wierd howl or hum trumpet sound from MAF area?
It's easy to miss the tabs going in correctly on bottom of the air filter box. I dunno - just a guess.
Forester pain in the neck
1 Lucky Texan replied to revano's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGood info on the glass distortion. Also, some people develop headaches from 'outgassing' of plasticizers in new cars, or after carpet/upholstery work. I wouldn't discount the possibility of an exhaust leak either. My wife's last car, Ford Windstar van, would sometimes cause 2 fingers on my left hand to get numb on long drives. It had 8 way electri adjustable seats IIRC but I never was able to make the problem better. No other car did/does that to me.
Very High RPM's after Timing belt replacement
1 Lucky Texan replied to Raindog's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWas there any tire/wheel installation done? Could you have smaller tires? I dunno, but this is a manual, and 'assuming other normal factors' the symptom reported is diagnostic for slipping clutch. Yes, if it's cable operated (someone here should know) it may need an adjustment, less likely with hydraulic but perhaps there is a blockage not releasing pressure completely or something. I'm going with Occam's Razor til more info is introduced. She said - what 115K? has it ever had a clutch? Wouldn't it be due for one? I dunno
Car jerky on sharp turns
1 Lucky Texan replied to mnewman0's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo, in theory and as reported by some folks, a tranny 'flush' seems to sometimes be able to free up a solenoid stuck closed by sludge/gumminess. Once the pressure can be released, a 'good' clutch pack will begin working normally. What constitutes a 'bad' clutch pack and , assuming normal C solenoid function, what would the symptoms be? thanx
New Subaru owner with bra question
I had a local tint guy install tint and ventureshield on my '06 WRX wagon recently. I did the fenders, hood and mirrors. So far so good.
1 Lucky Texan replied to Raindog's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXlol! yeah, IIRC you can nose up to a wall, tree, post/w'ever, select say 5th (4th?) gear and dump the clutch(at idle), the engine should stall. Is it possible she has a rear main leaking oil onto the f'wheel? I dunno - but I would get it investigated - soon
1 Lucky Texan replied to Raindog's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSetright is correct as far as the engine not being at risk. However, you really need to get this investigated. A simple adjustment now may save a coupla' hundred or more later. If the clutcth material IS actually worn away (quite likely at your mileage - and perfectly normal BTW) you will only get poorer gas mileage and destroy the flywheel, it may be damaged now. Really, have someone take a look ASAP. Soon, even engine braking will be reduced and you will only lose more and more 'driveability'.
1 Lucky Texan replied to Raindog's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI vote for slipping clutch. Likely coincidental. How many miles on the odometer and what kind of side street/highway mix do you drive? 75 in 5th at 3k sounds about right. I believe you. Bet the lower gears seem normal too - classic slipping clutch.
When you smash an F150 pickup into a '99 Forester S...
1 Lucky Texan replied to humanistic's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIn all fairness, any number of other vehicles she might've been in (including a Volvo) may have served as well at protecting her. I DO realize that personal anecdotes like this can have an effect of increasing brand loyalty and certainly a new Forester should stay on your list of replacement vehicles assuming it still fits other aspects of your selection criteria, but I wouldn't limit myself JUST because of the wreck. glad everyone's OK
torque bind?
1 Lucky Texan replied to djmark7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMight be worth triple-checking the tires. They should be the same brand/style/wear/CIRCUMFERENCE and not exhibit any tread seperation etc. I dunno
moved from altitude to sea level, reset computer???
I've had 2 different vehicles flip their CELs on altitude changes so I'm sure there is some effect on the 'system'. It wouldn't hurt to reset the ECU and recheck the tire pressure.
An STI for "grownups"?
1 Lucky Texan replied to dpoppeli's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXProbably the same ugly-@55ed way it's hung on my outback.
Growling rear end, 01 Forrester
1 Lucky Texan replied to Brick's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdoes a sweeping turn left sound different than a turn right? Some folks report the bad bearing sounds worse when it's on the outside of a turn.
90 Legacy AWD Malfunction
1 Lucky Texan replied to carfreak85's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI just wondered if reverse is also full time 50/50. actually, i dunno what i was thinking! lol! yeah - I probably should mix up my sig again - it's kinda getting old.
oil in coolant?
1 Lucky Texan replied to dklein90's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere's a coil inside the radiator that has tranny fluid pumped through it to help cool the tranny. I suppose if the tubing/whatever had a pinhole leak, you'd get the emulsion in the rad o'flow. It may mean you're trading HG problems for tranny problems though. I dunno how 'tolerant' the tranny would be of coolant mixing in - if it can even flow that way. Worth investigating.
1 Lucky Texan replied to carfreak85's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow would it behave in reverse?
Forester Headrest
1 Lucky Texan replied to hvnbnd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBut how would you know if they had already been 'activated' in shipping or were otherwise broken/maladjusted? can you go back to the dealership and confirm that ALL the Foresters on the lot are like that or just a few or ?
oil in coolant?
1 Lucky Texan replied to dklein90's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoesn't sound good. Look under the oil fill cap for 'chocolate mousse' too.
cheapest brand of tires
1 Lucky Texan replied to 97OBW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI JUST got some Kumhos on my new ride. So far so good. So, you figure my '06 takeoff wheels and tires are worth only about $250? I'm very disappointed but - at least it will help offset the cost of my new wheels. sigh
cheap/price free improvements
1 Lucky Texan replied to 97OBW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell, it's a weird question. Um - like if you want to accelerate faster, take out as much weight as possible, seats, spare tire, tools. Keep windows rolled up - even in summer the savings in wind resistance at highway sppeds makes up forrtunning the a/c. maybe remove the intake 'snorkus' in the fender. Keep it waxed and clean. Run the lightest weight oil suggested in the manual - and change it on schedule. Keep the plugs gapped properly. Keep a clean intake filter. Use 'touch up' paint on the 'parking lot rash' areas. Use 'wet tire' or similar product on the tires. Maintain proper air pressure in the tires - check at least monthly. Use maybe 5%-10% more pressure than the manual states. dunno what you're really wanting to do
1 Lucky Texan replied to 97OBW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXProbably some from the junkyard. Cars with very new/good tires do get junked occasionally. I have been in the position in the past where I actually bought used tires. It was never a great value - just an emergency maneuver. Shop at tirerack.com but take a printout to you local tire store (Discount, NTB, whatever) and see if they can beat it. Or, ask around one of the tire shops at quitting time if there is a way a guy who's strapped for cash cou;d get some good used tires. Sometimes folks jst but new tires before their old ones are wornout. The big problem nowadays is the liability that a shop incurs if they sell and mount used tires. They are reluctant to do it and in sime states it may be illegal. But giving a guy a 50 dollar bill when he's walking outta the tire shop at quitting time MIGHT fix you up. It's tough when you're strapped and the vehicle needs shoes. We've all been there. Don't be ashamed to ask your relatives, friends - even your boss. They don't want you to risk your life on crappy tires. good luck
Who here runs heavier motor oil?
Additionally here in the States, a manufacturer has a much greater incentive to recommend lighter weight oils to help meet CAFE standards, and I suspect they do that even if it means your engine may 'only' last 150K instead of 250K miles. I dunno
How long can a battery last?
thanx to browsing the above links to other links, I found the map I recalled; http://www.uuhome.de/william.darden/carfaq12.htm Seems their average for my area is approx. 41 months. I'd say my personal average is a little lower - probably other folks get a better average.
I suspect that when my cars sit in the summer sun here in Texas it would be quite easy for under-cowl temperatures to reach 140-160 F . At those temps for a coupla hours, what amount of 30W versus 40W oil is not squished out from the cam lobes? What about the oil squirters spraying oil directly on the underside of the pistons in the turbo engines? What about shutting the engine off after a hard run and the water stops circulating? What temp spikes can the valvetrain see? How much oil will be on the cam lobes the NEXT time the engine is started? If I could get Mobil 1 10W-40 at the same great price I always find the 10W-30 I'd run it. I may switch from 10-30 to the 10-40 after I get few thousand more miles. I dunno
Spotted on Ebay, sorry if it's WTLW
http://cgi.ebay.com/ebaymotors/Vintage-Subaru-FF-1-owners-manual-HTF-REDUCED_W0QQcmdZViewItemQQcategoryZ6762QQitemZ8009033054QQrdZ1 fyi
