Cold collared Subaru
1 Lucky Texan replied to RLJacks01's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow long does it take for the temp gauge to move up? Does it appear to indicate lower than before? maybe the cooling system's thermostat is stuck open. Any work done just prior to this problem? I'm guessing last winter all was well? Carl
Mustard in coolant?
Yeah, I've seen the chocolate mousse before - unfortunately too many times - on other vehicles I've owned. Honestly, if I could think of how/why its in the cooling system, I'd think it was that yellow 'QC' paint that they hit different areas with. I'm guessing it is part of the QC to inspect/mark certain bolts, etc. with paint. I dunno. It just kinda offends my sense of order to see anything not a liquid in my radiator.
Mustard in coolant?
I don't have any indications of a problem, but , when checking some fluid levels, I saw some mustard yellow substance deposited on the rad cap and on the inside surface of the filler neck. My GUESS is it may be the sealer that Subaru now includes in the cooling systems. Have any of you guys used the sealant stuff? Is it yellowish?
97 Outback vibration
If the problem presented itself soon after the above service - definitely look for a poorly reattached hose or the intake filter box dealie not tabbed into its slots. I think I'll go look for some pain meds, thanx for the idea nipper!
I think you have reasonable explanations given the description(especially the change with throttle use). I'd throw in an ill fitting air filter or the box not being clipped in properly over the filter. I wonder if the use of the word 'vibration' is indicating strictly sound or also a feeling? Also, is the sound from the front, under the hood? At 75 you're likely doing over 3100 rpm, does 3100 rpm make the same sound at lower speeds?(in a lower gear of course). seems a clogged cat converter is a good guess. Any 'history' on the vehucle we should know about? like a rich-running condition or recent repair work?
grinding (abs) in only one wheel?
1 Lucky Texan replied to fnlyfnd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCan you describe the sound better? Are you close to needing pads? usually the indicator makes a squealing noise. have you bounced the corner? possibly a strut bearing dealie (at the top). I dunno
Brake Light On
1 Lucky Texan replied to Sydfloyd44's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMost likely the reservoir is low on fluid either because of a leak or more likely because you are nearing the end of brake pad life. Either take it in to have the brake system inspected or let us know if you are interested in pursuing this as a DIY project.
02 Leg/Out brake job...need expert input
1 Lucky Texan replied to jgang's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou will probably need to take the rotors to be turned/ground. Although some folks find the info to be counter to their beliefs about warped rotors - you might find this article interesting; http://www.stoptech.com/tech_info/wp_warped_brakedisk.shtml Do not overlook the possibility you have 2 issues at once - bad tires or a tire with some tread seperation, and bad brakes. Though recently, new pads and rotors on a Dodge I owned cleared up a lot of wheel vibration under braking, which did not cause any noticeable pedal pulsing. In the past, I've had bad tires vibrate when brakes and alignment were OK. just some thoughts OBTW - do Mintex pads dust less or, have a lighter colored dust than stock? I have white wheels and an just asking.
Pics of my '06 WRX wagon!
The specs say so 2.5 litre 230hp/235 ftlbs at 3600rpm - but I think the weight went up a little. Overall, I think the vehicle is dyno-ing and performing a little better than the older ones. Its more car than I am driver! But I may take a coupla courses in the spring. There's a run south of here (DFW) monday and I am off that day, but I think I'd like to drive it a little more before I take it someplace where I could destroy it!
just fyi - I finally put a few pics of my car in the gallery.
Wagons only - post your pictures here!
- Got bearing fixed... still have the same problem...
1 Lucky Texan replied to JrFreak's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell, reconsidering basic questions makes me wonder if the OP has put any odd-sized tires on the vehicle.- Thermostat Install ?'s
1 Lucky Texan replied to Lawsonmh15's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPerhaps a new, clean container to catch the coolant in? Just poor it back in.- manuals on eBay
Sorry if this has already been posted; http://search.ebay.ca/_W0QQsassZcrappalooza no connection, blah, blah - just FYI- Caliper/ Brake Issue? Please advise!
1 Lucky Texan replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAny chance someone could stomp on the brakes while you're observing the caliper? Maybe a bolt is broken or it is twisting in some strange way? Just trying to think about the geometry required to make the pad wear as described. weird- Caliper/ Brake Issue? Please advise!
1 Lucky Texan replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPerhaps this is just an odd failure of a replacement pad? Some material just broke off or something? here's some brake info; http://forums.nasioc.com/forums/showthread.php?postid=2004938- 95 legacy awd wagon - rear end vibration
1 Lucky Texan replied to hmdavis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXShould also be easy enough to swap tires with the front and see if the problem changes or travels with the tire. Is it worse with a sweeping turn one way versus the other? That may pin down a specific side of the car to concentrate on.- 95 legacy awd wagon - rear end vibration
1 Lucky Texan replied to hmdavis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgood post - if it is more a hum and not a felt vibration - possibly a wheel bearing?- Alloys for O6 Outback
1 Lucky Texan replied to Ranger83's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHmmmm.... I would email Luke at http://www.tirerack.com . Also, http://www.cars101.com would list any changes to the bolt circle/offset. Offset SHOULD change with any width changes. I'm pretty sure only the STI and the Tribeca have 5x114 bc. POSSIBLY the Spec B GT. I dunno if any brake changes were made that could prevent doing what you suggest.- Caliper/ Brake Issue? Please advise!
1 Lucky Texan replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIgnoring for the moment the weird wear on the bottom egde of the pad. Is the thickness of the pad material of the inner pad approx. the same thickness as the outer pad? If so, there must be something more strange than a stuck caliper going on. If the difference is very noticeable, then something is preventing the caliper from sliding.(it slides to bring the outer pad into contact with the rotor such that the amount of force is virtually equal on both sides of the disc. It must be free to slide. Rust or damage could prvent this, or possibly a pinched or bad brake line is acting like a check valve or?????) Has ther been any suspension work done recently or has the car 'tagged' the curb or been off road or hit a pothole? No ABS or other indicators lit on the instrument cluster? What was the last service issue done to the car?- 1-winter tire solution?
1 Lucky Texan replied to dromond's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif Vic/se's advice is a no go for you - maybe a set of chains would be a better investment right now than tires. Easy to try the car out both ways, easy to store and relatively cheap. I know it's gonna limit your speed and fun - but it may be the best way out. I dunno- 2005 Forester with squeaky dash
1 Lucky Texan replied to cathie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you can pin down the actual area that squeaks, some SILICONE (not petroleum based) lubricant will help. Look for a dusty area or a different texture where the pices may be moving next to each other. Silicone lube won't attack plastic like most petroleum lubes will. Doesn't smell like oil either.- duty c solenoid??
1 Lucky Texan replied to gmichaelv's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would say, based on good logic in previous discussions with Legacy 777 and others here, that the 'duty solenoid C' is functioning fine, and your problem is likely the clutch pack itself. It's worth measuring the circumference of your tires. I suppose, it could be a frozen U joint, though it would still be turning, there would be no power on it. Likely clutch pack is bad.- 2005 Forester with squeaky dash
1 Lucky Texan replied to cathie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI SWEAR the other day I heard some squeaking in my '06 WRX wagon! But I don't know if I can reliably duplicate it. I may insist that they at least investigate it so , if it becomes worse in the future, I might get some attention. Mine seemed forward right of center (I'd say slightly right of the center of the pass. seat but maybe not all the way to the door hinge. approx under the windshield. It was kinda brief.- Need advice on tires
1 Lucky Texan replied to tjfaenza's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOh, it didn't quote my 'sig' file in your reply. So, for those of you who may be confused, he is refering to the passage below which is from a sci-fi book. sorry - for the OT but...... - Got bearing fixed... still have the same problem...
