105
Even though it was replaced, seems like the starter (solenoid?) is going out. Keep a chunk of 2x4 or a bat with you and the next time it fails, whack the starter 2-3 times 'medium hard' and then try starting it. Not uncommon to get poorly rebuilt parts. I suppose it could be some kind of poor ground or still a bad switch/relay in the starting circuit. Does any amount of whacking on the ignition switch area seem to help? I dunno Carl Carl
I now am left with just reading as there are folks involved with WAAAAY more experience than me - but I gotta say, based on reading this morning, it is imperative the plug wires/boots and plugs themselves be carefully inspected. Seems to me the wires/connectors could've been compromised such that it took a while for arcing to destroy them and MAYBE the coil pack or something. I dunno - carry on Carl
Maybe neutral lockout or something? Wouldn't exhibit the symptom of gradually getting worse. Probably Temp Sensor wouldn't either. Maybe IACV is dirty/sticking? Could you have gotten bad gas or water in the tank? Checked the filter? man - I'm just grasping here. I also kinda liked the tooth jumping business for the belt but you say everything lines up. Is it an OEM belt and did it seem EXACTLY like the old one? How bad was the old one? Did it break on you? Carl
Have we discussed why the work was done on this engine to begin with? Was it running well before the work? Also, how long and under what conditions ahs it been stored? Do the plugs get wet when you crank it? That would tell you the injectors are opening at least. Have you tried the 'clear flood' pressing of the accel pedal? Does a strip of paper try to 'suck in' when held at the tailpipe during cranking? Carl
Seems like it would be more likely to stick closed than open - but I suppose it's possible. Have you checked for a wet cylinder? Is it possible an injector is stuck open? Did you get high flow injectors or something?(often a stock pump can't keep up.) I dunno - hope someone else will join us, I'm quickly getting out of my comfort zone! lol! Carl
