105
20 year-old car is expected to need a 'sucky' repair every few months. while warm and idling, try tugging/pulling on some wire harnesses and hoses under the hood - maybe a vacuum hose is cracked (even a vacuum gauge might be useful with this problem) or a ground or other wire/connector is intermittent. Does it feel like the car is 'pulling' when this happens? maybe a Torque Converter issue?
there's a way to measure the tires with some chalk and a run on some pavement, but maybe you can get a new tire to match the other 3 new ones you're picking up? some people have found a single, slightly worn tire on ebay or craigslist to match a partial set after a sidewall blow-out. (will FRS rims fit on your car? same bolt pattern?)
Subaru has recommended for decades that tires be within 1/4" of each other in rolling circumference. Reality seems to indicate the system may not be quite as sensitive as they want you to guard against but, any tire (axle actually) turning faster than the others could be sensed as slippage and cause the AWD system to begin engaging. the fact that there are different tires on the car may also point to prior abuse of the system by mixing tires.
did the car have normal feeling brakes in the past? any work done or wrecks before the problem began? inspect all the brake calipers and caliper brackets. are all the brake pads wearing evenly? any wedge-shaped? brake lines bled of air? any damage or major rust around the firewall where the MC is mounted? after idling the car, pull the hose off the booster, there should be a woosh of air go into it. If not, it could have a leak? (I don't guess it's possible the booster hose is on backwards? maybe test by blowing into it - should block blowing from the engine side)
did you use the 'line' indented on one of the 'tabs' at the rear of the crank sprocket? Or, did you use the 'triangle' (some call it an arrow) at the front of the crank sprocket? (you MUST use the line. and none of those tabs can be broken off) the 'tooth count' referred to is the number of teeth between the various pulley index marks. Not a bad idea to use the wrench to turn the system trough 2 revolutions, stop at the cam/crank timing positions, then count the belt teeth between the marks and compare to Subaru numbers. also, the car could be flooded - if you suspect that, try starting while holding the gas pedal on the floor. That signals the ECU to cut fuel.
rebuilt axles are notoriously poor in quality. if they are truly 'new' (as in, new Subaru axles) I would trust it isn't a cv joint. But rebuilts often have the case hardening ground away, cheap over-size bearings dropped in, cheap grease added, etc. maybe 1 out of 10 will last. just make certain it IS the diff before proceeding to swap the trans or w'ever..
does the car have a filter spun-on the side of the trans? or, is it remotely mounted like our 03 OBW? anyway, you may need a new filter if it's waterlogged, it isn't an oil filter, built differently inside - that is, you need one from a dealer I think. or, if the TC was stored outside, maybe the filter is now clogged and excess pressure is pushing the fluid out?(dunno if the trans filter has a bypass)
