82, would also love some bolt on fender flares...I think the fender flares would be a big hit with all of the offroading EA82's out there, something so if we have to cut our fenders for a little more clearance it will cover the areas...nothing too huge but maybe an inch or two of added flare...anyways, any updates? -
bumpage, any updates? Would it be easier if I called?
Rotors & Pads? ACDelco, Wagner, advice?
BlindSight replied to BlindSight's topic in Old Gen.: 80's GL/DL/XT/Loyales...
alright, will do on the pads, any reccomendations on the brand of rotors? -
will be replacing the front rotos and pads as well. -
why isn't there anyone around where i live that will powdercoat rims for $20 each!? everywhere around here wants 70-100
havn't eard of those in the us. Anyone else? -
So will the optima handle running offroad lights and a nice sound system for a fairly long peroid of time at low speeds or idle? How do they handle running a sound system with the car off for a while? Anyways, what im getting to is...dual battery setup or single optima?
...new pics sooner than later.....reallly interested in seeing these done
Im thinking about 2toning my blue wagon...so far ive taken off the trim and gotten black plastic trim holder things and pushed into the holes sealing them from rain and it kind of looks like rivits down the side similar to nissan trucks and such....probably going to use some of the spray on undercarriage rubberized coating on the lower half.
so going to do the rear disk brake setup in my wagon and am trying to figure out what rotors and pads i should go with, will probably be either the ACDelco or Wagner brands because thats what I can get through my shops account with Oreilly. So what does everyone reccomend? Which rotors? Which pads/what type? Semi-metallic, non asbestos organic, etc...? Someone should do an official collection of reviews on this subject if they havn't, and if they have, where is it? THANKS AS ALWAYS
still havn't heard anything yet, any estimate on when I should be expecting my lift? sorry to be so annoying but like i said, i went ahead and got new tires for my 15" rims that i cant use untill i lift it...and all of my tires on the car now are going to pop at any moment...had one blow out yesterday so there goes my spare...so im pretty screwed if any of my other tires go....so just an estimate would be nice...if its still going to be 3 weeks or more I will borrow a car to drive until then or something...thanks again. hope to hear from you asap.
87 carbed EA82 Backfire :(
well its kind of a roar/multiple backfire/popping noise i guess you could say and it hapens consistantly whenever i let off the gas/shift. -
so my car is idling fine now and all but after adjusting everything my car is fackfiring alot...pretty much everytime rev up and let off and when im shifting gears. I am assuming i need to fool with the idle air screw...what should I do?
pm sent.
so I FINALLY fixed my stalling/not wanting to idle problem....there was some small electrical conection under the aircleander on the drivers side that was disconnected...pluged it back in and like magic...it holds its idle now when im not accelerating...no idea what the connection goes to...but thank goodness its back together. THANKS!!
carbed EA82 oil in aircleaner!?
changed out the pcv valve, air filter, and blasted out the hoses and lines and such with air intake system cleaner and after a few days ive been keeping an eye on it and there still is a tad bit of oil coming in but its barely noticeable and is a HUGE difference from what it was. thanks for all the help!! -
New Subaru (EA82) owners: Things to fix
BlindSight replied to Syonyk's topic in Old Gen.: 80's GL/DL/XT/Loyales...
bumpage. -
I wish that I have had one of those situations myself but no luck for me
