Everything posted by xoomer
Loyale... 2 Alternator laters, still no charging
xoomer replied to bfdtech's topic in Old Gen.: 80's GL/DL/XT/Loyales...
NEVER TRUST A DURA TESTER, THEY DO NOT TEST FOR LOADS, and in general do not work well! When a customer Comes in to my schucks With a starter or alternator problem I prefer to test it in the car. because then you can see the condition of the engine compartment to offer solutions. -
The tragic and untimley death of Vicki
xoomer replied to CzarMohab's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Holy Crap dude!!! Take care of yourself. -
Look what followed me home..56k Warning.
xoomer posted a topic in Non Soob Cars and Bikes Discussion
88 Ford ranger Auto** with a 2.3 $380 See attachments... *still havn't figured out how to post the pictures. **needs Automatic Transmission -
I may take you up on that.... I'm gonna try a filter and some lucas stop slip... since it is 2 quarts over full.
Whats it gonna cost me?? I'm broke as hell. I went to tacoma pap and pulled a tranny out of an aerostar... and then found out that it wasn't gonna work because two pin lock up vs three pin lockup... I'm headed up to lynnwood today.. well later in the morning to try to snag a a4ld out of a rig up there... Keep your fingers crossed.. I would like to have this damned thing running asap
Hey, I had a ford ranger follow me home on thursday... New suspension, stereo, radiator, battery, paint. The bad.... Needs a Tranny, Anyone here know how to rebuild it? or anyone got an old A4LD Tranny sitting around?? Mods go ahead and move if I've put this in the wrong spot.
HEY, I'm gonna be there tommorrow. I'm gonna be in the ford section. (pull a tranny ) for my New Truck. anyone wanna role by my Purple subie in the yard is a dead give away,. I'll most likely be in under a Ranger.
Hey there all, I have a Question.. In my 81 DL my heat works but only on the floor setting, I switch it to something else and it stays on the floor, Now mind you I like warm tootsies, but when it comes to being able to see I need that a little bit more. I remember hearing That these are vacuum controled, And considering how many times my stereo has been stolen It wouldn't suprise me If a line came loose or broke. Any Ideas?
This is what I did because I just had this failure this week. I pulled the axle, pulled the doj appart pulled the bearings out. Cleaned it all up. turned the inner gear thingy around and put the bearings back in and regreased it put a new boot on it and put it back in... shes hasn't done anything since. All for about $9 X..
Are Xt and Rx body's the same
xoomer replied to DJtheGOD's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The RX was a package for sedans as well as the three door coupe. Actually the sedan was first then the 3door coupe. (a friend of mine had a RX sedan from 85,) -
hate to break this but NEW ones are only 79.99 at schucks... for my wagon at least... remaned ones are 69.99 And if you come through me I'll get you the 25% employee discount. (anyone in the northwest.) I can't get huge amounts but I could "Buy these as a gift for A friend" I will occasionaly be able to do this... so if your stuck I can maybe help you out.
Rockys Major Long Road Trip!
xoomer replied to Bucky92's topic in Old Gen.: 80's GL/DL/XT/Loyales...
rocky's a great car. I miss my XT turbo that thing handled great. -
if its valve stem seals. hyperlube stop smoke works.!!
Normal RPM at 75MPH for XT?
xoomer replied to NocturneVoyager's topic in Old Gen.: 80's GL/DL/XT/Loyales...
my 4speed ea81 is at 3400 at 70 My legacy in 5th at 70 was 3100 -
ARGH!! Another Problem Please help
xoomer replied to xoomer's topic in Old Gen.: 80's GL/DL/XT/Loyales...
on the advice of this board and Superior Subaru!! I think I repaired it. I only drove like 4 miles on it but I think I got it... I pulled drivers Axle and pulled it apart Cleaned it turned the inner bearing apart and put the balls back in and greesed it up and put it back in. I made it work this after noon.. Hopefully its fixed. (at least until I can get a new car) or afford a new axle. My trip home is Up one of the steepest hills in town and it usually does it on the hill and it didn't do it tonight!! -
never got a pick of it but I had a cat that Would sleep on my desk but only if my subaru haynes manual was there. but as soon As I got home this cat would run outside and go to the hood and sleep there this was a suby cat. if he had to ride in a car he would sit quietly in the back. but any other car he would be running all over the place.
EA81 wagon bearings Part Number 0513859 $19.99 and Wheel seal 0521799 $3.99 Beck Arnley numbers.
ok, I'm getting a wierd shaking at different speeds. and I'm wondering if its a wheel bearing.. My rears feel fine but my drivers front seems to have some up down movement. I just replaced the tie rod. could it be the bearing? cause I can get that taken care of but I've never had a vibration like this. I also have a broken axle moving side to side in the back but it doesn't seem to be the problem. (no clicking) anyhow I can't afford to have my car down, Any ideas? I'm going to need something asap
Replaced the tie rod.. and was fine.. and it was fine then after going up the steep end of 180th it started doing it again.. -
I was driving on the freeway going about 60, and the car started shaking really bad... I pulled off the wheel and the outer tie rod looks like it seperated from the boot... and had a lot of shiny looking parts... The part of the tierod that bolts to the wheel assembly looks like its coming apart... Opinions needed, Is this the cause of my shaking??
ok thanks nip
but this is my second tank of gas... (I put texaco in there.) it seems to run better.. The wierd thing is once its warm its fine. I can shut it off and start it again no problem.
My car was doing the samething after I had installed my car alarm, There is a pink connector under the dash(in my car) that had come undone. this wire aparently is the one that runs power in to the computer?
pretty much It wasn't giving me this problem until after I got this gas.. I had other problems.. but I remember that I got in the car the next morning and she didn't want to start
