Everything posted by bratsrus1
Red hatch brat spotted superior wi.
Hey wounded brat This is Jerry, i am the guy that owns that hatchbrat and it is for sale for the right price. Lots of custom parts on this subie. Thanks Jerry
want to put an ej18 in my ea81 BRAT, HELP!!!
Hi This is Jerry, i have an Ej1.8 engine in my 85 hatch runs great very happy with it and i am getting 38.4 mpg with it. I bought it from Super Dave he also cut down the harrness he did a super job really clean. I live in Selah next to Yakima if you want to see my hatch or call me 1-509-952-2855 i can let you know all about it. Thanks Jerry
Talking about how to improved MPG?
Hi This is Jerry, i have an 85 EA81 hatch back and i drive 500 miles every week just to work and back. So with that i have installed a 93 imperza 1.8 engine everything all stock on the engine except air filter it has a cone filter. I use the stock Y pipe it all fit. I have a 86 RX 5 speed dual range tranny with 3.70 gears and a VLSD 3.70 rear also rear disc brakes. I am running stock tires 185/70R/13 now this is the kicker i am getting 38.4 mpg for now but i still have a bunch of things i want to do to get 40 mpg. The car weights about 1000 lbs. less than the imperza. Thanks Jerry
im new to the roos
Hi Scott This is Jerry, your hatch is begging you for a 5 speed swap oh please let me have a 5 speed. Thanks Jerry
LSD vs VLSD
Hi This is Jerry, i have bolth of them. The lsd in my hatchbrat well put it this way on black ice the back end will catch up to the front end, not enough weight on the back end. The vlsd i have in my hatch and black ice it dose fine thats why i chose it over the lsd. I do alot of driving on black ice every winter. Thanks Jerry
Tranny Crossmember Question
Hi This is Jerry, yes i make a 5 speed kit for the EA81 cars and brat if you want to know about it call me 1-509-952-2855. Thanks Jerry
BRAT Meet 2011 Planning
Hi Andy This is Jerry, that sounds good to me i will have my hatchbrat there. I had a really good time last year. Thanks Jerry
Transmission and tcase...
Hi Blue This is Jerry, yes i have a sammy setting in my 86 hatchbrat. I live in Selah come on over and see it you can also call me 1-509-952-2855. Thanks Jerry
Mark Your Calendars, Dig Out Your Camping Gear, and Prepare for WCSS 13!!
Hi This is Jerry, even if i am in a pine box my wife can put me in the back of her baja and take me there. Just prop me up and have a good time, i will be there. Thanks Jerry
Carb'd EJ?
Hi This is Jerry, i have a holley 4 barrel carb on my 2.2 and holy cow it knows how to smoke the tires. Thanks Jerry
The Big Northwest Meet
Hi This is Jerry, cool looks like i can do this trip. I will be in 1 of my EA81 cars on the road again just can't wate to get on the road again. Thanks Jerry
I got some questions about my ea81
Hi Nick This is Jerry, call me and i will let you know all about the 5 speed kit 1-509-952-2855. Thanks Jerry
Carb'd EJ?
Hi This is Jerry, the red wire is key start the red with green stripe is the hot wire from the coil the other wire is the ground side of the coil. Thanks Jerry
Wcss 13???
Hey Twitch This is Jerry, all my EA81 cars run EJ engines in then, i have only 1 EA81 engine left and it's from Japan. Thanks Jerry
Wcss 13???
Hi This is Jerry, all i can say is i look forward in going to the show every year. This year i will be there in one of my EA81 cars. I am ready to go now. The show to me is the time i can see everybody that i talk to all year long on the computer. Happy trails to everybody Thanks Jerry
I bought the beast!!
Hi This is Jerry, i live in Selah next town to you give me a call i have that set up. I have an EJ 2.2 with a holley 4 barrel on it 1-509-952-2855. Thanks Jerry
piston pin removal tool
Hi This is Jerry, to get the factory tool cost way to much money i have check into it. What i did was get an old blade screwdriver bend the end of it using a torch to heat up the end of it so i can bend it. The screwdriver was about 6 inches long, took the handle off of it then clamp a vise grips to it. the adjusting bolt to the vise grips i welded a nut to it to fit my slide hammer. Then remove the C cilp from the piston then slide the screwdriver in the rist pin then slam away until the rist pin is out. But i do have the rist pin installer tool. Thanks Jerry
5mt d/r awd swap
Hi This is Jerry, i have an 85 hatch back with the EJ 1.8 imperza 1993 with a 86 RX turbo 5 speed dual range tranny 3.70 gears. I also have rear disc and a VLSD. Running stock tires 185- 70R-13 for high way driving now i get 38.4 miles per gallon. When it warms up i have a few more things to do and i am sure i will get my 40 mpg. I really like my subie to each is own. Thanks Jerry
Trike Builder Needs Your Knowledge
Hi Larry This is Jerry, they have a dissy for the EJ engines i have 2 of them. I am runnung a 96 imperza 2.2 with a holley 4 barrel carb. I got them from New Zealand, 2 wires make this engine run. We need to talk call me 1-509-952-2855 Thanks Jerry
brat body on toyota frame with 350 engine?
Hi This is Jerry, the car is a 86 hatch that i cut the roof off of and put the roof from a gen 2 brat also use the back wall. I had to lengthen the frame 13 inches. It is set up so i can pull the frame and install subie running gear back into it. The engine is not in it but it is set up for the 2.2 with the 5 speed dual range tranny with a short center drive line to the transfore case. I have way to much money into this project but i would like to get 3000.00 i also have another complete front end and it has rear disc brakes. Let me know Thanks Jerry
Hi This is Jerry, if you look at my avatar you will see me standing by my 86 hatchbrat that has a sammy frame and running gear under it. The reason i chose the sammy is that the wheel width is the same as the subie has. I didn't want the wheels sticking way out past the fenders. It is just spring over no lift and yes it's that tall i am 6 feet tall. Oh by the way it's for sale all the fab work is done. Thanks Jerry
Hi This is Jerry, use a sammy frame it sits along side of the subie unibody frame. You will have to strech the sammy frame because it is to short. Thanks Jerry
5 speed for 86 brat transmission questions
Hi This is Jerry, give me a call 1-509-952-2855 i can let you know all about the swap over. I live in Selah next to Yakima not that far away. Thanks Jerry
5 speed d/r into brat
Hey Bratclay This is Jerry, call me tomorrow i can let you know what all you need 1-509-952-2855. Thanks Jerry
EA to EJ Radiatior Swap
Hi This is Jerry, yes the radiatior is closer to the engine but everything clears and i have about 2 inches of clearence. My subie is under 7 inches of snow and it's still snowing i hate that white crap. Thanks Jerry
