1 Lucky Texan
  1. hahahaha! With it being throttle related, I don't see how it can't be missing/bad vacuum line or otherwise 'intake' related. keep us informed OK? Carl
  2. speaking of tires, in some cases - they could make a big difference in some of thoses tests. still, fun video - thanx for posting. Carl
  3. this thread is shaping up to be pretty good; Best Manual Transmission Oil
  4. When you were switching back and forth and dyno-ing the car, did you reset the ECU each time and allow it to adjust the timing for the fuel? Carl
  5. Well, it seems he's already determined that coasting at 40 would sound OK but 'foot-on-gas' at 40 is noisy. I dunno Carl
  6. make sure the air filter box is clipped in well at the bottom. Not sure on your car - but it has happened to a lot of folks. Carl
  7. I suspect he meant Altezza /whatever style cleared lenses. probably whatever fits the other Imprezas from that MY range will work. like these; http://search.ebay.com/search/search.dll?cgiurl=http%3A%2F%2Fcgi.ebay.com%2Fws%2F&fkr=1&from=R8&satitle=altezza+93+subaru&category0= Carl
  8. hah! "let's see....angry, hungry -what's the 3rd one ending in gry????" lol! Carl
  9. Do not forget the thermostat and the rad cap if they weren't serviced. Though it seems the cap might not cause this problem. Also, be certain the cabin heat is set in high - just to confirm clearing out any air in the core. I dunno good luck Carl
  10. Other than making sure the engine is in top running condition and using the correct fuel grade - anything under the hood is gonna require some extensive work or a swap (2 liter turbo from a wrecked STi or WRX or a front clip from Japan or ?) Lighter pulleys, lighter rims, lighter flywheel if manual tranny will free up some ponies for acceleration. There's lot more potential in suspension work to make a fun AutoX or rallyX machine, not so much for 1/8 or 1/4 mile. check the NA forum at www.nasioc.com too. Carl
  11. Can you describe the noise with more detail? Also, how's the radio reception - especially AM. Carl
  12. Did this happen after some service was done? Are there ANY other issues with the car that seem unusual? Carl
  13. Are those the ones that have similar load to the stock horns? No heavier wire/relay required? Carl
  14. The only other thing I can think to mention is, I have a personal habit of going around 2-3 times only bringing the torque up to spec on the last pass. I dunno if it's REQUIRED but I just can't bring myslef to go all the way to 65 on the first nut while the others 4 are loose. Carl
  15. If you throw out the highest and lowest numbers from this thread so far, total all the other numbers and divide, I get approx. 71.6 . I see no reason not to use 70-75 ft/lbs and then just check the torque a few times, especially on new alloys. There is further discussion we could pursue as it relates to lug nut/rim seat profiles, use or not of anti-seize, nut thread engagement, etc. I think there is a page at www.tirerack.com that discusses lug nuts. be careful out there. Carl
  16. I used 65'/lbs on SSR alloys the day I went to the track with my WRX and checked 'em twice during the day. They never budged. Carl
  17. Was it Twain that said; "It's a very poor mind that can think of only one way to spell a word." As an aside, I've heard from a coworker who still has school aged children, that their teacher reports how poorly spelled papers are nowadays as they are littered with text messaging short-cuts! Carl
  18. Triple Treds are almost universally praised, but in Dallas may be overkill. I'd definitely spring for a tire that can take heat though. But the little ice and almost non-existent snow we get will be taken care of by the AWD without worrying much about the tire;s snow performance. Make sure the tires you do get are rotated at least every alternate oil change. just my 2 cents Carl
  19. In texas the vehicle must be in for the SAME problem(safety or operational) 3 times within some fairly small number of months. That is, if you have 5 DIFFERENT things that make the car stall 3 months, you're stuck. But if the ECU or ABS is bad 3 times in 3 months you might get a new car (I think minus some pro-rating for your use of the vehicle) and the opportunity to use the LL goes away after a year or something. I'd expect california law to be different in detail, but similar in intent. Carl
  20. If no luck, you could try buying an OEM unit from one of the onlive dealers. I've purchased from jamie at http://www.subarugenuineparts.com but there are others. Um - perhaps an '03 is worth trying? (take some measurements and a tape measure in with you. Oh, be sure to double check that the tabs at the other end of the filter box are seated correctly - on some models it's easy to mis-align when reassembling) Carl
  21. who knew there WAS a standard way to spell mosey? Besides, we Southerners are SUPPOSED to 'ignernt' ! lol! Carl
  22. Your superb knowledge and use of colloquial US english always amazes me. hah! Carl
  23. Might be better places to spend the money - lighter flywheel(but less that 11 lbs or so and folks have 'issues'), lighter rims, suspension bits. Carl
  24. email Joe at www.cars101.com maybe or contact my friend Ryan at Teape Subaru of Hurst | 240 NE Loop 820 , Hurst, TX 76053 Phone (817) 255-6200 | Fax (817) 255-6299 (I do nit get any $/benefit from these guys - just passing on possibly helpful info) good luck Carl
